Question about Tomtom GO 910 GPS Receiver
TomTom GO 910 - screensaver?
Hi, I have a new GO 910 in front of me. I can't disable the TomTom advertisement coming up every 2 minutes on the screen. I acts like a screensaver because it starts by itself when the receiver is idle and can be interrupted by touching the screen. I tried to switch the "screensaver" off but couldn't find anything that does that in the menu. Could you please help me?
Bayar
  • Anonymous Dec 25, 2008
    can i fix this w/o connecting the unit to the computer?
    President:
  • 4,402 Answers
Try this it does take a while to do.
STEP 1
Connect your TomTom to your computerTomTom GO 910 - screensaver? - 1.gif via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the backup1.gif you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Posted on Jan 18, 2008
Have TomTom 910 Having Problems Charging it.
The 910 satnav/mounting interface is dreadful- it is the cause of half the problems on this site! You can order the battery on the net. Google VF5 or Samsung ICR18650-24. To replace, strip off rubber strips. You need a mini star screwdriver, carefully pull unit out of cover gently levering at the side. Carefully observe plastic carry through which acts as button on the front and base clip underneath- this must be reinserted correctly. It is a vital part of the structure- observe it carefully! Remove upper small PCB and large PCB after removing 2 electrical connectors. Battery located under PCB. Dispense with rubber mounting. Reassemble carefully battery holder (loosely until you have placed previous plastic carry through). Tighten battery holder to hold plastic strip which must be located over mounting bracket, carefully reinsert both electrical connectors (different sizes), reattach large PCB then small one, then screw back in cover. It is likely you will then be stuck on initial screen with unit not booting correctly. You must then do software resets (opened paperclip inserted into invisible hole next to connecting strip at back). It is likely that you will have to connect to Tom Tom HOME to do this. I failed here as the darn unit will not connect to my computer.
An awful piece of equipment- I have gone Garmin!
Mar 18, 2009 | Tomtom GO 910 GPS Receiver
Safety lock
Yes, I too have experienced a problem with locking up when I take my TomTom 910 out of the dock after being connected to my computer. I also took my TomTom back to shop and was shown how to do a Hard Re-set on it. Firstly, you have to locate the reset button (which I see you have. Why it is hidden away in such an awkward position I don't know. I carry a pin/paperclip around with me for this purpose!) Press the reset button once until the TomTom screen switches off. Then with the TomTom off press AND HOLD DOWN the On button on top of your TomTom. Keep holding as white computer script appears on the screen. Carry on holding down until the remainder of the script appears to almost fill up the screen with script info and then this stops. Then release the On button and the TomTom icon will appear. After 2 to 3 minutes the TomTom should switch to show the current location map and look for satellites. Locking on to satellites can then take up to 15 minutes by the way.
Hope this helps.
Good Luck!!!
neo
Feb 27, 2009 | Tomtom GO 910 GPS Receiver
Tomtom 910 reset not making a difference
you have to hold the reset for at least 30 seconds. Get up free updates and back up your device
Nov 24, 2008 | Tomtom GO 910 GPS Receiver
Tomtom 910 dark screen
If the LCD backlight is gone theres no choice but to replace the whole screen ( OR it could be the LCD lamp driver circuit on the circuit board ) . It's not economical to purchase a new screen but it is possible to purchase a defunct 910 , typicaly off ebay and use the screen from it . ( ensure you are buying a tomtom with a good intact screen ) . Changing the screen is tricky and fiddly but someone with general electronics knowledge should'nt find it difficult. You also need the special "star" drivers for the screws ( sometimes known as ' torxs ' ). If you are inexperienced with this sort of work then its best not to attempt it. There are companies advertising that can do this type of work for you and especialy in UK......... Good luck.
Oct 29, 2008 | Tomtom GO 910 GPS Receiver
Mobile phone
You have to put the phone in discovery mode. To do this go to options or find something that says discovery mode and it should put it in discovery mode for about 3 minutes.
Feb 08, 2008 | Tomtom GO 910 GPS Receiver
Faulty tomtom go 910
have to send it in to get battery replaced.
Jan 20, 2008 | Tomtom GO 910 GPS Receiver
Tom Tom one White screening
If it is within warranty return it or vist contact tomtom
http://www.tomtom.com/support/support.php?ID=2
Dec 02, 2007 | Tomtom GO 910 GPS Receiver
TomTom 910 charger question
Yes, you can.
I presume the charger has an USB connector.
5v and 2A are the correct figures for a Go910.
Aug 24, 2007 | Tomtom GO 910 GPS Receiver
Tom tom 910 map no found bloplem
i knew tomtom 910 the best gps . so that why i buy it , but some time has bloplem i need help . if any want gps i recomender that buy the tom tom 910 is work for that money cause i got 1 year and now i bether and knew many new location .
Jun 19, 2007 | Tomtom GO 910 GPS Receiver
Tomtom GO 910 GPS Receiver Logo
1,070 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
