Question about RCA P61939 61" Rear Projection Television
Set channel to video 1 and or video 2
How do I manually set the tv channel to video 1 and or video 2 in order to play a dvd. Remotes does not work on my tv
  • jevon Jan 14, 2008
    How do I manually set it to video 1 or 2. MY REMOTE DOES NOT WORK. CAN I GO THRU THE MENU BOTTOM ON THE TV?
Dose anyone know where i can buy a new screen for this TV?
Posted on Jan 14, 2008
  • tvnut2 Jan 14, 2008
    use Video 1 that is what kids have it set to.
How do I get channels on my Emerson tv with dvd? I have tried everything I could think of and I only get channel 23 and that is kinda grainy looking.
I don't understand the question. Why do you need channel settings for the DVD? Are you asking what channel to play the DVD on? It won't be a TV channel, it will be a separate video input source setting, usually found on the remote. The TV may show Video 1 or HDMI for the source in order to watch an external source like DVD.
Sep 27, 2014 | Emerson Televison & Video
What channel or setting is used on the TV to play a DVD?
Hi, Channel 3 or 4 might work for older TVs. Most new HDTV's have a mode setting in the menu. (Video 1 or 2 or 3) or (Component 1 or 2). On your remote you may have DVD button. Try all these suggestions, 1 of these will work. You can play with the remote too. Good luck.
Jun 13, 2011 | LG 42LB2R 42 in. LCD HDTV
I have a 19 inch toshiba tv 19A21 but no remote for it. I'm trying to hook up a dvd player to it to play through the tv. All the cables are set up correctly, but I can't find the input channel on the tv...
Most analog tv,u just reqiure pushing the tv manual button channel up a few times,tv will go into video modes like 1 or 2 for play video devices.If this doen't work,try website like to buy an original remote.
Mar 21, 2011 | Toshiba 19A21 19" TV
What channel do I set my TV to in order to play a DVDdisc?
Assuming your DVD player is properly connected to the video and audio inputs of the TV, you should be able to press the "input select" button on the remote and toggle between TV and DVD. A copy of your manual is here:
Oct 14, 2009 | Emerson CR202EM9 TV
Stuck in vedeo mode wont play movies dvd or vhs.dont have a remote can i reset or reprogram the tv to play movies or at least get back to regular channels
Tries this go to the tv set itself presss the channels up or down u will get out of the video modes line1 or line 2 u will get out to regular tv signal.If u need a new axact remote go to this website.1-800-Remotes Factory original.
Aug 24, 2009 | Zenith B27A11Z 27" TV
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
Swiching from tv to playing video
sorry. you cannot switch to video mode without the remotes
Feb 21, 2008 | Disney Princess MCP DVD2050P DVD Player
Can't re patch tv with set top box to watch tv
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
Jan 08, 2008 | Televison & Video
Cannot view channels higher than 10 and cannot get DVD to come on
Dear althea, I cannot help you with the first problem, but as for the second, "DVD does not come On" and "Do not understand Video 1, 2, & 3 settings." it is very simple. YourTV has the sockets at the front Marked Video 1, Audio L and audio R, The y are in three colors - Yellow for video, red for audio right and White for Audio Left. Similarly, you have 2 such sets of 3 sockets - they are Video 2 and Video 3. This allows your TV to be connectod to three different Video sources - maybe a VCR, A Video game, and a DVD player. To view the pictures generated by your DVD Player, all you gotts do is connect the supplied AV cord from the rear of the DVD player to the front three sockets in the proper order - Video from DVD to Video of TV, Audio L & R from DVD player to Audio L & R of TV. Now press Video on the TVs remote. Press repeatedly till you get Video 1 displayed on the screen. Then, if you now play your DVD player - make sure there is a disc in it - you will be able to view the picture / movie. Good Luck
Mar 05, 2007 | Sony KV-32XBR100 32" TV
External DVD won't play - no manual available anywhere
The tv has a set of imputs for audio and video ,there is a posibility your dvd is not working right,you can also try a vcr by using the rca audio and video outputs of the vcr to the rca audio and video imputs of the tv,that will tell you if the dvd is not working ,the tv should have a switch selector for video and antena or have a channel below 1 called aux.
Oct 02, 2006 | RCA T13208 13 in. TV/VCR Combo
RCA P61939 61" Rear Projection Television Logo
110 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
