Question about Kirby G6 Bagged Upright Vacuum
Need help in changing the blade on inside of case housing for a old G6 type vac 15 plus yr old. how do i replace plastic blade.
  • searsman Dec 27, 2007
    got rgw part to change blade but need help to open up vac to change it.
  • 357 Answers
This guide should make it easy for you!!!
Hope this helps...
Posted on Dec 27, 2007
I have a 4 yr old vx6000c central vac that constantly blows house breaker
This unit requires a 15AMP 120 VOLT dedicated circuit. If there are other appliances or items on this central vacuum circuit, this could overload the circuit causing it to pop. The other issue that could be occurring is that the central vacuum is on a GFI circuit or ARC fault circuit. Central Vacuum Units are not designed to run on these types of electrical circuits.
Please visit our website if you need a replacement part or if you have more questions. Or give us a call at 1-800-533-3249
Don't forget to like and visit our Facebook page.
Jun 06, 2014 | Broan-NuTone Vacuums
Electrolux Epic Series 6500 SR. The machine is 15 yr. old & is working beautifully. However, when operating it emits a terrible stink, like cat *****. I've changed bags & filters but no ch
You need to have the vacuum cleaned out. If you are good with tools, just remove the motor and fans assembly, take the fans off and wash them. Brush ALL dirt out of the housing and reassemble. Your Electrolux dealer can do this but it isn't cheap. I used to be the service manager for my area. Since it isn't under warranty, you can have ANY reliable vacuum cleaner shop give a good cleanout. NEVER put anything into the cleaner to make it smell good. Electrolux cleaners get their power by having a straight through suction. The air goes through the motor. Adding smelly things can crystallize onto the motor and burn it out.
Jan 17, 2013 | Electrolux Epic 6500 Vacuum
I am trying to open the outer casing of the vacuum
There is a push in type flat plastic switch trim cover over the metal housing surrounding the switch.. You must unplug the cord, gently pry around the trim cover and you will find a screw, an irregular one underneath holding the switch in place. DO NOT OVERTIGHTEN when reinstalling this one or you will crack the switch.
Once removed the rear housing will come off. Then you will see several new philips round head screws holding the front housing onto the vac.With all screws removed the housing should open easily but there may be dirty film inside holding the halves together. The fan shaft will unscrew revealing the fan, a spacer behind and perhaps two different spacer washers. Install the new fan hand tight, washers and spacers in same order...
Good effort figuring this one out. Please post back with results.
Oct 29, 2009 | Vacuums
On my kenmore central vac no power unplug unit plug it back green light comes on but try turning vac on green light goes off again .
Please clarify that we are talking about the central vac LED/switch panel panel and plugging it into a 110 V wall receptacle.
If I understand when you unplug from the power source ,then plug back in the green LED comes on, looking normal ? But when you manually activate the switch on the motor housing of the vac itself the vac does not start and the LED goes out, so no green or red LED at that point?
If this is the case , Kenmore CV's built approx 5 years ago (MADE by EUREKA) and prior had a circuit board with attached cord (as opposed to detachable) which was prone to relay failure. There were several symptoms, most common was that the relay on that switch panel /circuit board would fuse on and the vac would continue to run when the hose was detached from the wall.However some I worked on from that era had exactly the same symptom you describe. If your unit is between 5 and 10 years old and this sounds accurate, you can unscrew this curved side panel relay with one philips screw. Inside on the PCB will be an L shaped black or white 24volt relay, generally rated at 10 amps. The replacement board or relay will be rated at least 24V/ 15 amps or more. If you can isolate your motor and test it separtely with a power cord or meter , the realy/board will be the only control componnet left.
If you have a small tipped soldering IRON, not a gun, you can generally find a replacement relay to rebuild the board for about $6 at an electronics parts store. Otherwise you will need to replace the control board itself, anywhere form $45 to $70 plus service call if you have a tech come out to the house, and the tech will just unscrew , detach wires and replace the board, no repair , approx 15 minutes work. This will likely cost over $100.
Please post back with your results
Oct 24, 2009 | Easy Flo EF1400 Central System Vacuum
How to change upper filters?
Open the vac as though to change the cone and remove the plastic inner cone with the slotted screw at the bottom.. Underneath you will find a 5" disk , likely coated with fine dust.
That is the one which needs to be changed. Around that disc will be three more screws holding the upper housing onto the vac. These ones are accessible from inside, if changing the motor.
Below the handle of the vac there is a serial number ring and three screws in an offset triangle. If you remove these and the rubber cover for the toe switch, the vac housing will come off. This will reveal the `foam or cotton ``muffler``. You can replace it or wash and dry it if foam. It acts as a muffler more than a a filter....
Oct 17, 2009 | Filter Queen Majestic Canister Vacuum
I got a new filter for my Beam central vacuum. How do I replace it? Do I take off the top lid of the canister?
You would not normally need to replace the filter unless it is damaged. Access is from inside the tank itself. Remove the bucket and locate the finger loop on the existing filter. Pull toward the inside of the bucket. Replace the filer by setting in it's track and snapping tight to the wall of the vac. Unless damaged you can save and clean the old filter for reuse.
Jun 10, 2009 | Beam Industries 2900 Serenity Plus Central...
Bought house. Inherited shop/vac. A bit old, but
If you are going to use the wet vac to remove water, be sure to remove the bag inside the canister first. Also, some wet vacs have an internal float that has to be installed, but that may not be the case with yours.
May 16, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Fan and bearing replacement on a Kirby G6
if you run your vac to long after the fan is broke it will cause excessive vibration and the bearings can go out. in almost all cases i replace the fan only. most of the time if you have a bad bearing the vac will make a grinding noise. you can also tell a bad bearing by grabbing the belt pulley on the end of the fan and pull up and down if it moves alot then your bearing is also bad. you can get the bearings separate witout ordering the armature assy. when talking of replacing any of these parts besides the fan i would advise you to take your vac to your local repairman. working on motor parts of a kirby can get pretty involved. to replace the fan first take the housing off where your belt and brushroll are. you should then see 5 screws on the front of your kirby. remove all 5 screws. then remove the handle. at the very bottom of your handle you will see a piece that allows you to move the handle, on the back side of this you need to push in with your thumb and the handle should pull off. then you should see a plastic piece directly below that snaps into the top housing. remove the 2 screws from this. one where the cord boot is and one above your power drive neutral/drive lever. then under this plastic piece is 2 more screws on your top housing. when these are out your housing should pull off. if not then remove the bottom plastic housing of your outer bag. then go back and look at the front again and you will find since removing the top housing you have exposed 2 more screws in the front fan cover housing that also need to come out. after this pry this housing off and you should be looking directly at the fan. grab fan with pliers in one hand and with the other hand apply pliers to the silver belt pulley and turn this piece clockwise. it should unscrew and then you can pull your bad fan off and attach the new one. i hope this helps and remember its not as hard as i probably made it sound. good luck!!!!
Sep 24, 2008 | Kirby G6 Bagged Upright Vacuum
I need to replace the belt on my kirby g6 2000 how do i do it
Generic problem for all Vacuums
Posted by shawn81 on Jun 20, 2008
I need to replace the belt on my Kirby g6 2000 how do I do it
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Kirby has a belt hook on the inside of the bell housing and 1st you need to release the old belt by turning the dial in front of the bell housing counter clock wise to get the old belt off. Some Kirby vacuums the entire bell housing comes off and makes it fairly simple but the process and the format to change the belt is the same. The brushroll has screws on each end and the screw heads need to be facing down on each side, so remove of drop down one side of the brush and slide the belt onto the middle of the brushroll then re-insert the brushroll, screws head facing down, then use the Kirby dial to hook the belt and then dial the belt onto the Kirby fan pulley and then you should be done. If you have further questions please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 20, 2008 | Vacuums
Kirby G6 Bagged Upright Vacuum Logo
63 people viewed this question
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
