Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door doesn't close properly
The garage door starts to close but then backs off as if the sensor is tripped. This consistently happens every time the door closes at a certain point (approximately 1 foot from the bottom and no there is nothing protruding from the door that is tripping the sensor). This inconsistently happens at various other points along the path.
the sensors are clean. I cannot tell if they are pointed directly at one another, but they are very firmly in place. This problem just started happening recently. Opener is about 9 years old now.
  • 1 more comment
  • Anonymous Jan 03, 2008
    the garage door starts to close but then backs off as if the sensor is tripped. This consistently happens every time the door closes at a certain point (approximately 1 foot from the bottom and no there is nothing protruding from the door that is tripping the sensor). This inconsistently happens at various other points along the path.
    when I press the control inside the garage the door will start to move then the light flashes on motor and garage door will not go down unless I manually hold control down inside garage, also keypad will not open the door.
  • Anonymous Jan 05, 2008
    yeah I have the same problem with mine. It's just started to become a pain to open and close recently. Nothing is blocking the sensors, yet it stops at various points along the way as if something were. Once closed, it only opens a foot or so and then stops. So I see as not a sensor problem because sensors only affect the closing process. It's all so annoying, especially where it is so cold outside and I want to keep the car in the garage!
I just had this problem and I cleaned the sensors and made sure all the lights on the sensors were on. They were but yet the propblem persisted.
I checked all the wires and found that the wires were touching where they went into the unit. I separated them and all is working fine now.
Posted on Aug 12, 2009
Have you adjusted your sensitivity regulator screw found on the motor box? I had the same issue. Would open only so far and then would do an auto open once it closed so far. Adjusted the 2 screws (*One* for the Upward Motion *Second* for Downward motion) and this did resolve the issue...Good luck!
Posted on Mar 07, 2009
For the guy who has the problem with the sensor acting like it is tripping try this.If a wire on one of the sensors is not connecting well, it will make the light on the sensor go off, the sensor that is operating won't recognize the other sensor which can cause it to think there is something blocking it. Try jiggling the wire on each one to make sure the wire is getting good connection. You will see the light on the sensor blink off and on if its doing this. The light on the sensor has to stay on for it to be working properly. Ive seen this happen twice in the last year and I dont work on them for a living:) good luck
Posted on Jan 08, 2008
Seceuroglide garage door
No doubt you have a rambling controller that changes the codes quite often. That protection prevents other from opening the door when you are away. It sounds like your hand controller needs a new battery, or a neighbor used their device that just happened to trip your sensor. Call the manufacturer and get assistance, have them run you through the process of readjustment.
Feb 26, 2014 | Building Materials
The garage Remote control was working normally at first then for now reason now it just opens the garage door but doesn't close it. I checked the side sensors they look OK & clear, and I...
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
Jun 06, 2011 | liftmaster Garage Door 1/2 Hp
Last night, I went to close my garage door and as it started to close (door moved about a foot), it reversed directions and opened. I suspected a cat might have ran in and tripped the safety sensor, but,...
On the rear of the motor unit near where all those white wires go you will find a small light. Check to see if it is flashing a code. It will flash a number of times then pause and then repeat. This will help diagnose the problem. Also make sure the trolley hasn't traveled too far and jammed against the bolt just in front of the motor unit. Post back.
May 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
When you push either the remote or the switch at the door, the garage door will go down almost to the bottom and then come back up and the light will blink several times. This does not happen all the time....
Your safety reversing sensors must be connected and aligned correctly before the garage door opener will close. An obstruction in the path of the sensor will also cause your door to not close.
This sensor is an electronic beam, which is sent between two sending and receiving “eyes”. These eyes face each other and are located just inside your garage door. They may need to be adjusted so the beam from the sending eye is properly detected by the receiving eye. Once the receiving eye “sees” the beam from the sending eye, a green indicator light will glow on the top of the eye.
Jan 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
I too am having the same issue. I replaced my console control because my garage door was unresponsive and that fixed that issue. Now I have to hold the button down sometimes double tapping the button and then holding it down to close it. I believe the first place to check is the limit switch. Look at your owners manual or get online help in adjusting that. If that does not work you may need a new logic board. As far as the sensors go, one is a sender and one is a receiver. They have indicator lights and when they are aligned they light up. Check those first as a logic board is usually alot more expensive. Check ebay though as I did as there are plenty of good used parts available. Just get the numbers off of your logic board so you know what to look for as far as model number and date of manufacture. Good Luck.
May 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener trips the GFCI
When garage doors get sticky, bent, and the chain needs lube they will trip the controls. A door may suddenly reverse for no apparent reason, that is friction. A GFCI is real sensitive to load. Also check the wiring to the unit. Any bad connection will upset the GFCI. Check all the way back to the breaker box, sometimes the screws on the wires need to be tightened.
Apr 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Whisper garage door system that only closes 3/4...
One sensor should always be yellow, the other should be SOLID green.
If the lights are not consistently SOLID, you have a sensor issue.
TEST: If the door closes completely by pressing and holding down the wall pad button, you have a sensor problem.
Check to make sure the are aimed properly at each other.
Check the wire at the sensor and more importantly at the machine (If the wires are loose at the machine (terminals) it can cause this problem. Remember the machine does shake a lot.
If the wires are good, the sensors are aimed correctly, you have a sensor issue and need to loacte a replacement set.
Feb 17, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Craftsman 1/2 HP door opener bounces back open
There should be 2 sensors on the bottom of your door on the inside, 1 on the right side and 1 on the left side.
These sensors serve 1 purpose to send a beam or reflection to each other.
If something is blocking this reflection or is in front of the sensor the door will always come back up.
It is a safety feature so nothing or no one gets hurt when the door is closing!
Sep 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage Door doesn't close
I have this same problem periodically. I fix it by manually closing the door and then letting the truck re-engage the door and everything is fine......unitl next time.
Sep 18, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
842 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
