Question about NetGear WGR614 Wireless Router
Netgear router how do you access the routers control panel to check the mac address ...i cant get on to the netgears routers settings page when i type in the http://192.168.0.1 it wont open up i get the message saying cannot display the page ok ...ps am also having bother getting the router to connect to the IP address ..the router picks up the signal that my pc is connected on the router.....can you help me
Go to routerlogin.net, the username is: admin, and the password is: password, OR 1234.  You can follow the setup wizard or manually assign the IP address.  I hope this helps!
Posted on Dec 31, 2007
Tip
4 Steps to Disable MAC Filtering on Netgear Router
The MAC filtering tool with a Netgear wireless router generates an access list based on the individual Media Access Control numbers that you connect. Because each computer-based networking device has a solve MAC address, the MAC filtering should stop unauthorized users from connecting to the Wi-Fi network. However, due to the instructions required to locate the networking device MAC address, you might get it onerous or inconvenient to add new systems to the network. In such situations, you should turn off MAC filtering and choose the other security approaches like WPA 2 encryption.
Note: - To get additional information, you can call on the Netgear customer service number and seek the help.
    1.Launch the web browser on your computer connected to the router through a wireless or wired connection. Input the following URL 'www.routerlogin.net' or 'www.routerlogin.com' in the address bar and press the 'Enter' key to show a login window.
    2.Input the 'admin' under the 'User Name' box. Input the password you chose when you configure the Netgear router. If you didn't choose a custom password, enter 'password' to sign in. Press the 'Enter' key to show the Netgear router's main menu.
    3.Click the 'Wireless Settings' button under the 'Advanced heading' tab on the left menu bar. Select to click on the 'Setup Access List' option near the end of the page. It directs you to the 'Wireless Card Access List' page.
    4.Remove the check mark of 'Turn Access Control On' box at the upper of the page. Click on the 'Apply' option to save and apply the changes.
    However, if you suspect that anyone has accessed your Wi-Fi password or you have any kinds of functional or technical issues in connecting to the Internet using your Netgear router, you should directly speak with the experts regarding your router glitches and get them resolved as quickly as possible. At such time, call at the certified Netgear customer support number available on the ContactforService directory site.
Netgear Router Customer Support
on Apr 11, 2017 | NetGear Computers & Internet
I've a problem with using the WLAN with nokia
This may be a problem with your router. Routers have a feature where you can control which computers can access the network using their physical address. This is called the Media Access Control (MAC) address. Every wireless card and network card in the world has their own unique address and is represented in hexadecimal format.
You'll need to notify your router of your phone's MAC address. On my netgear router, I access the router through a browser on a computer connected to it by typing www.routerlogin.net (i think... it varies with different routers) or the gateway ip address e.g. 192.168.1.1. Find the option for MAC address management, in my netgear it's called Access Control (i think) and there should also be an option to add MAC addresses. Add in your phone's mac address and try again.
Your phone's MAC address should be located on the box it came in or under the battery of the phone. The MAC address is in the format 00:A1:B2:C3:D4:E5:F6:7A.
Good luck
Feb 17, 2010 | Nokia 5800 XpressMusic Smartphone
I just set up a netgear router and a lynksys expander. All my laptops work, but iphone & itouch will not. Seems as though the password has changed. Can this happen? How can I find the password? When I...
If you did not configure the Netgear wireless router and changed the default settings and the default password password, then your wireless system is open to anyone hacking into your system and change your wireless router's settings and they can hack into your computers and your Internet connection. The Linksys expander will increase the wireless range to give a wider coverage to your router.
I suggest you reset the Netgear back to the factory defaults (press the pinhole button on the back of the Netgear router until the LEDs flash then release this button,
The configure the Netgear as follows :-
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 13, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
I have two routers Netgear DG834Gv3 and Thomson SpeedTouch TG585v7. I want to create a wireless bridge between these two routers, so that I can have internet on the Netgear router. The main router/Access...
I am sorry but I am not so familiar with the Thomson Device but I can give you a clue on how to set it up....you can skip the security settings first just make sure they work then you can set it later...Check it out!
- Thomson as "Master Router" connected to modem set up as follows
-- 192.168.1.1
-- Set up wireless access point as you normally would in Wireless Settings, muine are "MY_SSID",Channel 2,b+g mode,
64-bit WEP with hex key (rather than pass phrase)
--- Enter any laptop wifi MAC addresses in the "Client Access List" here to allow them and make sure it's set to restrict
them
-- Set DHCP range to 192.168.1.10 to 192.168.1.127 (my preference) in "Lan Settings"
-- go to Wireless Bridging and Repeating menu option
--- Set "Enable Wireless Repeating Function"
--- Set as "Wireless Base Station"
--- DO NOT check the "Disable Wireless Client Association" if you want to be able to use laptop wifi
--- Enter the mac address of your "Slave Router" here
Make sure all of the above is applied and has stuck, i had a habit of setting some things then clicking to a sub-menu
before clicking apply, always scroll down and click apply before drilling into sub options!
DG834G V3 : "Slave Router"
-- Get latest firmware as earlier v3 firmware doesnt support WDS
-- 192.168.1.2
-- Enable Wireless Settings and set to exact same as "Master Router" including 64 bit WEP key and MAC access list for
laptops etc
-- Disable DHCP in Basic Setup (I think)
-- "Advanced Wireless Settings" menu option
--- "Enable Bridging and Repeating"
--- Select the "Wireless Bridge With Client Association" (or similar) option
--- Enter the "Master Router" MAC address here
Again, double check everything has stuck, that the "normal" wireless settings for both routers are identical and reboot
both (in either order worked for me but booting the Master first is probably best practise)
GOOD LUCK!!!
I
Oct 26, 2009 | NetGear DG834G Router
How do i access my belkin router settings?
Are you sure you are connecting to your wireless router and not a neighbors wireless router by accident? Try connecting to your router using a ethernet cable and typing in its IP address. Your Netgear routers default IP address should be 192.168.x.x (gateway address).
open internet explorer and type 192.168.x.x and the will get u to the belkin router page and then click on mac address control and then type your password to get in to the router and it will take u to all the mac address u have allowed or denied.
Please rate me.
Thank you.
Yboyandrei
Aug 19, 2009 | Computers & Internet
How to hook up a netgear rangemax wireless router WPN824
  • connect it based on the manual
  • Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
    • set first the routers access page
    • type www.routelogin.com
    • type username: admin, password: password
    • on basic settings: select no internet login: set the router mac address to set to computer mac address, apply
    • click: wireless settings under set-up: change: SSID: <your name>, region: US, mode: g&B, channel: 11, no password first, click apply
    • goto xbox system-network- then look for the ssid of your router and connect, if you encounter any problem call xbox live support
Aug 05, 2009 | NetGear RangeMax WPN824 Wireless Router
Blingking light, no access to internet
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} FULL SETTINGS
Aug 03, 2009 | NetGear WGT624 Wireless Router
Having trouble accessing router with ipod touch and nintindo dsi
In order to Unlock Netgear router you need to know the login password for router's login page and if that does not work, you can try with a default username : admin, Password : admin, still if you are unable to access the routers page then you need to reset the router by inserting a pin in the pinhole where it says reset at the back of the router...press and hold down the pin for 30 seconds and then restart the router, this will take the router back to default settings and then apply username : admin and password : admin....it should work
Netgear address : 192.168.0.1 ( Type in IE address bar to access it )
Regards,
Anup
Apr 06, 2009 | NetGear WGR614 Wireless Router
VPN passthrough
What are the settings that you have for your netgear router? Its going to tunnel, right? Try this solutions and see it will work.
1. Access the set-up page of the router, from a browser, type 192.168.1.1
2. Go to VPN tab and select IP SEC VPN
3. Local Security Group, set it to subnet and input the Network Address of the router (LAN IP - 192.168.1.0)
4. Remote Security Group, set it to subnet and input the Network Address of the netgear router (LAN IP, for example - 192.168.2.0)
5. Remote Secure Group, set it to IP only, WAN IP address of the netgear router
6. For Key Managemnt, just make sure that all settings are identical with the netgear router
7. Last go to Advanced Settings and make sure that group settings are identical to the netgear router
Hope it works for you
Jun 24, 2008 | Linksys RVS4000 Router
NetGear WGR614 Wireless Router Logo
79 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
