Question about Albatron L17AS 17" Flat Panel LCD Monitor
Drivers I bought a Albatron TFT LCD 17" monitor(second hand) but can't find a driver for it.( model L17ax) I have intel 815 chipset family with a pentium 3 prosessor.
  • Anonymous Jan 25, 2009
    same problem here
    Genius:
  • 1,066 Answers
You shouldnt have to have a driver for a monitor. but, what operating system are you using?
Posted on Mar 11, 2009
Correct Graphics Driver for Windows 7
try a downloadble programme like driver easy or similar.
Apr 24, 2013 | Computers & Internet
Can you tell me where the sodimm slots are located on a Advent 6551 laptop
Advent 6551 Laptop Specification CPU Intel Celeron Dual Core T1600 (1.66GHz) BIOS Phoenix BIOS. Press F2 to enter Chipset Intel GL40 Express Memory 1GB DDR2 PC2-6400 800MHz SODIMM (2 memory slots. Max 4GB) Hard Drive 160GB CD Drive DVD±RW Screen 17" Widescreen TFT (native resolution 1440x900) Video Card Integrated Intel GL40 Express Chipset Family Webcam Built in Sound Card Realtek ALC888 High Definition Audio Network Card Realtek 8139 / 810X (Onboard)
MSI MN54G 802.11bg Wireless G Mini PCI Card (MS-6877) Ports 1x Headphone
1x Line-in
1x Microphone
1x Expresscard slot
1x Card Reader
2x USB 2.0
1x Kensington Lock
1x LAN
1x eSATA *
1x DVI Battery U40-3S3700-B1Y1 (11.1v 3700mAh) Size 27.8 x 287 x 402mm (HxWxD) Weight 3.4kg Colour Black Made By F71IL1 * The eSATA port also doubles up as a 3rd USB port.
Drivers
Your laptop should have been supplied with a Utility CD which contains a copy of the user manual and all the drivers. There is also a copy of the drivers on the laptop itself, you can find it by browsing to the c:\applications\drivers folder. Finally you can download some of them from The Tech Guys website.
The Wireless LAN card uses a Ralink RT72 chipset so if you're struggling to find drivers then the "USB(RT257x/RT2671)" ones on the Ralink site should work - http://www.ralinktech.com/support.php.
Memory Upgrades This laptop has two memory slots. One slot is accessed by removing the cover underneath the laptop (see the "Bottom of Laptop" section below)
Jan 20, 2011 | Computers & Internet
Intel(r) 82801AA AC97 Audio Controller Audio Driver for Windows 98 is needed for the above embedded chipset
Install this driver from Intel Site:
Audio: ADI* Soundmax* Driver for 815 Chipset-Based Boards
Integrated audio driver for Intel desktop boards using AC '97 for Windows 98.
@ http://downloadcenter.intel.com/SearchResult.aspx?lang=eng
Hope it helps.
Aug 05, 2010 | Computers & Internet
Travelmate 4202wlmi displays incorrect setting on startup - 1280 x 768 (default Monitor on mobile Intel 945gm express chipset family) and I cannot change it to 1280 x 800 (Plug and Play Monitor on Mobile...
some display settings are not compatible with some monitors/lcd displays...
check before u make any changes to the display properties....
some changes done forcebly will permanently damage ur monitor beyond repair....
try to install the VGA driver software of the monitor/notebooks may not require andy drivers as OS would have installed it by default...
also dont make any changes to the refresh rates in the display properties as that also may damage ur monitor...
possible use the chekbox that says "Dont display frequency rates that are not compatible with the system"
Dec 21, 2009 | Acer TravelMate 4202WLMi Notebook
How can I change the resolution from 1280 x 800? This is the highest possible according to the display setttings. I have removed the generic pNp monitor. I am running Vista Business. The display adapter is...
Graphics Unable to use the native resolution, such as 1920x1080, 1680x1050 and 1440x900 circuit388.gif Symptom(s):
On some displays, users may be unable to use the native resolution when using Intel® chipset graphics. Resolutions such as 1920x1080, 1680x1050, and 1440x900 are not available in graphics properties.
Cause:
The display's EDID is not read properly when connected to some digital flat panel displays. Display devices describe its capabilities by sending EDID (Extended Display Information Data) to the computer.
Solution:
Intel has released a graphics driver to specifically address this issue; however, there may be side effects to this solution such as longer than normal resume times from standby. This solution will only work with external displays such as DFP displays connected to the computer's VGA port. This driver is not designed to address issues with a notebook's built-in display (Local Flat Panel) or with TV’s connected to the system. This driver is provided as is. Intel has not tested, and does not guarantee, the operation of the driver for this purpose.
For the desktop and Mobile Intel® 945 Express Chipset Families:
If you have a computer that has the Intel® 945G or 945GV Express Chipset or the Mobile Intel® 940GML, 943MGL, 945GM, or 945GMS Express Chipset, click here for drivers that resolve this issue.
For the Intel® 3 Series Express Chipset Families and the Mobile Intel® 965 Express Chipset Family:
If you have a computer that has the Intel® G31, G33, G35, Q33, Q35 Express Chipset or the Mobile Intel® 965 Express Chipset, click here for drivers that resolve this issue.
For the Intel® 4 Series Express Chipset Families:
If you have a computer that has the Intel® G41, G43, or G45 Express Chipset or the Mobile Intel® GL40, GM45, or GS45 Express Chipset, click here for drivers that resolve this issue.
For the desktop Intel® 946 and 965 Express Chipset Families:
If you have a computer that has the Intel® 946GZ, G965, Q963, or Q965 Express Chipset, click here for drivers that resolve this issue.
How to identify your Intel® graphics controller
How to install the graphics driver
I cannot select a larger display mode (resolution, refresh rate, or color settings). How do I resolve this issue?
Error: "The driver being installed is not validated for this computer..."
Operating System:
Windows XP Professional x64 Edition*, Windows Vista 64*, Windows Vista*, Windows Vista 32*, Windows 7*, Windows 7, 32-bit*, Windows 7, 64-bit*, Windows 7 Enterprise, 32-bit version*, Windows 7 Enterprise, 64-bit version*, Windows 7 Home Basic, 32-bit version*, Windows 7 Home Basic, 64-bit version*, Windows 7 Home Premium, 32-bit version*, Windows 7 Home Premium, 64-bit version*, Windows 7 Professional, 32-bit version*, Windows 7 Professional, 64-bit version*, Windows 7 Ultimate, 32-bit version*, Windows 7 Ultimate, 64-bit version*, Windows XP Professional*, Windows XP Home Edition*, Windows XP Tablet PC Edition*, Windows XP Media Center Edition*
This applies to: Intel® 3 Series Chipsets
Intel® 4 Series Chipset
Intel® 82945G Express Chipset
Intel® 82946GZ Graphics Controller
Intel® 82G965 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q963 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q965 Graphics and Memory Controller Hub (GMCH)
Intel® 945 Express Chipset Family
Intel® 946 Express Chipset Family
Intel® G31 Express Chipset
Intel® G33 Express Chipset
Intel® G35 Express Chipset
Intel® G41 Express Chipset
Intel® G43 Express Chipset
Intel® G45 Express Chipset
Intel® Q33 Express Chipset
Intel® Q35 Express Chipset
Intel® Q43 Express Chipset
Intel® Q45 Express Chipset
Mobile Intel® 4 Series Express Chipset Family
Mobile Intel® 945 Express Chipset Family
Mobile Intel® 945GM Express Chipset Family
Dec 06, 2009 | Acer TravelMate 5730-6204 Notebook
Dell E173FPb 17" Resolution?
It depends what kind of machine you're using
Oct 25, 2008 | Dell E173FPb 17" TFT LCD Monitor
Samsung SyncMaster 510N LCD TFT Monitor
Does the monitor remain on does it switch off?
Problem seems to be hardware related ie monitor itself is defective.Try connecting to another known working system.If monitor is defective it could be a power/inverter related issue or panel could be defective.
Please provide feedback and rate the solution.
Samir
Jun 13, 2008 | Samsung SyncMaster 510N (Silver) 15 inch...
Open Questions:
Albatron L17AS 17" Flat Panel LCD Monitor Logo
284 people viewed this question
Top Albatron Computers & Internet Experts
Iqbal Husain
Iqbal Husain
Mark Gough
Are you an Albatron Computer and Internet Expert? Answer questions, earn points and help others
