Question about ViewSonic VX924 19" LCD Monitor
924x green led flashes slowly,no picture on screen.Shows no input note on screen when vga cable unpluged {normal} back lights come on briefly untill flashing led starts.Led stedy green when no video input hooked up.mydemise04@yahoo.com
  • osie2007 Jan 04, 2008
    I had mine fixed,it was the capacitor on the power board,30.00 is all it cost to repair,look on ebay for for the name It services,there are local here so i just droped it off and two days later it was done,they specialize in veiwsonic monitiors of another type,but do other repairs as well,hope this helps you all out.
  • 3 Answers
Having the same exact problem...it started with the green led power light flickering and it would take a long time to come up and then it got progressively worse...now the led light flickers red, yellow, green and the screen displays white lines randomly as the led light flickers...seriously doubt that the monitor is repairable....paid $500+ bucks for this sucker and have only had it for 1.5 years...have 3 CRT monitors that only cost $100 bucks from the mid 90's that are all still running strong (none are ViewSonic monitors), so needless to say we are very very disappointed in the QUALITY of ViewSonic Products. Our Company Will Avoid ViewSonic Porducts at all Costs in the Future!
Posted on Jan 03, 2008
  • digitaldawg Jan 03, 2008
    We Checked our power source/brick and it is fine....the monitor appears to have other issues besides the power source and it is ready for the scrap pile....We recommend that you Don't Buy A View Sonic as they are over priced for the Quality that they offer and there are many other brands out there that offer better quality and better support.
It sounds to me like your losing the high voltage on the inverter board after the board warms up.Could be the transformer or a capacitor on the inverter brd.
Posted on Dec 29, 2007
    Scholar:
  • 42 Answers
This is NOT Viewsonic's fault, it's one of their component suppliers problems. They have a good design, but the capacitors are failing prematurely. See below for a solution.
This is the same problem with my 4 VG800 Monitors, you should be able to find the correct capacitor on your monitors by following the same procedure, I'm sure the boards are similar. Just get the correct value capacitor and try it in parallel with the initial filter capacitors right after the DC power in.
Alright, I had 4 VG800 monitors with the exact same problem. The front led is blinky OR constant reddish/orangish OR picture is white with colored vertical lines OR no picture with whistling from the back of the monitor and backlights illuminated. All problems have the same solution. You need to disassemble the monitor (2 screws on the back, remove lower front button panel, remove 2 screws holding panel in and remove speakers, then remove panel and unplug speakers. Now remove lots of tape and screws from the cover in the center of the monitor). Now that you've exposed the amplifier board and the VGA to LVDS board, you want to look for the pair of 25V 100microfarad capacitors that are nearby the DC power in (they are right next to the black "100" inductor). Desolder the capacitor farthest from the DC jack and replace with an electrolytic with the same specifications. If you want to check that this is the correct solution please put the new capacitor (WATCH THE POLARITY) in parallel with the capacitor there want watch the front panel indicator go green and the monitor work properly.
I'll be posting and Instructable entry in the next few days on the process, watch for the username Waterppk on the website www.instructables.com
-Chris
Posted on Mar 18, 2008
2 Suggested Answers
  • 286 Answers
SOURCE: veiwsonic 924x
This is a generic symptom that could happen to any LCD monitor.
The following is a generic answer applicable to most.
The most possible causes are bad capacitors or a bad semi-conductor.
Open the unit and check to see if any of the capacitors in the power supply or other boards look domed or vented on the top.
Replace any capacitors accordingly. Use the same value capacitors. Most often, 1000uF 16V or 25V, 470uF at 16 or 25V, 220uF at 16V or 25V.
If this doesn’t solve the problem, try checking the surface-mount transistors on the inverter board that run the lights. Some times these transistors go bad and can cause the power to cycle up and down. Check the area for any cracked or overheated ceramic or mylar capacitors.
Don’t forget to check for caps on the main board. Some times these boards are overly simple and only have a couple of caps, but other times they are teaming with them.
Posted on Feb 14, 2008
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Jun 04, 2016 | Sharp Aquos Televison & Video
Aspire 5110
So does it sound like your laptop is running and booted up all the way except the screen is blank? if so try the steps below:
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 08, 2012 | Computers & Internet
RCA L37WD12 out of control
Ur Tuner board have problems,just not dead yet.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.The Tuner board main IC have intermitten short,that why take out A/C power input work for awhile,and than back to the same problems.
Apr 22, 2010 | RCA L37WD12 37 in. LCD HDTV
Samsung Sync Master 914 has no picture. When power supply is only in, green light flashes slowly. When both power and vga are in, green light flashes more quickly. I hear a faint clicking sound coming...
I would check the caps with ohm meter. Make sure they all show increasing resistance. Caps can be bad without looking bad. Check output voltage on the power board, should be around 12V. If all that checks out then I'd look next at the backlight bulb. I'v repaired many monitors and the problem was almost always overheated caps on the power board. Post back and let me know.
Dec 03, 2009 | Computers & Internet
Monitor led is green when vga cable cunect but on diesplay on monitor?
if the screen is only green then unplug and replug the cable but this time hold it on to the connection and jiggle it until you see the screen's color back to normal, if not then there might be a problem with the monitor's congifuration on the lcd screen or even in the system under the drivers or the wire is busted
I’m happy to help further over the phone at https://www.6ya.com/expert/alex_32392698f23d119d
Aug 10, 2009 | Computers & Internet
Monitor Not Showing A Picture. Light flashes Yellow and Green.
use the onboard graphics instead of a seperate graphics card (if installed) to test the screen.if it still doesn't work then unplug your monitor from the mains supply and plug in again to reset it. i doubt it's your monitor that is the problem though. but look on the back of your pc for another connection for your screen. the onboard graphics connection is normally vertical near your ethernet port and mouse and keyboard inputs.
please rate me and give me a fixya! if it helped.
Apr 05, 2009 | Acer AL1713M 17" LCD Monitor
Lcd monitor power light flashing with no img. seems 2 be frozen
The display is in safe mode and you will need to reset the display to get the display out of the safe mode. There are 2 different model revisions. Please choose the method that will match your revision. Depending on the revision of the monitor, one of the following 2 methods should reset it to a normal state. This reset generally requires both hands and it is sometimes easier with another person.
If the serial number begins with an A and/or your power button on the far right (5th button from left):
Method #1
1. Unplug the VGA cable.
2. Remove the power cable from the back of the monitor.
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 3 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
5. If the procedure worked, the green light will go to amber and you should see a "No Signal" message on the screen for a few seconds.
Method #2
4. Keep holding the buttons until the 4th green LED blink; then, let go. The green light should be steady when you release the buttons.
If the serial number begins with a B and/or your power button is in the middle (3rd button from left):
Method #1
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see attached picture) and while continuing to hold the buttons, plug the power cable back in.4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
Method #2
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
If you have tried the reset a few times and it does not solve your issue, please Ask a Question to submit a request through the system or call 1-866-752-6271 Option 1 to contact technical support.
Mar 02, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
TV does not turn on/red led flashes 7 times in front
this is common issue with this model and through your troubleshooting is tied to y main board. blinking led on logic main in normal operation. when replacing y main always good idea to replace y upper and lowe buffer boards as they complete a circuit and sometimes replacing one without other could cause additional failure on remaining boards
Aug 10, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Veiwsonic 924x
Dec 27, 2007 | ViewSonic VX924 19" LCD Monitor
ViewSonic VX924 19" LCD Monitor Logo
941 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
