Question about Toshiba Satellite P35-S611 Notebook
Wi-fi cables which one hooks up where. We took apart to cean cpu heatsink. Putting back together not sure which first white or black. Can you help?
White is main and black is aux
Posted on Dec 30, 2007
White wire connects to main connector on wifi board, black to aux connector on wifi board
Posted on Feb 02, 2008
When the screen is white instead of taking out the battery and putting it back in can I do something else?
Not sure why your removing the battery?
If you are shuting down the machine. Close all running programs before shuting down otherwise the machine has to close each program in turn before thr machine can shut down all together. Depending on how the settings are for the power button. The shut down process can be forced by holding down the power button until the machine has shut down. Black screen instead of white. Hope this helps answer your question.
Regards
Bob from OZ
Jun 15, 2015 | ProntoTec ntoTec 7 Inch Android Tablet Pc,...
I have T-Mobile 4g galaxy avant android phone. I do not have coverage n my ares 4 the Internet. Cam I hook WI-FI up 2 my desk top and accessories the inn tenet via my home wi-fi
You can get WI-FI anywhere WI-FI is available with a smart phone.
But if you only have a modem at home and an ethernet cable from the modem to your computer to get internet, then you may not have WI-FI at home.
You'll need to get a wireless router to have WI-FI at home.
Once you do that, you can continue to have your desktop hooked up by the ethernet cable, but you can also install a WI-FI adapter card in your desktop. It will have an antenna on the back of your computer and then you can set it up anywhere in your house and have internet without an ethernet cable.
Mar 16, 2015 | T-Mobile Cell Phones
When i going to use camara display "Error camara not available" restart phone and tried so many times but not resolve please help me what can i do...
I also used to have an xperia u and it also produced the same problem. First i tried to simply reinstall the whole operation system on it, this you can do through the sony update service software via your pc. If this does not help, (and this helped me only once) next time i simply took apart the phone, and tried to clean it checked the contacts within it (all the copper parts). After putting the device back together, my camera was working again. For the taking apart process you will need special tiny screw drivers.
Mar 05, 2014 | Sony Xperia U ST25I Android OS v2.3...
Shakey screen and lines across it after 4s screen replaced
Most likely you just got a bad part. As long as you didn't apply too much pressure when putting the screen in, then it's probably just a bad part.
Nov 24, 2013 | Apple iPhone 4S
Overheating
You will probably need to replace the CPU fan down the road and remove the old thermal grease between the heatsink and the processor ic for new compound, will make all the difference.
Sep 24, 2012 | Toshiba Refurbished SATELLITE CEL600 64M...
How do you get wifie on black and white
First, make sure your Nintendo DS has internet through the Nintendo Wi-Fi Connection, then go into any Pokemon center and use the global terminal to engage in battles or trades with random strangers over Wi-Fi.
Basically, so long as you are in a wireless hotspot, i.e. McDonald's or a Library, you should be able to get Wi-Fi on your Pokemon Black/White.
Mar 08, 2011 | Pokemon Zekrom Pokemon Black and White...
My ipad and my iphone wont connect to the wireless,
The password that my Iphone required was the 20 digit key located on the sticker as WPA-PSK. Hope this helps someone!
Dec 31, 2010 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Loud fan
Check that the fan is not hitting any wires in side the case.
If not you may have disoriented the fins while cleaning them. Make sure the fins are not hitting the fan body.
If the fan wasn't installed property the CPU temprature should rise fast and your computer might automatically shut down to prevent damage to the CPU. If that is the case, try reinstalling it making sure it's attached well to the CPU. And remember to add some thermal compound to help the heatsink transfer heat.
If none have solved your problem you can buy a new fan for your CPU at any computer store. Make sure it's compatable with your CPU socket type.
I have lately purchased this fan for my quad core CPU and it's 100% silent. You can run it without a fan also. It's a really huge heatsink. I recommend it.
http://www.coolermaster.com/products/product.php?act=detail&id=4509
Oct 27, 2008 | Sony VAIO PCV-RX753 PC Desktop
HP 7410 All-in-One
The fix that Maggix sugested worked on my machine. Problem is apparently related to the Wi-Fi card. I unplugged the connector and all is good.
To access the connector remove the rear plastic access panel. To remove take out the two chrome looking screws. Then slide the plastic panel up to release the clips, then pull it out. You may have to play with it a little but it will come off.
The connector is at the very top of the circuit board located at the far LH side of the rear access area. It is the second (2nd) one from the back. It is white and has 5-6 colored wires that then go into a cable loom with heat shrink on the transition. Unplug the connector with pointed nose pliers and tie-wrap it back out of the way so that it cannot accidentilly short to anything.
Now, plug in the printer and see if you get pas the HP splash screen and the scrolling timing bar.
Good luck and thanks to Maggix for the great solution.
Jun 05, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Ecofan only turns slowly
These fans can be rebuilt! Like many others, our fan died after being placed in the center of the stove top. I took the two halves of the fan body apart, and scraped the heat sink compound off either side of the power plate. I then applied CPU heat sink compound that can be found at any computer or electronics store liberally to either side, and put it back together. The fan spins like new, spread the word!
Nov 28, 2007 | Cfm 802 Ecofan Table
Toshiba Satellite P35-S611 Notebook Logo
447 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
