Question about GE Washing Machines
GE Profile Washer
Hello, I have a WPRB8050d0CC Serial # VF171198G Washer.
It had its transmission replaced under warrenty one year ago.
It agitates but does not spin. It will fill with water but doesnt seem to do that correctly unless its on Super (size) load.
I just watched it fill and agitate for 20 mins then drained and at the point where I believe it would spin it just shut off.
Now I have noticed it will light up both the soak and wash lights .
Thank you
  • 5911 Answers
SOURCE: kenmore 70 series
Okay...I'm a little confused on your symptoms. You initially said it fills, but doesn't agitate or spin, but drains.
Then, you finished with the washer filling, no agitate or spin, but now doesn't drain.
Which one is it?
The symptoms you describe are usually associated with the following:
1. Fills, may or may not agitate, won't spin or drain - lid switch.
2. Fills, may or may not agitate, won't spin, but still drains - motor coupling.
3. Fills, may or may not agitate, won't spin or spins slow - gear case.
4. Fills, agitates, spins, but does not drain – water pump.
NOTE: These are the more common failure items with these symptoms.
Double check the lid switch by opening and closing the lid. You should hear a clicking noise to indicate the switch is working. The switch is located under the top panel along the wash tub rim on the right-hand side. If not, check to make sure the lid strike (small plastic piece on the lid itself) is in place. This activates the lid switch when the lid is closed. Also, check the mounting screws along the rim (there are two of them) to see if they are tight.
If the motor coupling were bad, the washer would still drain, but there would be a rattling sound as the washer tries to spin or agitate.
If you need replacement parts, go to and type in your model number in the "Search by Model Number" window. The lid switch can be found under the "Top and Cabinet" heading as item number 11 (part #3949238). Instructions on how to replace are located at the following link:
If you wish to replace the motor coupling, the part can be found under the “Brake/Clutch/Gearcase/Motor/Pump” heading as item number 13 (part #285753A). If you need instructions on how to replace, just follow this link:
Now, there’s a couple of ways to drain the washer. If it’s a simple lid switch problem, you don’t need to drain the washer to replace the switch. With a broken switch repaired, the washer will run and drain by itself. However, if you wish to drain the tub you can use a shop vac to pull a vacuum on the drain hose. This may take a few times depending on the size of the shop vac. These wash tubs typically have about a 35 gallon capacity. If you do not own a shop vac, you can by-pass the lid switch by jumpering the two BLACK wires at the lid switch connector that is connected to the console. CAUTION: Make sure you UNPLUG the washer before jumpering, then plug back in.
I hope this information is helpful to you. If I’m wrong about the symptoms, please post back and update me on what the washer is or is not doing, so I can assist you further.
Posted on May 15, 2008
  • 1543 Answers
SOURCE: GE Profile Prodigy Machine not agitating
If the motor runs when it is suppose to be agitating, but the agitator does not move, pull the agitator straight up and out of the machine. Sometimes this is difficult, but you can slip a belt or similar object under the agitator, attach it to a broom handle and yank up on it. Now take the bolt out of the agitator drive collar and remove it. If you can not turn the splined transmission shaft with your fingers you are in luck and should be able to just replace the can shaped agitator drive spline. (part number WH49X10042 ) If you can turn that splined shaft with your fingers you are looking at a new transmission.
Posted on Nov 11, 2008
  • 90 Answers
SOURCE: Whirpool lsq9244eqo fills and drains but does not spin or agitate
It sounds like the agitator gripping teeth are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, pull the cap off and check the plastice teeth and four plastic hooks that grab the teeth. If they are worn out, then you will have to replace the agitator. To replace it, you will see a nut that is between the circlular teeth. Unscrew the nut and pull the agitator up hard.
Posted on Jan 19, 2009
  • 640 Answers
SOURCE: Kenmore 80 series top load washing machine won't agitate or spin
defective motor coupling,,replace..onthejob
Posted on Jan 24, 2009
SOURCE: GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Posted on Apr 15, 2009
Washer drains ok won't agitiate tub feels wobbly replaced motor 2 years ago when it wouldnt spin or agitate
There must be some problem with the transmission... You might have to have a repairman look at it.
May 25, 2014 | GE WBSR3140DW Top Load Washer
GE profile washer not spinning model number wnsr3120w0ww
Do you hear the motor going? If you do, I am sorry to say it is your transmission on your washer. The website link below will confirm this if you hear a motor going. If you don't hear a motor then it could be your motor. It is very expensive to replace, I am sorry to say. The expense of the transmission is $260 plus or minus with labor.
Dec 06, 2009 | GE Washing Machines
My GE washer won't spin or agitate
check the motor capacitor if your motor doesn't turn when powered, otherwise the "wig-wag"coil could be faulty,these coils shift your transmission for different cycles
Aug 23, 2009 | GE Profile WPSR3100W
Ge profile washer WPSR3100W1WW won't agitate
I see this pretty regular. You have a bad transmission. This is very common with the older GE's. To replace the transmission will run around $340 / $400. Not sure about your area. Just be glad you got this much use out of it, you are one of the very few that have. From 1998 till 2007 I owned my on repair company where I did GE's warranty work in my area for them. During that time period. When I found a GE washer under warranty doing what you are describing. GE would warranty the whole machine. They would have me destroy the machine after I would deliver the customer a band new one. GE knows they had a bad transmission and it cost them a lot of money. It was cheaper for them to replace the washer than have me repair it. The transmission list price was $298.00 back then. A word of advice, when you replace it. Buy a Whirlpool, Kenmore, Maytag. These brands hold up the best. I have the least service calls for Whirlpool and Kenmore. Both are made by the same people. Kenmore is made for Sears. Good Luck.
Please rate this solution if helpful. Thanks
Aug 21, 2009 | GE Profile WPSR3100W
Washer does not agitate. Will spin and drain.
bad dogs pull off center cap remove bolt carefully lift off dogs are two pieces that catch to agitate they are minimal cost and are easy to replace they wear out especially with heavy loads!!!Best of Luck to You!!
Jun 28, 2009 | GE Profile WPRE6100G Top Load Washer
Bearing is shot
Probley not but check manuel. Transmission bearing did have longer warrenty 3 to 5 year ago.So have alok in maneul.
Mar 10, 2009 | GE WJSR2070B Top Load Washer
GE Profile washer
suspect gearcase ask for estimate first..could be more than new washer
Jul 09, 2008 | Washing Machines
GE Profile Harmony 4.0 -Broken Clutch Coupling
if your under warrenty always call for service repairing it yourself voids your warrenty
Jan 15, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Washing Machines Logo
81 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
