Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Thermostat We also have a trio with the freezer on the bottom. The frezer is not cooling and temp at 12 the top section is cooling but at 57 we tried to reset but it will not hold it keeps going back to the above temp. Is this also the same issue?
  • tcjm125 Dec 31, 2007
    Thanks this was helpful
Maybe the timer, cheap fix!
Posted on Dec 27, 2007
Fridge not cooling .kenmore trio frezer works fine
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Oct 06, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Model 795 77304600 bottom freezer purchased dec 06
WHAT IS WRONG WITH YOUR FREEZER?
small_3_29.jpg For a detailed Freezer illustration, click below.
Chest
redarrow.gif Upright
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
It doesn't work at all
It's not cooling
It cools poorly or it's all iced up
It's noisy
It doesn't cycle off
Hope this may help you;
Regards,
VOTIT
Sep 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
I am getting an ER FF message on my refigerator in the section where it normally gives you the fridge and freezer temp.
f =heat exchang you have to check the condensor fan and evaporator fan , clean the condensor coil . if the frost build up to block air way. need to check heat element and defrost thermostat. good lock
Jan 10, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Frost buildup at back of bottom freezer department. Refrigerator should be frost free. Freezing impaired.
could be anumber of things happing, is the freezer fan spinning? if not ice will accumulate( also hamper cooling in the refrig section). perhaps a defrost issue, a bad heater or defrost thermostat could also cause, this/ may even just be the door being left open for extendedperiods of time( ie.. overnight, or hte gasket not sealing correctly) leading to a frost build up on rear panel
Jan 27, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
The freezer works but the refigerator section does not. When you turn the temp switch for the refrigerator it will turn off the freezer also.
dont tuch the thermostat put it in normal setting!
now, check if your fan in the frezer working, if it is working che3ck the thermostat unit and heater in the frezer unit also need to see if the frosting is eaven all over in the frezer side..
contact me at www.911servicetoday.com
Dec 30, 2009 | Refrigerators
Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Nov 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
Sep 28, 2008 | LG LRTC19314ST Top Freezer Refrigerator
Placing a refrigerator in the garage
IF YOUR GARAGE TEMP GOES BELOW 35 THE REF MAY NOT WORK WELL BECAUSE MOST REF HAVE THE THERMOSTAT AS THE REF CONTROL. THE TEMP IN THE BOX IS SENSED AT THAT POINT AND SHUTS OFF, THE REF SEEM TO WORK BUT THE FREEZER WILL WARM UP.
IF YOU WANT TO USE A REF IN THE GARAGE, FIND ONE THAT HAS THE THERMOSTAT CONTROL AS THE FREZER CONTROL. LOOK AT THE CONTROLS, THE ONE THAT HAS AN OFF POSITION IS THE CONTROL THAT IS THE THERMOSTAT. SO, THE FREZER CONTROL SHOULD SAY "OFF" SOME NEWER REF WITH FULL ELECTROINIC CONTROLS MAY WORK AS THEY HAVE INDIVIDUAL SENSORS FOR BOTH THE REF AND FREEZER SECTIONS.
Jul 14, 2008 | Whirlpool EL7ATRR Refrigerator
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
76 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
