Question about SanDisk Sansa c200 MP3 Player
Connection problems i plug it into m laptop and it reads it for like a second and then its says MTP Device failed ?????????idk what that means?
  • bootiewifey Jan 08, 2008
    how do i change it from mtp to usb
  • 192 Answers
It is problem of MTP chip used in that. You have to format it with special formatting tool. Any mobile repairer who have MT box can do this. Because RX, TX and Ground pin should be identified properly to format it. If anybody near you have this MT box he can do this. If he needs pinout of that device mail me i will send it to him. patel352003@gmail.com
Posted on Jan 06, 2008
MTP USB device failed to install on Windows 7
Did you instal the software that came with your camera?
You also can download the new View NX from Nikon for free. Always first install the software, before connecting any device on your computer. Special what it is a device like a camera.
The computer can interpret a camera on an USB for: Now I nave to charge the battery. Or when you start the program to transfer pictures, now I have to download pictures, or some camera's like your D200, also cam be controlled remotely over the USB, if the correct software for that is installed.
The software windows needs to install has to be on the computer first.
May 15, 2013 | Nikon D200 Digital Camera
It is stuck on the disconnected screen and it won't turn off or on. It had been charging and when i took it off, it is frozen. It is a new laptop with norton antivirus. So I don't understand.......
Try and reset the player. Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Then try this Connect the player to your computer. The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. <<<<< BUT TRY THIS ALSO >>>>> Check the Device Manager 1. Right-click My Computer, and select -- > Manage. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. *** See This Tip Posted here **** --> http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <-- Copy this address into a new window. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. >>>> BUT TRY THIS <<<<<<< Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Feb 26, 2010 | SanDisk Sansa Fuze MP3 Player
On my mp3 i had washed it on accident but the battery was dead when i did i tried to plug it into the computer it did nothing; i dried it it finally worked with my computer reading it and all; i instantly...
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. <<<<< BUT TRY THIS FIRST >>>>>
Feb 23, 2010 | SanDisk Sansa E280 MP3 Player
MTP wont install
if that failed, why don't you do what it says and call the device manufacturer - i mean, really
just kidding
if you have Vista, forget about it
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jul 24, 2008 | SanDisk Sansa e250 MP3 Player
IDK?
this means the driver isnt installed for the device.
first, try plugging it in, then goto my computer and look for 'removable device' that is where you will access the mp3's.
If all else fails, google 'nextar mp3 player driver'
good luck :D
Jul 03, 2008 | Nextar MA566 MP3 Player
GPX MP3 player
on the top right of you mp3 there is a button that says M.
Try holding it then plugging it back into you computer.
O.K ill try to make this easy now, do that when its off because when it says mtp on mine i can put songs on it but idk why yours is not working so try what i said on top and good luck, because if it says usb that means you share stuff but when it says mtp that means you put on music.
May 19, 2008 | GPX MW3837 MP3 Player
Turns off and on ..crazy insignia!!
Yes, some systems don't provide enough USB power for battery recharging of certian devices. You may need to purchase a separate USB power adapter.
May 17, 2008 | Insignia NS-DV2G MP3 Player
Creative zen v plus
i had the same problem but solved it, it seems that the usb driver does not always install with the software installation so you must install using the DEVICE MANAGER make sure first your mp3 player is connected, so ( copy & paste) your software to desktop, then go to CONTROL PANEL, then SYSTEM, then HARDWARE then DEVICE MANAGER, in device manager you should see ( zen v plus ) with a yellow question mark above it, which means the drivers are missing, click onto that and follow instructions to install the drivers which you will find in the software you have pasted to desktop. good luck, tony spain
Mar 22, 2008 | Creative Labs ZEN V Plus MP3 Player
MTP Error
When the YP-K3 2 gb device is plugged into the USB Port, the system says "Found New Hardware, Samsung YP-K3" which then switches to "MTP Device" and then fails on an MTP error. It seems to be searching for a driver, and cannot find one. H E L P!!!!!
Dec 29, 2007 | Samsung YP-K3 MP3 Player
MTP DEVICE Sony 4gb walkman NWZ-S616 not installing
if you have a problem about MTP Device and wont be able to show in your "My Computer", here are tips that may help you fixed your problem:
*First- Uninstall the MTP Device Driver in your system.(Right click My Computer then manage, then click Device manager at the left part, then after that, find MTP Device in your right part, then click and Right click the name of your MTP Device then uninstall.)
*Second- Reconnect the device and then after a pop-up show which says, New hardware found,
click install the driver in a specific location, then choose the bottom option and then choose
Storage Device.
*Lastly- Turn On your Device and search it in My Computer.
that's all, and i hope i do a little help to you!
Mark Anthony Quintana
Dec 09, 2007 | Audio Players & Recorders
SanDisk Sansa  c200 MP3 Player Logo
61 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
