SOURCE: Intimus 280 shredder noise
The 280 is notorious for buildup of paper in the cutting cylinders and strippers.
If you are technical, unplug from wall, disassemble top cover and clean all the debris. Check nylon strippers (white plastic) for damage.
SOURCE: the paper will not go through my shredder
Can you actually see the cutter blades rotating? I have seen gears broken and you can hear the motor running but no blade movement. Remove the screws lift the top off carefully because their is a short ribbon cable connected to the main board and can easily be damaged. Of course unplug from power outlet first.
Gears and motor can be puurchased.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
SOURCE: the shredder will not cut the paper. the motor
I just had this problem. I took the screws out from the bottom of the shredder and opened it up, take a look and see if there are any cracks around the frame that surrounds and holds the shredder in place, if so you have to glue the crack so the frame is stable again.(the crack/break in the frame prevents the paper from cutting because the teeth on the shredder are not fitted properly). hope this helps.
