Question about Microsoft Xbox 360 Console
Xbox 360 error e74
I get error e74 and one red light flashing. I tried everything and it failed. Is my 360 a fake? Is the AV cable fake as well? I got a new one but that was a phony.
  • 9 more comments
  • Anonymous Dec 27, 2007
    one flashing red light ,first time I have tried to turn the xbox on.It reads error
  • Anonymous Dec 29, 2007
    i got error code E74 . I took it apart and cleaned the dust out of it and cleaned with circiut board spray .It came back on for a week and then had the same problem . Iv try everything .
  • tiraera2006 May 04, 2008
    I tured on 360 and a black page comes on and it says e-74 and has one flashing light it has no picture no sound and i only had it two month.
  • jelani831 May 14, 2008
    i started to play all of a sudden my screen gets blury i turned it off then i turned it backed on and a red light was flashin with a code E 74
  • looking at p Jul 12, 2008
    tha fuking red light came on and the piece of **** xbox would not play my muthafukin bioshock , what kind of piece of **** breaks like six months after i should have gone wit sony
  • jamesmadison Aug 09, 2008
    apparently this problem happened to me also. I knew something was wrong when the screen during GTA turned all blockish. But i thought it was probably this disk because in the dashboard everything was fine along with Halo and COD. So i reset the xbox and i got the message. I talked to xbox support and they said my warranty will cover it (i bought the elite on 1/16/08 just a month after MS changed its warranty length) If you bought an xbox from any time after december of 2008, you should be covered for the next year or so.
  • Anonymous Feb 05, 2009
    I've just recently got the same issue. I just downloaded the new update and played one of the arcade games, when it started pixelating and froze. Shut it off and tried turning it back on and up comes the 'E 74'.
  • Anonymous Feb 19, 2009
    I was playing my 360 and all of a sudden i got the e74 error fixed it
    with the towel trick and it worked. But for some reason it fuzzes up
    just like when you get the error.
  • bamsk814 Mar 14, 2009
    i turn on my 360 and one red ring flashes it says error e 74
  • Anonymous Apr 12, 2009
    i ******* hate 360 now there picese of ****
  • ilahaa May 11, 2010
    Solution Link . . . www.MicrosoftXbox360Console.com
Hey everyone.. MS will warranty this problem. here is the link that they are including the error e 74 to the list of coverage warranties.
http://www.thetechherald.com/article.php/200916/3451/E74-Xbox-360-error-now-covered-by-Microsoft-warranty
Posted on Jun 15, 2009
    Genius:
  • 1,093 Answers
If you have the E74 error it is the display chip the scaler chip overheating, you will need to stop the heat build up, to do this send it in or fix it yourself using a good guide
Posted on Dec 23, 2009
  • 3 Answers
I just had the same problem with the E74 error.. sent it in and got it fixed for free
Posted on May 15, 2009
I had the sam issue. What you can do if you bought your xbox 360 less than 3 years ago is give it the red ring of death. You can do this by heating itt up a lot, and then cooling it rapidly. Do this, it will get the red ring of death, and then you can send it in for the red ring of death fix. if Microsoft only fixed the 3 red lights, you can send in your xbox again because it renews the warranty. good luck!
Posted on Apr 12, 2009
Can anyone give the exact instructions for the towel method please? I've been looking everywhere and i just can't find anything, Microsoft wont do anything so i'm gonna try this?
Posted on Oct 31, 2008
Ive had mine for less than a month and just the other day it came on with the E74, and i called microsoft and they tried everything and said they would repair it for $100 but its well worth it.. when u do this, they give you a 1 year warranty + 1 mo. free xbox live.
Posted on May 12, 2008
Be aware that MS will not repaird the e74 for free (even though they should - it's becomming almost as common a faul as the 3 lights!).
I've got it, I fixed it with a heat gun for a few days then it went completely.
Xbox is now in bin and i'm £300 down.
Posted on Feb 01, 2008
Look http://www.youtube.com/watch?v=GTBH29CmFHA&feature=related
the purpose is overheat the GPU, not the CPU, then try cool the cpu, and isolate the GPU, it works for me
Posted on May 22, 2008
  • jeoddr May 22, 2008
    try http://www.youtube.com/watch?v=GTBH29CmF...
    If you have problems, the purpose of this is overheat the GPU, and it restore itself.
    Try cool the CPU and overheat the GPU for 5 to 10 min.
    it works for me
    if it doesn't works try pressing down the ANA CHIP, look more on youtube and see it yourself
This is a big load of sh**e!!! £300 for this and I'm not even covered when it breaks after 4 months...as if it were my fault or something!?! Anyways, seen as I'm not covered I figured I may as well try my own solutions! Try the wrapping the towel method (youtube it) it doesn't work ever time but as stupid and all as the idea sounds it does work in fairness!
Posted on May 08, 2008
    Scholar:
  • 85 Answers
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
It is very possible since you have tried another AV cable that your scaler chip has gone bad or even possibly your gpu. Maybe you just bought two bad cables.
Posted on Dec 27, 2007
  • Anthony Dec 31, 2007
    E74 is a known error.
    If your AV cable hasn't worked then it is your GPU your system will have to be sent to MS there is nothing you can do to fix this issue. Contact MS if you want your system to work. The AV cables you have been getting probably work just fine its your system as stated in my previous post.
How do i fix an error 74 on an xbox360
The E74/E6x/E4x/E8x are famous error codes that have plagued many Xbox 360 gamers. This error codes will be displayed on your screen, each indicating different problem with your Xbox 360. It's usually defined by the single red light or 1 Red Light Error lit up at lower right quadrant on the Red Ring of Light on your Xbox 360 console.
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by using the Xbox 360 Repair Guide. Xbox 360 E74 error has reported to increasing a lot for the newer Xbox 360 version.
Hope this was helpful?
Feb 26, 2011 | Microsoft Xbox 360 Console
One red light flashing on xbox360,code e74 showing on screen
If you have 1 red light flashing it is normally E74 or some other E error you need to stop the heat.
You can send it in and Microsoft will do it for you or you can repair it yourself using a good guide
Dec 23, 2009 | Microsoft Xbox 360 Console
E74 fault xbox 360
hello E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
shaun
Oct 03, 2009 | Microsoft Xbox 360 Console
When i switch it on,it shows errror e74,with a red light flashing.
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU. Contact Microsoft for the Scaler chip issue.
Jul 23, 2009 | Microsoft Xbox 360 Console
XBOX 360 - E74 WITH ONE RED LIGHT
Usually when the AV is disconnected all four lights flash red. Cheapest thing to do first is try another AV cord.
However, it's possible that your 360 has been refurbished and the hardware has the chip in a warped position.
If it isn't the AV cable:
You can order a kit for RROD on ebay for about $7.00. Same hardware as what you'd need.
What you have to do is replace the hardware (x clamp) on the video chip the same way it's done when an xbox gets the RROD. reheat the chip so that it connects again by letting it run for about 5-7 minutes with the fan disconnected, turn it off again, wait about 30 seconds and then turn it back on. I fix 360's with this error code at least 3 times a week.
In some cases after doing the clamp trick you will get RROD. No worries, just follow the proccess above and everything will run smoothly.
Jun 02, 2009 | Microsoft Xbox 360 Console
MY SCREEN IS SHOWING E74 ERROR AND ONE RED QUARTER LIGHT IS FLASH
If you nave a good AV cord, this will be a chip issue. you will have to call Microsoft in this case for a repair ticket.
If you have not ever opened the console for any reason, you can call this number for a free repair.
1-800-4MY-XBOX
May 15, 2009 | Microsoft Xbox 360 Console
One red flashing light e74 rror code
If you just got it take it back, if you have had it for a little while you need to call microsoft and send it off for repair
Aug 21, 2008 | Microsoft Xbox 360 Console
One red light bottom right hand corner
You can check out the informative blog post at http://www.fix-xbox360.info/2008/09/11/xbox-360-disc-read-error-e74-error-no-video-problem/
This post describes the E74 error with one red light problem.
hope it helps...
Jul 22, 2008 | Microsoft Xbox 360 Console
Xbox 360
What is the error code at the bottom of the screen & check for flashing red lights on the power button if 3 illuminate it the infamous RROD(Red Ring of Death-google it) which you will get a free repair for if its the bottom right quadrant flashing red then its most probably E74 or E61. E61 is a hard drive related problem so try playing without it, & E74 is the AV cable snapped inside or the GPU/CPU inside the xbox 360 has weak solders on it, I suggest MS support ASAP.
Microsoft Xbox 360 Console Logo
6,059 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
