Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
4th of July on 12/26
The element on our Kenmore oven lit up like a sparkler and continued even after it was turned off. Only when it was unplugged did it stop sparking.
  • wally2323 Dec 06, 2008
    I have the same problem. After shutting off the controls, burner will heat up to high and shut back off continuously until I unplug the oven. Do I need to buy a new element??
I had the same problem and it would not stop burning until I switched off the circuit breaker.
Posted on Dec 04, 2008
  • 447 Answers
Yes the element failed and they will arc when they do that.Ive actually seen people hose them down with a fire extinguisher only to have it still arc. Bake elements are inexpensive and very easy to install.
Posted on Dec 27, 2007
Kenmore electric oven will not bake
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric range oven baking element does not go on eveything else works
The bake element
Jan 30, 2014 | Kenmore Ovens
Bake and Broil elements quit working
Could be both elements, control board cause usually both elements don't go out simutaneously, or even just your breaker. check for continuity on elements unplugged of course.... and 220v at plug. also check for burnt wires to elements. some models have a cavity high-limit switch located on back for safety. check for continuity on this if you have such...hope this helps
Sep 05, 2012 | Ovens
F2 error display on kenmore oven model 911.47869. Bottom element not working but has continuity on ohmmeter. Top element working. Oven sensor has continuity on ohmmeter too. What else to check???
Hello, That is great that the oven tempreture sensor has continuity but you would need to do an ohms test on the sensor itself and it should read at room tempreture between 1000-1100 ohms any less then this and you would replace the sensor. If you did have between the proper amount of ohms on the tempreture sensor you would then look at replaceing the control board but most likely in your unit it is due to a bad oven tempreture sensor. If you have any further questions message me back also make sure you unplug the sensor and the oven before performing this test. Thanks Rick
Aug 31, 2011 | Kenmore Ovens
Kenmore stove model# 665.92024100 While cooking
Check and see if the broil element has shorted to ground.
Bonus
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 13, 2010 | Kenmore Ovens
Oven panel all lit up but won't work
control is the oven clock . look for a code in the display . if no code . unplug or turn power of 5 min and retry. may need a colck .. mm
Dec 04, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore oven not working
Hi, You need to unplug the stove, take the back panel off and check continuity on the bake element or after the back panel is removed, plug the oven back in, and turn oven to bake. You should get 240Volts to the two terminals on the bake element. If you have 240 Volts, the element is bad and needs replaced. I can ship you the new element.
Hope this helps
Vic
May 08, 2009 | Ovens
Kenmore self cleaning oven model 790.9520 : element stays on
sounds like it was in the preheat mode the cent to the cook mode so you can cook
Dec 16, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Oven going crazy
The bang may have been an element arcing over.  Turn off the power and remove the element.  If it shows any form of damage, replace it.  If you're not sure, use a continuity checker to check it.  If you have two elements...do this for both.  You will likely find the problem.
Nov 13, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
88 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
