Question about RCA Scenium HDLP61W151 61 in. HD-Ready Television
Poor screen resolution and unable to get channel guide.
Our RCA Scenium is about 2 years old. About two months ago, we suddenly found that the channel guide was empty - no programs were showing. Then some were on the guide and some were not. We tried to reset the channel guide but nothing worked. Concurrent with this happening, we also have problems with picture clarity. The picture is somewhat fuzzy. It doesn't seem to be the cable as we are getting all the channels but the guide won't load and the picture is not the same bright, clear reception we got before. Any ideas? We've run out of things to try.
    Problem Solver:
  • 11 Answers
The channel guide is a service just like closed caption. Rumer has it that it's not going to be around for much longer. The only fix is to unplug set ..wait awhile till memory loss occurs...plug back up and do a setup. Nothing in the TV will cause partial guide. Weak signal could and cause fuzzy picture too. Complain to cable company. But brightness problem is something else.
Posted on Feb 08, 2008
We have a 14 year old rca scenium that the picture looks like a paint by number,what can i do to fix this? thanks
If your RCA TV is 14 years old, it may be nearing end of life. You may find repair is not worth considering.
Sep 10, 2014 | RCA Scenium D40W20 40" Rear Projection...
I have an rca 61" dlp tv that is about 4 years
More than likely you have a power board that is failing. Since the TV is so old I doubt it is under warranty still. I estimate it would cost you anywhere between $300-400 to repair that problem so it may be time to switch to a newer LCD TV.
Feb 28, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
My monitor will is all grainy I have connected it to a Sony Vaio (4 months old) downloaded latest drivers etc but still [poor quality -
I think it is your screen resolution it needs to be increased, go through my published guide entitled How to set your Desktop Screen Resolution?
Increased resolution and colour quality will give you an excellent picture.
damnor01
Jan 30, 2011 | Acer S201HL Monitor
The humming noise on my rca scenium starts just a
If this is a DLP set, which I suspect it is....you need a new color wheel. Common problem for these sets. If you don't have an extended service plan, about a 300--400 fix, in home.
Oct 09, 2009 | RCA Scenium HD65W20 65" Rear Projection...
Dark picture on RCA Scenium 61 in DLP
Yes, the lamp will gradually get darker as it nears it's end. The rolling lines sounds more like the set is on a local channel for the cable hook up. If your local area has a channel 3 or 4 live terestrial broadcast simply tune the cable box output to the other one, the same for the tv.
If this is cable/local broadcast issue it will go away in Febuary when the NTSC broadcast ends.
Jan 15, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA Scenium
I had the problem myself with my Scenium, the TV has a prblom with the circuitry and only fix is through an authorized RCA repare facility. Hope its fixed for you soon, awesome tv.
Rate plz
Sep 15, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
I had the same behavior, but not as a result of power outage. The TV is driven by windows CE software and it goes haywire every now and then. Usually pulling the plug for a few seconds takes care of any problems, but not this time (as you noticed). I had unplugged my ethernet connection on the TV a few weeks ago and thought I'd hook it up again to see if there was a new software release (not likely). I went to the menu and chose "Connections" and then chose "Ethernet Setup" and then chose "Reset All". After I closed the menu the TV rebooted itself (as it said it would). After my TV rebooted I had my analog channels back. There shouldn't be any connection between these two events, but it worked for me. Hopefully it will work for you as well. Good Luck!
Feb 17, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Blue on the left and right sides of my rca scenium, 65 inch hi def rear projection tv
Well what may have happened is a bad thing, See if you can find some way of displaying a totaly white pix, and have this full size filling the entire screen. If the side bars are still there this means the CRT's are burned and this is a perminate thing, The fix would be to change the CRT's mabe just the green and the red but they still run about $285.00 each. This was cause by having the set run in a format that DOES NOT fill the entire screen
Jan 12, 2008 | RCA Scenium D40W20 40" Rear Projection...
RCA Scenium HDLP61W151 61 in. HD-Ready Television Logo
118 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
