Half of the screen is a solid blue but fades like a gradient into what the camera can capture. Any chance it's something I can clean/re-attach/easily replace. I have another old broken VX2000 at my disposal. Thank you.
Sony dcr-vx2000 i turn it on and play a tape recorded on from another camera and it plays that footage with no blue covering the screen but when i go to capture mode it is covered by big blue gradient like cover. After capturing some footage like this i try to play it back and it records the blue. Someone said it was the heads. This guy says its the lcd panel but it played the other footage just fine. and badchecker says its a ribbon cable. anyone else have an opinion maybe with some evidence or more details.
The lcd panel is faulty. replace it at a service centre
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
I solved my own problem. If you have a similar problem it's due to a disconnecting ribbon on the inside of the camera. If you need further instructions than that, email me at [email protected]
