Question about Scheu (K350-FAT) Heater
Scheu Heater problem
It starts up runs for 1-2 minutes then it starts to backfire and blow smoke out. How do I get it to run properly?
  • 625 Answers
Sounds like the fuel nozzle filter is clogged. remove it and blow air through it backwards or just replace the nozzle.
Posted on Dec 27, 2007
Changed O2 sensors and white smoke starts pouring out of exhaust
White smoke is usually steam which would indicate a blown head gasket or crack in block. Hope it's something easier.
Jan 15, 2013 | 1999 Ford Taurus
Single cylinder yanmar diesel engine on log splitter back fires out of exhuast & blows out black smoke
Engines runs for a couple of seconds then loudly backfires with a flash of flame out of the exhaust followed by a plume of black smoke. Then runs sort of ok for a couple of seconds then repeats the backfire again AmanStino Lightning Cable Apple MFi Certified 1M Nylon Braided Charging...
Apr 21, 2012 | Cars & Trucks
98 eldorado starts, runs rough and backfires. All codes have been cleared
CHECK THE MAF CENSOR VALVE, 5 MINUTE FIX. GET MAF FROM AUTO WRECKERS, 50 BUCKS, NEW 500. GOOD LUCK, IS IT BLOWING BLACK SMOKE WHEN DRIVING UNDER LOAD. GOOD LUCK
JOE
May 19, 2011 | 1998 Cadillac Eldorado
Heater runs a few minutes then blows smoke and cuts off
Are you using the old fuel from last year? If so, drain and clean the tank. Replace with fresh fuel and replace the fuel filter. Check or replace the air filters. Check your ignitor for proper operation. Test again. Good luck.
Dec 01, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heater runs for approx.2 minutes then starts to blow black smoke
Here is a tip that I wrote that tells you how to troubleshoot a Torpedo orReddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
heatman101
Oct 13, 2010 | Desa International Reddy Heater® RHER155B...
I have a 1996 honda passport V6, the car was scanned and found code p0134. the car runs but after a few minutes of warming the car stalls and backfires runs terrible what can cause those type of problems
This code refers to the front oxygen sensor on Bank 1. Basically the oxygen sensor is inactive.
DTC P0134 - 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
The powertrain control module (PCM) provides a baseline voltage of about 450 mV on the oxygen sensor signal circuit. When cold, the PCM detects the the internal resistance of the sensor is high. As the sensor warms up the resistance is lowered and it starts producing voltage based on the oxygen content in the exhaust. When the PCM determines that the time it took for the sensor to warm up is greater than one minute or that the voltage is inactive (not reading outside 391-491 mV it views the sensor as inactive or open and sets the P0134 code.
Potential Symptoms: One or more of the following may occur:
* Check engine light illumination
* Poorly running/engine missing
* Blowing black smoke
* Poor fuel economy
* Dying, stuttering
Causes: A code P0134 may mean that one or more of the following has happened:
* Bad O2 (oxygen) sensor
* Bad heater circuit in the O2 sensor
* Wiring or connector to the sensor frayed / broken
* Blown heater circuit fuse
* Holes in the exhaust system
* PCM failure
Possible Solutions: The most common fix is to replace the oxygen sensor. But that doesn't rule out the possibility of:
* Rusted exhaust pipe
* Inspect wiring & connector(s) for problems
* Excessive amperage blowing heater fuse (still requires replacement of sensor but also replacement of blown fuse)
* Replace PCM (only as last resort after all other possibilities are covered.
Hope helps (remember rated and comment this).
Jul 15, 2010 | 1996 Honda Passport
Runs for 2 minutes well then shuts off and smokes - a 50,000 btu serial #7581 - fairly old
I would suggest calling Portable Heater Parts at 1-800-362-6951, you will need your model number and a description of the problem and talk to their technical service department for assistance and to order replacements parts for this unit. Let me know if you need more assistance.
Dec 08, 2009 | Scheu (K50-FA) Heater
Reddy heat/scheu kerosene space heater no ignition
Typical kero heater uses either a spark ignition or a hot surface. The hot surface igniter is very fragile. A small bump may break the elements. Flame is detected by a photocell, signal is sent to the lockout relay board. Change the igniter costs about 50 bucks.
Nov 29, 2007 | Scheu (K50-FA) Heater
Scheu (K350-FAT) Heater Logo
142 people viewed this question
Top Scheu Heating & Cooling Experts
Stuart Slabber
Level 1 Expert
Tom Chichester
Daryl Gleaton
Are you a Scheu Heating and Cooling Expert? Answer questions, earn points and help others
