Question about Maytag Neptune MAH5500B Front Load Washer
Maytag neptune Mah8700a
I have a repair person coming out this week to fix my machine, but I have wet clothes locked in the machine. I have followed all of the directions that the manual give for unlocking the machine, but I have yet to have any luck.
  • 183 Answers
Problem is probably a faulty lid lock/interlock if you force this you WILL do damage, best thing is to let your repair agent release the lid, less damage will be done.
Posted on Dec 27, 2007
I have a neptune top loading washer. Call PSEG service man out (had contract on washing machine). will not repair cost too much. Problem. end cycle spin -water will not come completly out of cloths....
Yes Elizabeth if you don't DIY the fix it's no worth having a repair service touch the machine.
I'm an knowledgeable owner and have helped many owners across 4 different forums save their $1K machine at reasonable cost. If you want to DIY I will help at this forum........ Google this ""FAV6800A/FAV9800A Outer Tub bearing replacement"" read thru the post and see if this is for you or someone that can help you DIY the work..............Good Luck dh1200s
Aug 01, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Won't drain all the way and door lock won't light up
Clean out the drain pump and check the pump motor while it is dis-assembled.
Mar 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Loader washing machine - door won't lock
It won't spin because the door won't lock. The door won't lock because the door lock mechanism is bad. I ran into this many times with the Neptune's when I was working for Sears. It is not a very easy fix. It is a pain to get to that door lock and replace it. You will most likely need a repair person to come out and fix it. I hope this helps you, sorry to be the bearer of bad news. I hope you have a good rest of the weekend though and let me know if you have any other questions. Good luck.
Jan 25, 2009 | Maytag MAH6700AWW Neptune Front-Load...
The word "suds"
to much detergent...with theses unit you must use he or low suddsing detergent..take half the wet soapy clothes out then start unit..sud level must fall...
Dec 27, 2008 | Maytag MAH8700A Front Load Washer
How can i fix my washer myself?
The washer will not ever completely drain according to Maytag. A certain amount of water stays in the outter tub for balancing the machine for final hyper-spin. However if the machine is not spinning all of the water out and your clothes come out sopping wet....read the long thread I typed out to another person earlier.....it's about 2-3 questions up on the same topic
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
My neptune does not extract.  My clothes come out dripping wet.
I am having the same problem, and have found that the door lock light is not on, and that the door lock does not seem to be working. This would keep the machine from spinning.
Is your door lock light on?
Jun 14, 2008 | Maytag Neptune MAH7500WH Front Load Washer
No power at all
ok first if you look in the dispenser drawer may have to push the tab and remove the drawer there is like a yellow pull tab will unlock the door second if your sure their is power to the washer the look at the control panel for burned resistor on the control bd and let me know if your serial number ends in ga through gx or ja through jn
Jan 30, 2008 | Maytag MAH8700A Front Load Washer
Doesn't your unit have a lock light in addition to an on light? On mine when you start the machine a red light comes on, then after a minute or two the lock light above it comes on. Once the lock light lights, the machine shouldn't stop. If only the initial light comes on, the door isn't locking. As a result, as the drum moves the clothes and they push against the unlocked door, it turns the machine off. You might need to check/tighten the door latch. Also check the door wax motor/door lock assembly.
Dec 10, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune MAH5500B Front Load Washer Logo
77 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
