Heating & Cooling Logo
Posted on Oct 13, 2009
We bought a Frigidaire A.C. Model
We bought a Frigidaire A.C. Model FAC127S1A-12,000BTU's and didn't get a service manual with it since it was a floor model at Lowe's. How do I get a service manual?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Nov 08, 2009
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
1479
Points
15
You can down load pretty much any manual from the internet.Look up there website or give them a call
http://www.my-air-conditioner.com
Breaker keeps going when plugging the cord in the outlet
the outlet itself may be miswired with the line(hot) and neutral reversed. simple plug in tester will tell you if that is the issue, among other things. usually under $4 for the tester.
Where is the drain pan drain hole on the bottom of the Fridgidaire FAC 127S1A air conditioner?
Good Morning Friend,
I understand you want to know where the drain hole is on your Frigidaire air conditioner, model# FAC127S1A. I see that the drain seems to be blocked, as water is collecting in the drain pan, instead of draining. The drain hole is located beneath the compressor. You might want to try tilting your air conditioner slightly to the outside, to allow better water drainage. Hope this is helpful.
-Best Regards-
WP
How do I clean the condensation drain on my Fridgidaire fac127s1a?
I understand you want to know how to clean the condensation drain on your Frigidaire air conditioner, model# FAC127S1A. I see that the drain seems to be blocked, as water is collecting in the drain pan, and beginning to leak from the front. The drain hole is located beneath the compressor. You would have to get underneath that to clean the drain. You might want to try tilting your air conditioner slightly to the outside, to allow better water drainage. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
What is the size of this unit
I think it's a 12,000 BTU.
nice direct say on it. I have this model number in my house.
If memory serves correctly it was 12000BTU on the box when i bought it.
I have it out in my garage, it still works after all these years..drips INSIDE the window now because the waterways under the unit were poorly engineered.. hard to access and too small, such that they CONSTANTLY getting plugged up like a dam, causing the tray to spill into the inside coming out the front of the unit.
There is dirt behind the air directional louvers inside the air conditioner unit. How can iot be cleaned? The crevice tool of a vaccuum won't fit inside, besides the "dirt" seems to be...
Download manual from here: http://www.searspartsdirect.com/partsdirect/user-manuals/FAC127P1A1-Frigidaire-Parts-Room-air-conditioner-Parts-manual
2helpful
2answers
Yes, we have a fridgidaire FAC127S1A Model and we installed it today and are having trouble with it leaking water once it runs for a while. (The hole on the under side of the A/C.) Is this normal or is it...
If the water is leaking to the outside, that is normal. Especially if, the humidity is high outside.
If it's leaking to the inside. No, that's not normal and is due to improper installation. The rear of the unit should tilt down about 1/4" , to allow the water to drain outside via the drain pan hole.
To help you further, I have included a link to the Owner's Manual for your FAC127S1A model air conditioner. You can download and print it for future reference.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020213A0310en.pdf
Hope this helped you. Please let me know. Thanks.
5helpful
Frigidaire window air condition unit
Hello,Lilo The styrofoam pack MUST stay in place.When in operation the air tempature is so cold the unit will condensate(create water)if not insluated.Your unit would LEAK all over the place.The blower fan is a PLASTIC composit and should not rust.
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
