Question about Kenmore 13599 / 13594 / 13592 Built-in Dishwasher
Kenmore 13593 Not Operational
Dishwasher Kenmore 13593 was used until yesterday, but today only the hevy wash and quick rince option can be selected in the front panel. All the other options including the start button are not available since after pressing each botton for more that five second no activitie/action is identified.
As fallow the areas that were verifiy without a solution: panel components, motor movement, power, water, user manual, internet.
Please help.
SOURCE: Kenmore Quiet Guard 2 keypad
Sounds like the electronic controls (smart card) are acting up. Try shutting off the power at your fuse box or shut off the circuit breaker for 1 minute them turn the power on again. This fix quite often works on electronic appliances.
Posted on Apr 08, 2007
  • 90 Answers
SOURCE: Dishwasher not working again
is the clean light blinking, if so make sure water temp is at least 120 degrees
Posted on Jan 05, 2008
icuppu
  • 3 Answers
SOURCE: Start light is blinking
It appears that your door switch is intermittently working. Make sure that the switch clicks on and off when you gently press on the release door lever. It you don't here a distinct click sound then you'll have to go into the door switch and do a little filing on the plastic bar so it does not bind with the depressing of the switch. It is very simple to take apart and put back together.
Posted on Sep 30, 2008
SOURCE: Dishwasher not responding
we have a 4 yr. old built in dishwasher,model #665-15812,the lock-on light is blinking,and the wash and rinse lights are on,but if we push start ,it won't,and if we push the clear button,it won't clear,it's like it's stuck ....we've tried un-plugging,etc....any ideas,on what to do??? donnie-sue79
Posted on Jun 04, 2009
  • 415 Answers
SOURCE: have Kenmore ultra wash model 665.1604, purchased
unplug the unit for 1 min then plug back in then test unit pcb controller should reboot its self. if this fails you'll need to send the complete model # on the inside of tub area
Posted on Aug 31, 2009
I am trying to clean earthen pottery plates in my dish washer and after washing half of the plates disappear.
The Kenmore PRO also has an Ultra Wash Filtration High Energy Filtration System that helps the majority of us with hard water. It features 2 spray arms, and a Turbozone that blasts away the most gunked up items you can make a mess on.
The Kenmore PRO also features 6 cycles. The High Energy Smart Wash Cycle is the most advanced and versatile. It actually senses the load size, soil amount, toughness of soil and uses minimal water and energy. The Smart Wash Cycle runs from 110 minutes to a max of 194 depending on toughness of soil and uses from 4.2 gallons of water to 6.9.
The Pots Pans Cycle also makes some adjustments depending on soil level and takes from 140 minutes to 203 minutes to complete. It uses 4.8 to 6.9 gallons of water.
There is also a self-adjusting Normal Cycle that runs from 110 minutes to 193 minutes and uses 4.2 gallons to 6.9 gallons of water.
The Kenmore PRO also has a self-adjusting China Gentle Cycle that provides a light wash and gentle dry for delicate items and runs from 105 minutes to 194 minutes and uses 4.2 gallons to 6.9 gallons of water.
It also has a 1 Hour Wash that runs for 58 minutes and uses 8.0 gallons of water and a 15 minute Quick Rinse Cycle that uses 2.1 galllons of water.
The Kenmore PRO also has 5 other options that are additional to the Cycles. Each option adds time and water to the selected cycle. They are:
TurboZone, HI Temp Wash which raises the water temperature to 120 degrees F, a Steam Sanitize which raises the final rinse to 155 degrees F, a Top-Rack Only Option, and a Heated Dry Option.
The Kenmore PRO also has a Delay Option that allows you to run the dishwasher on off-peak hours and delays the start time up to 6 hours.
I have not field-tested all these options yet, becaue I am such a skeptic -- and picky about my dishes, I usually go ahead and always use the TurboZone, the Hi-Temp Wash, the Steam Sanitizer, and the Heated Dry Option. But, hey if you are plunking down $1500 for a dishwasher--you should make use of all your options. I'll keep this review up-to-date as my dates with the Kenmore PRO progress with dinner parties and my very precious china, but for now (mostly because of the "ClangBanger") our good china is safely stored in the cabinets.
Aug 16, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
No power to dishwasher. water still in dishwasher. Breaker ok
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 04, 2010 | Kenmore 13593 Stainless Steel Built-in...
Kenmore 665 dishwasher clean light is flashing. could it be the heat element?
The clean light is blinking due to the water not heating properly. It could be the heat element or a few other things. I have put together some things that can cause it and instructions to reset the control so you can use it. Follow this link and let me know if it helps.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 06, 2010 | Kenmore 13593 Stainless Steel Built-in...
My Kenmore 13593 dishwasher has stopped washing properly. It seems like the spray nozzles are not spinning. Almost as though there is not enough pressure or their is an internal leak. I have plenty of...
Look for plugged screens in the pump area... House water pressure has nothing to do with washing pressure as house water only fills, then the dw pump takes over...
Sep 20, 2009 | Kenmore 13593 Stainless Steel Built-in...
Quick rince light is flashing..but nothing work
To clear the indicators
Press CANCEL before starting the dishwasher to clear all options
and cycles.
Sep 16, 2009 | Kenmore 24 in. 16332 / 16334 / 16339...
Kenmore dishwasher model#66513582R-700 with no power.
Fuse does not protect against high voltage. Most likely burned up the control board
Jun 30, 2009 | Kenmore 13593 Stainless Steel Built-in...
Want to replace dishwasher panel with stainless steel
I'm not sure if that replacemetn part would work, but I know you can get cheap stainless panels and faux stainless options at applianceart.com. They have colors, textures, seasonal, designs, and stainless steel. You can choose between faux stainless (as seen on HGTV and the Today show) or regular stainless metal. check out www.applianceart.com
Jan 19, 2009 | Kenmore 13593 Stainless Steel Built-in...
Side mount brackets for kenmore dishwasher
Where can I can sears part # 170664 side mount bracket for a kenmore dishwasher mohel 13593?
Nov 13, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Jan 02, 2008 | Kenmore 24 in. 15933 Built-in Dishwasher
Kenmore 13599 / 13594 / 13592 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
