Question about SanDisk Sansa e250 MP3 Player
My sansa e250 turns white
My sansa wont turn on the screen turns white and seems to reload again and i already tried what guys told another person but it still will not fix it and i also did recovery mode can you plaese help me
  • kenn utley
    kenn utley Dec 27, 2007
    The same shit keeps happening to my e250 and I just want to smash it into a wall but I love too much and after I would of destroyed someone comes up with a solution that works...that would be a bitch.
  • kenn utley
    The same shit keeps happening to my e250 and I tried to do the recovery thing that was suggested, you know the 20 sec. bullshit. I just want to smash it into the wall, but I love it too much and when I would of destroyed it someone would come up with a solution that actually works...that would be a bitch.
Try resetting (holding power button for twenty seconds)
or letting the battery run out and charging it
still not working?
did you get a warranty, or did you buy it recently, you may be able to take it back to the storee you got it from orr send it back to the manufacturer?
Posted on Dec 27, 2007
My 8GB Sansa seems to have crashed
Hi.
You need to update the Firmware of your Mp3 Player.
To do that try to follow this guide:
Sansa e250 MP3 Player Updating Firmware Guide.
Good Luck.
Nov 03, 2009 | SanDisk Sansa e250 MP3 Player
My sansa wont boot up
The best results that I have had were to hold the power button for about 15 seconds. ( if you only hold it for 3 seconds it goes into sleep mode). This shuts the device off. Then restart it.
Dec 12, 2007 | SanDisk Sansa e250 MP3 Player
Black screen
i dont know what the problem might be but u should try calling sandisk they should know what to do. hope it helps
Jul 11, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 will not play videos
Download latest ver of Quicktime
Jun 23, 2007 | SanDisk Sansa e250 MP3 Player
I need help with my sansa e250 mp3 player
Hi. Seems like your player may be encountering some corruption. Try this and see if it would help: Switch your Sansa E250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E250 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E250 and 90-99% of the time, it would boot up successfully. Let me know if this helped :)
Apr 21, 2007 | SanDisk Sansa e250 MP3 Player
Blank White Screen - No Menu Showing
My Sansa has a similar problem. Sometimes when the Sansa turns on (after the Sandisk logo) the screen will either turn black, blue, or black and white stripes. The player still works, but it is hard to navigate without the screen, obviously. What I end up doing is letting the backlight turn off and then pressing any button. Sometimes when the screen comes back, the display is allright again. But sometimes it takes more than a few tries. Turning it off and on again seems to work a little better, but it is more time consuming.
Apr 01, 2007 | SanDisk Sansa e250 MP3 Player
Sansa won't move
Try reloading the firmware. If the Sansa Updater says that you have the lastest firmware download the firmware manually and then run the software. In addition, tech support is fantastic with Sansa give them a call or e-mail. Best Regards, Keith
Jan 26, 2007 | SanDisk Sansa e250 MP3 Player
Help! my sansa wont turn on.. but the blue ring is still glowing
My sansa 260 has had the blue ring glowing and no screen for a while and I tried all the repair software and none of it worked because my sansa would not connect to my computer. I used the 15 second trick to turn it off, put it on hold then opened the back. Above the battery in the back is a black rectangle which was out a little so I pushed it back in took the battery out and put it back in and when i closed it and turned it on the screen was back! Works perfectly now
Dec 30, 2006 | SanDisk Sansa e250 MP3 Player
Sandisk e250 mp3 player froze up and won't turn off!
To Reboot your sansa e250 without removing batteries . Switch to hold position ( right beside headphone jack ) Press and hold menu and rec buttons at the same time untill screen resets. On my player lock up usually happens when it hits a corrupt song - try to delete and reload the culprit to minimize future lock ups. Hope this helps someone out there.
Nov 15, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
52 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
