I have a 1990 honda accord lx and the green s light comes on intermeittenly and then i have to disconnect the battery so i can drive it automatically. I heard there could be 15 reasons why this is happening i want to know what are the 15 reasons before i spend the money to buy a new tranny. thanks
Hi, you have to have the battery connected while the engine is running as the alternator is sending a trickle charge back to the battery to keep it charged up. When the alternator does not find the battery then the circuit is broken as you disconnected the connection .
Scan the computer for the trouble code that the check engine light may have registered. Maybe that will point to the problem. What is the green s light for?
The 1990-1993 accord timing marks are located in the space between the engine and transmission. There is a rectangular rubber plug, at the top, front of the transmission housing, that pulls out and the timing marks are visible(with a timing light) through that access hole.
On my 1990 Accord Lx I have the same problem. My floor pan has a hole in it some where and my carpet gets wet which gets my computer wet causeing the "S" light to flash and then when my tranny shifts it skips 2nd gear.
No, you don't have to pull the engine. Many of those problems are fixed by removing the wheel, and the plastic inner fender. It's probably a crank seal, or a power steering hose. PS- You mean the passenger side... don't you?
A green flashing "S" is similar to a check engine light. It is telling you that something in or on your transmission is not functioning correctly, such as the speed sensor or shift control solenoids. If it starts flashing and the speedometer stops working or the transmission shifts weird, take it to a mechanic.
