Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Dishwasher dishes are not getting cleaned on the top shelf and the bottom one
  • 6 more comments
  • Badadrtr Dec 31, 2007
    I have a Kenmore Elite dishwasher(ultra quiet) and it appears that the water is not getting to the top rack, as the bottom dishes are fairly clean, BUT the top dishes are clearly not getting cleaned. There is water droplets on the ceiling of the dishwasher, but the dishes don't seem to be wet (on the top), the bottom of the dishwasher is getting water, but I do not know how much, as the dishes are not as clean as they use to be. I cleaned and removed broken glass from the bottom, and thoroughly cleaned all exposed parts that could be removed. There appears to be nothing stuck in any of the parts, but hard water film, which I removed. The dishwasher is about three years old. Any ideas? Could it be the water inlet valve? Thanks
  • Russ696 Jan 08, 2008
    I don't have that exact model but same problem and it was the chopper assembly it went on me twice first time bought a new one only around $16.00 second time cleaned it fixed it put it back worked fine. Its under the filter screen a little cover one screw holds it in good luck .
  • annie71 Jan 19, 2008
    I have the same problem and suspect that it is the jar labels that have gone through the washer. Any way to clear these out or clean the thing before I have to spend $200 to fix it?
  • JosipMaric Jan 21, 2008
    Same problem here, I bought dishwasher a year ago and it was working perfectly all right but a few days ago I notice that I have food particles on my glasses and dishes. Any idea why?
    Thanks
    JM
  • kljean Feb 17, 2008
    Same problem. The glasses (or other items) on the top shelf located in the outer edge and corners are the ones that get a gritty residue (easy to see with clear glasses). Water is going everywhere and the glasses did not have this grime when put inside originally.
  • garryderemer Oct 08, 2008
    Gallses on top rack not getting clean......leaves dishwashing detergent residue
  • fabdou Oct 16, 2008
    I placed on a bowl on the top rack and it did not fill with water.  I also noticed that the arm is not rotating for the top dishes.
  • vimarie Nov 30, 2008
    Ok, the cup gets water in it on the top shelf, but nothing is clean. Next suggestion?
    Novelist:
  • 148 Answers
Basic checks:
is water entering into the machine.
is it hot.
is it being heated during pre-wash
is the soap being dispensed
is the pump running when cycling?
do the arms turn freely?
you mentioned the top and bottom shelves. are there places where the dishes 'are' being cleaned?, or are you meaning that in general they are not being cleaned at all?
most of the above indicators are observable by stopping the wash cycle from time to time in various modes.
to see if water is being pumped at all, put a bowl on the top and bottom shelf, and nothing else. if there is water in it after it cycles then the pump is moving at least some water.
start with these observations and please report back
good luck
mark
Posted on Dec 28, 2007
The top shelf of dishes in my CDA dishwasher isn't coming out clean any more
Look at you manual. How to remove the top spryer to clean it, re-install and presto. (I hope)
Jan 13, 2013 | Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Items on top shelf are not getting clean whereas bottom shelf dishes are clean
I had this problem, and on mine it was because when I pushed the top shelf in , the little sleeve for the spinning nozzle wasn't fitting over the coupling that supplies water to it. Try checking the alignment when you push in the top shelf.
Hope this Helps,
RSMITH972278
P.S. PLEASE RATE ME
Oct 19, 2009 | Dishwashers
My dishwasher will not clean on the top shelf
cheap trick...take a glass and put it on the top rack...right side up run dishwasher for about 4 mins is the glass full with water,no ok than check your drain hose the water is sphion out during wash,,lift it the height of unit..keep me posted
Oct 09, 2009 | Dishwashers
Dishes on top rack don't get clean
The following suggestions will greatly enhance the ability of your dishwasher to clean all of the dishes thoroughly:
1. Rinse all of the food off of the dishes before you put them in the dishwasher.
2. Run the hot water into the sink until it is as hot as it gets before you start the dishwasher.
3. Do not pack the dishes into the dishwasher, just put in a reasonable number without crowding or stacking them on either shelf.
4. Pull the top shelf all the way out to be sure that the water connection at the rear of the top shelf is connected. Sometimes, this connector comes disconnected preventing the water from entering the top spray assembly.
THese things should make a huge difference.
Good luck with this and please rate my answer. Thanks. Joe
Feb 03, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
My Kitchenaid dishwasher not cleaning dishes on top shelf
You need to clean the jets on the machine arm with an old toothbrush etc... then clean out the debris filter on the bottom of the tub near the dryer bar. The calcification in the little jet areas causes this problem. This should help.
Jan 18, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchen Aid dishwasher - top shelf not getting dishes clean
Is the top sprayer clean and not clogged so that the water can flow through? The top may not be functioning properly.
Jan 16, 2009 | KitchenAid Dishwashers
Dishwasher isn't cleaning dishes properly
try running bleach through the system.....pour some in the bottom and in the soap disp and run it
Jan 04, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Top shelf items dirtier after cleaning
After some experience with our own fdw60 with the same problem, we now put all pots and pans on the top rack. Putting them on the bottm appears to stop the clean water rinse reaching the top rack. All washes since have been ok.
Sep 23, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
157 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
