Question about Memory Cards & USB Flash Drives
Audio I hear no sounds over my speakers. When I try to open the volume control, it tells me that there is no playback device. I know there is, because two weeks ago, there was no problem, now there is. I've tried updating drivers and rolling back drivers, I probably screwed it up worse, I don't know. Do you have any clue?
  • 66 Answers
Re: Audio
Somtimes I have that problem when cleaning up the drive once a month. I forget to install media player,power dvd etc.
You may try the OEM disks that came with the computer. Most let you re-install stuff without formatting and losing anything but I still back stuff up before just in case.
Hope this helped a little
Posted on Dec 28, 2007
0 characters
3 Points
Noontec hdd media player gv3341
The movie contains 'DRM' encoding -- "digital rights management".
The NOONTEC cannot access the Internet to obtain the DRM information to authorize playback of that file on that device.
Feb 09, 2014 | Memory Cards & USB Flash Drives
My transcend 2GB pen drive is detect only in linux only
First, try the cord and the I POD on another machine. If that all works, then it's the machine. If that's the case, try this:
Unplug ALL USB devices.
Open Device Manager.
View, Show Hidden Devices.
Uninstall all devices under USB Controllers.
Uninstall all devices under Storage Volumes. Say no to any reboot prompts until you are finished. Also, if a Storage Volume doesn't uninstall, ignore it and move to the next one.
If you have a yellow ? with unknown devices, uninstall all of the entries there as well.
When this is done, reboot TWICE.
Reconnect the USB devices and see if they're recognized properly.
Please rate me if this solution works for you
Thanks......Have a great time
Jul 06, 2010 | Transcend (589307) Media
My transcend 8gb pendrive is not working. plz help me
plug in your flash drive then go to device manager then universal serial bus controllers expand it will see usb mass storage device right click in it and select uninstall now remove your flash drive and restart your system plugin flash drive.... this time it will detect your flash drive and.. i think branch is in panjagutta, secundrabad it is in jagdish market at abids and chenoy tradecentre mg road parklane..if some how you get to properties box try to format with ntfs system....goodluck
Jun 14, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Can i use a memory stick to playback music through a hi-fi music centre,or portable radio please.
Only if your hi-fi supports such devices or if there is a port to plug it in. Check also the Hi-FI user manual.
May 30, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
  1. Open control panel.
  2. Open administrative tools.
  3. Open Computer management.
  4. In the left column click disk management.
  5. This populate all the disk present
  6. Locate your memory card
  7. Then you can delete the partition entire and build new one
  8. You can format with Fat Or FAT32 file system
  9. Do not perform quick format.
Another options are available to format via cmd
To do that
At the run Menu type:CMD
then a command promt window will open
Type format x: /fs:fat32
Note that x is volume label (memory card drive label may d, e or f)
try this
Feb 25, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
No sound on my boy's game Dell laptop
Hello and thank you for using Fixya's services.
I think he may have meant do not install because you were downloading from another computer to your flash drive. If you would have installed, it would have been on the wrong computer.
So, insert the flash drive in the computer that needs the sound. Open the flash drive and install the driver. There should be a .exe or setup.exe, where you can double click and it will take you thru a wizard.
NOW, if there is not an exe, then you will have to do a manual install. To do this, open control panel. Click on add/remove hardware. Follow the wizard and when it asks you for the driver location, just point it in the direction of the flash drive.
* TIP: The manual is always a little difficult. I would recommend taking the easy road and getting on the computer that has no sound, going to this website, download and run the software. Install, reboot and your good to go.
Hope this helps and please let me know if you need further assistance.
Nov 02, 2009 | Memory Cards & USB Flash Drives
How to fix a usb composite device?
You need to manually allocate the memory locations which is a rather complex job. Try to find a Windows-savvy techie.
Jun 14, 2009 | Memory Cards & USB Flash Drives
Pendrive not working
1. Click Start. Click Run. Type cmd and press OK.
2. Type "set DEVMGR_SHOW_DETAILS=1" (without quotation marks) and press Enter.
3. Type "set DEVMGR_SHOW_NONPRESENT_DEVICES=1" (without quotation marks) and Press Enter.
4. Type "start devmgmt.msc" (without quotation marks) and click press Enter. It should open Device Manager.
5. Click View. Click Show hidden devices.
6. Click "+" to expand "Storage Volumes" and right click on everything that is under Storage volumes. Also, expand Disc Drive and uninstall everything present under this apart from your Hard Disc (Please make u dont uninstall Hard Disc)
7. If there any unknown devices right click it and click Uninstall.
8. Reboot the computer.
If this does not work please let me know.
Nov 14, 2008 | Transcend (589307) Media
Any idees?
Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab.  Then click on the “Repair” button to start the repair process.  Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in.  If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
-Tha Mp3 Doctor
Sep 14, 2008 | Memory Cards & USB Flash Drives
Shark 75160HS 2.1 Multi media speaker system
HEADPHONES AND SPEAKERS Hi There Try this, CONNECTION Check your connections on Rear part of your PC. Lime is for Sound Out usually a speaker, Pink is for Mic, Blue for Audio Input. VOLUME Try Adjusting the vlume on your PC first. Check the volume on the Headphone too if there is one. CLEANING Using a dump clothe. Wipe the plugs and jacks with a twisting motion. WIRELESS\BLUETOOTH Check your battery if it is drained. Try replacing them with a new one or charge them if they are rechargables. If all fails then You may have a Sound Card problem. Using a spare Speaker or Headphone check it if it works. If its not then its Defective and needs replacement. If its working then your Speakers or Headphones are defective. Try fixing them by cleaning or checking the Continuity of its cables using a analog Multi tester. Hope This helps ======================= If you are having trouble with Newly bought items then return them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 21, 2007 | Memory Cards & USB Flash Drives
Memory Cards & USB Flash Drives Logo
27 people viewed this question
Top Memory Cards & USB Flash Drives Experts
Brian Sullivan
Brian Sullivan
Are you a Memory Card and USB Flash Drive Expert? Answer questions, earn points and help others
