I have a table top heater. I go through gas tanks in under an hour. When I remove them they are ice cold and full of frost. What is causing the leak? Model No. 82300
Comments:
Oct 13, 2009
- I am using the small disposable camping type propane tanks. It happens to all of them. I do not know if there is a washer or something on the heater missing? I cannot tighten the tanks any more.
I have a Charmglow heater, Model HBL-155DLP/M20...both heater lights don't come on...fan works and...
(More)
I have a Charmglow heater, Model HBL-155DLP/M20...both heater lights don't come on...fan works and flame works, but no heat. Unit only worked for a few times, then this happened. How can I troubleshoot to see what part needs to be replaced. Thanks.
I have a Coleman Cal Cooperage 107 hot tub. We recently had a power surge. Hot tub turns on but...
(More)
I have a Coleman Cal Cooperage 107 hot tub. We recently had a power surge. Hot tub turns on but neither pump works. Both fuses are good. Electrician just checked them. No reset on pumps. Any ideas?
haven't used for a long time Colemann 5040; light works, heater does not / Any suggestions ; valve...
(More)
haven't used for a long time Colemann 5040; light works, heater does not / Any suggestions ; valve problem ?
I have disassembled a large portion of the unit. I can hear the propoane coming out at the top with...
(More)
I have disassembled a large portion of the unit. I can hear the propoane coming out at the top with a slight hissing noice but the smell of propane is very slight. The propane tank is full and functional and I have cleaned out the top section where the gas is emitted. Has the regulator gone bad or is there another issue?
