In my experience this has been caused by a bad lamp. First thing to do though, is to make sure it isn't an airflow problem by vacuuming out all the vents around the set. This will probably save you an expensive service call: Google the lamp part number and order one online. Probably 100-125 u.s. dollars. Replace only the bulb and don't touch the front glass. This should solve your problem...Honestly. Good luck Russmann
If standby light flashes 4 times then it is problem of Fans in TV and if light blinks 5 times then its ballast supply issue. Let me know how many times standby light blinks in your TV to find out problem section and its solution.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sony Grand WEGA KDF-60XS955 60
My Sony Grand wega KDF-60XS955 has developed problems after having the lamp changed by Sony. A blue...
(More)
My Sony Grand wega KDF-60XS955 has developed problems after having the lamp changed by Sony. A blue cloud developed on the bottom of the screen which has now gone to both sides of the screen. In addition, there are bright blue points of light in hundreds of areas on the screen.
yellow and blue vertical lines on screen . Tried resetting, unplugging power, moving speakers. No...
(More)
yellow and blue vertical lines on screen . Tried resetting, unplugging power, moving speakers. No relationship with cable. It's same with video. They are very thin lines about 1 cm apart.
