Question about Curtis-Mathis CM19011 TV
No volume The volume only works when a head set is plugged in. How do we fix the volume
  • Anonymous Feb 27, 2008
    I have a 20inch apex tv and the volume only works when there is a dvd player,game system or cable hooked up to it. Now if none of the above things are hooked up too the volume willl not work
I have no volume on my tv I can't figure out why?
Posted on Jan 18, 2008
Volume it turned to full but it's realy quiet
Check your game volume settings not your device, if still doing it, check your head phones plug in, could be damaged use head phones, Good luck
Jul 05, 2015 | Tablets & eReaders
How to fix Volume issues in PSP Portable
How to Fix a PSP Volume Button through Software
Check to be sure that your PlayStation Portable's AVLS (Automatic Volume Limiter System) is turned off.
Start your PSP without a game in it. Choose "Settings," then select "Sound Settings." If the AVLS option is "ON," turn it "OFF."
Check to see that your memory stick is inserted properly if the sound still does not work. This often interferes with the volume control. Remove the memory stick and reinsert it.
Perform a hard reset of your PSP if the volume still does not work. To do this, first unplug your PSP and remove any games or memory sticks. Then remove the battery from its cavity on the back. Press and hold any button for five seconds, then reinstall your battery.
Move on to hardware solutions if none of the above options work
How to Fix a PSP Volume Button through Hardware
Remove your PlayStation Portable's battery pack, any games and memory sticks. Unplug it.
Unscrew all five screws that hold the faceplate onto your PSP. The fifth is hard to locate, so find it just below the screen on the bottom edge.
Clean the button heads underneath the volume buttons with a small cloth. You should also clean the Home button nearby as this often interferes with the volume button.
Return the faceplate and screws, and test your PSP.
on Feb 13, 2010 | Video Game Consoles & Games
Turned volume to max no ringtone sound will notify me of text or calls how to fix
depending on which phone you have you might have to assign a ringtone ? click on the phone icon,click on menu button,select ring tone ( you can have a different ringtone for each person if you want ) also when volume is tuned up you will notice on some phones theres a cog icon at the end of the slider ? click on that as other volume options will show ( they could be turned down ) sometimes our volume will stay down if you have had your phone on silent and switched back...or if we plug head phones in the volume turns down automatically.try scroll silent on /off or plug head phones in and out
Apr 26, 2015 | Cell Phones
My headset stopped playing volume, how do I get it reset?
Try another headset first to isolate the problem. If the other headset is ok then I would check the in line volume control if fitted or it could be the cable is broken at the plug end or the headset end. if the second headset does not work either then check volume levels on phone. does phone speaker work ok. Can also be headset socket on phone worn out ?!
Feb 04, 2015 | ZTE Cell Phones
The speaker on toughbook CF-30 quit working when I pressed function key and f4
If you have the speakers on and at the same time plug in a head set, the head set overrides the audio output. Make certain the Audio OUT is clear. Look to the Speak setup at the lower right desktop screen. Right click and check the Volume and Settings. Make adjustments from there.
Jan 07, 2014 | Panasonic Toughbook CF-30 Notebook
Left headphone not working
no u have to check for a wire broken in the head set or down but the plug
Jan 01, 2012 | IBM Axxess Computers & Internet
My speakers are not working plugged into the back of the PC. They are working when I plug them into the head phone jack in the front. Is my sound card bad?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 22, 2011 | HP Computers & Internet
Does it have a built in microphone?
Interrogate the information in your 'Recording' file
Plug your webcam in
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
Click "Recording" tab.- check both "Show disabled" and "Show disconnected"
Right click on volume graph and
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
May 20, 2010 | Gear Head WC330I Webcam
Volume stays low won't increase
Your volume limit on your ipod is probably set low. To check it, go all of the way to the ipod's main menu and go to settings. Then go to volume limit and put it where you would like it to be if it is too low. Then go back to your music and play it. Turn the volume up to your liking and it should work and play louder.
Apr 06, 2009 | Apple iPod MA446LL/A MP3 Player
H700C Low audi volume
The head set just started to have low audio. People can hear what I am saying. I can't hear them.
2.gif How do I fix it?
Feb 08, 2008 | Motorola Mobility Bluetooth...
Curtis-Mathis CM19011 TV Logo
75 people viewed this question
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
