Question about Vornado EH1-0020-01 Compact Heater
Varnado EH1-020 VH2 blows cold air or wont stay on
Used only mildly for one winter. It only blows cool air when in the High fan mode, and when in the auto mode it only cycles on and off a few seconds at a time, but the air is hot. At $70.00, I should be able to get more than just a season out of this turkey. Any ideas?
  • 1 more comment
  • nozulch Nov 12, 2008
    My Vornado EH1-0005 heater has quit completley. There ia a two black wire welded together connected to nothing. Could these wires connect somewhere? I see no other problem. thank you.
  • Anonymous Nov 21, 2008
    I have the same exact problem, on high blows cold air in on auto warm air blows for a couple seconds.  help!
  • Too Cheap Dec 03, 2008
    I have the same fan-- got it last January at Linens N Things. Used it a dozen times at most. Blows cold air now!! I should have used it in the summer.
  • 80 Answers
THERE IS A LIMIT SWITCH THAT REGULATES HOW LONG THE HEAT STAYS ON SOUNDS LIKE THIS LIMIT SWITCH WHENT BAD MOST ITEMS LIKE THIS HAVE A FACTORY WARRANTY THAT COVERS THIS ISSUE MY RECCOMENDATION IS TO TAKE IT BACK TO WARE YOU BOUGHT IT OR IF YOU LIKE TAKE IT APART WHILE IT IS UNPLUGGED AND LOOK FOR A LITTLE DEVICE THAT BREAKS ONE WIRE TO YOUR HEATER ELEMENT AND TRY TO MATCH IT UP AND REPLACE IT.
Posted on Dec 27, 2007
What is kicking off to make my furnace go through its cycle and then blow cold air and wont shut on my Ruud gas furnace
it could be flame sensor or high limit switch how long do burners run does the fan stay on while this occurs
Dec 15, 2016 | Ruud Heating & Cooling
Why did SPT Portable Air Conditioner stopped blowing cold air?
Unit needs to be taken apart and washed out , also check to see if motor turns freely by hand , clean base of unit fans / blowers and drain ports / channels . Check outdoor motor to see if bearings are tight or fan overheats and cuts off if so replace outdoor motor .
Oct 04, 2014 | Heating & Cooling
My mistral reverse cycle mss25ss model does not work at all in heat mode. what would be broken?
firstly is the air comming from the outdoor unit cold or warm? if it is cold then the 3way valve is working and it has changed to heating. If it stays warm then it is still in cooling mode. The indoor fan wont come on until the coil temp gets warm enough, ( so it doesnt blow cold air on you straight up). If it is changing into heat mode then the larger of the pipes connected to the outdoor unit should get warm/ hot. If this is not happening then the unit is either out of gas or the compressor is on hollidays and wont come back to work.
May 22, 2012 | Heating & Cooling
I know I should reverse the direction of the ceiling fan for summer/winter. Which way is which?
you want the fan to turn anti clock ways in winter as this sucks the cold air upwards pushing the hot air from the roof downwards. and clock wise in summer blowing cool air downwards to cool you
take care
please remember to rate this repair.
Aug 03, 2010 | Craftmade International Craftmade...
Indoor fan blowing cold air when on heating
The indoor fan will continue to run. When heat pump goes into defrost the outdoor fan stops, the reversing valve switches and the unit is basically working in the cooling mode. In order for you not to feel a blast of cold air in the winter the electric strip heat also comes on so the indoor fan must run while the strip heaters are on.
Jun 03, 2010 | Heating & Cooling
No heat jaguar 88 xj6 fan wont turn on cool air out the defrost vent
I have the similar problem with both my Jaguars, one is a 1988 Jaguar XJS, the other is a 1987 Jaguar XJ6, both blow COLD air out some vents while it blows warm air for heat. I heard it had something to do with the cold air blowing as a dehumidifier, I don't know if this is true, but it is really annoying to have both cold and warm air blowing when I need heat in these cold Canadian winters. If you find out please drop this website a note and let us know how you solved it. thanks.
Nov 12, 2009 | 1988 Jaguar XJ6
No cold air
if unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
Jun 09, 2008 | Frigidaire FAH085N1T Air Conditioner
Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Jun 07, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Vornado EH1-0020-01 Compact Heater Logo
416 people viewed this question
Top Vornado Heating & Cooling Experts
Bill Long
ray gallant
JonSnell Electronic
JonSnell Electronic
Are you a Vornado Heating and Cooling Expert? Answer questions, earn points and help others
