Question about Sylvania CL972B (Black) 19 in. Flat Panel LCD Monitor
Monitor not shutting off all the way.
When I shut the computer down the monitor light keeps on flashing after I push it and it won't shut off . I've unplugged it , I've unplugged it from the computer., nothing. I even stood on my head . It is a ntel.
  • 555 Answers
SOURCE: my monitor will not shut down - screen stays white
You got a short circuit in one transistor located at the inverter area. The transistor is acting like a conductor and not shutting down the power to the back light inverter. If you are a technician and want to fix it, look for short circuits in transistors.
Good luck.
Posted on Sep 06, 2009
0 characters
1 Points
Notebook won't turn on
my nb500 netbook wont turn on i slamed it shut now wont turn on
Apr 23, 2012 | Toshiba NB500-12X
When my computer shuts down, the Monitor flashing green light keeps flashing. My problem is that I can not turn the Monitor "on" light off.
its a default feature. playing with the fromt pannel may cause an early filure or malfunction.
to get if off, switch off it from the power source. or remove the power cable from back.
Rate this solution, Write a comment to keep in touch.
Sep 16, 2010 | Samsung SyncMaster 191T 19" Flat Panel LCD...
My 20 inch Dell Monitor keeps shutting down..
mcdevito75 here, Sounds like the monitor itself, contact Dell for rep[lacement on warrantee if warrantee applies.
Jul 14, 2010 | Dell ST2010 20" Monitor
Lcd monitor is flashing on & off
This monitor is expeicencing a defect on the backlight and the assembly behind it. The backlight may need replacing or you could just buy another monitor.
Hope this helps.
Mar 15, 2010 | Acer AL1916W 19" LCD Monitor
My monitor power light keeps flashing. It won't
usually this is a bad power supply. most electronic shops can repair them
Jan 10, 2010 | Acer AL1916W 19" LCD Monitor
My DELL LCD monitor keeps flashing after the computer shuts down
Try to set the monitor in the factory setting this will discharge the monitor and restore it in the factory settings.
Nov 23, 2009 | Dell E173FP 17" LCD Monitor
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
Mar 08, 2009 | Computer Monitors
ViewSonic Monitor has trouble to wake up after been shut down?
Ok sounds to me like a power supply problem.. this a a fairly common symptom. I suggest that as a temporary fix you set the monitor to NOT turn the power off to the monitor in sleep mode if possible, in your power settings for the monitor.
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
Monitors on/off green light flashes
Try first unplugging the monitor and the computer from the wall for 12 to 24 hours. If this does not work, hook up another monitor to the puter to see if the problems with the puter or the monitor.
Sep 22, 2006 | Dell E171FPb 17" TFT LCD Flat Panel...
Computer Monitors Logo
27 people viewed this question
Top Sylvania Computer Monitors Experts
micky dee
Are you a Sylvania Computer Monitor Expert? Answer questions, earn points and help others
