Question about Sub-Zero 632 / S
SubZero 532 have a subzero 532 that has developer a very small hole in the capillary line for the freezer. This happened due to vibration against a adjoining line. Can I braise this line and recharge or will I need to replace the whole capillary? The line is about 3/16 OD I do have acetylene and silver rods. Thanks Cliff
  • tecocliff Dec 27, 2007
    Thanks for the information. I should have been more clear. I am not going to be charging the system I just want to make the repair then have it charged for me.
    The compressor did not run long after the leak due to the fact the freezer was not cold enough. So I am willing to take a chance on charging it. Its the brazing of the capillary line that I am the most interested in. What is the best size copper line to use to create a sleeve to slip the two ends of the 3/16" capillary line into. Any tips on the actual brazing would be a help.
    Thanks
    Cliff
  • tecocliff Dec 28, 2007
    Do you have any tips on the best way to flare the 3/16 tubing?
    I do not have a flare tool that small.
    Thanks
In refer. repair we usually us silver solder as there is a tremendous amount of pressure that builds up in your sealed system. You would use the same size copper tubing, 3/16", and flare the ends to repair. If you have experience and can get ahold of some silver solder that would be okay. (Silver solder is not the color but the type of solder to use.)
Posted on Dec 28, 2007
    Scholar:
  • 146 Answers
It's a bit more complicated than you may think. It's not good to braise a hole you need to take a 6 inch piece and splice it into the area of the hole. As for recharging if you have never done it don't attempt it. Since there was a hole you may have gotten contaminants into the line and contaminated or burnt the system. For one thing you need to be certified as it is against the law to open up a system and discharge it into the air. The old freon is poisoness to small animals and if you don't have the right equipment you can't do it anyhow. Also depending on how old the system it may take R12 or R134. It's not just a matter of pouring new freon into the system. It has to be evacuated and the old freon captured then it has to be measured then with the right equipment pushed back into the system. Like I said if you have never done it don't even try it you could make things worse.
Posted on Dec 27, 2007
  • Kelly Sullivan Dec 29, 2007
    You can get ahold of a flaring tool at Harbor Freight or any other appliance parts house. You will need it for it to fit correctly.
Water is not draining down the drain tube in the main compartment of the subzero 550 refrigerator
clean drain line . force hot water down the drain as the get algi and stuff in them . if problem happens again then use a drain heater kit ( subzero ahd one for this model ) this will prevent ice over .. **** hope this will help ..
Dec 23, 2009 | Sub-Zero 650 / O Bottom Freezer...
I have a subzero model 532. I turned off my
its quite possible that your fill tube is clogged with a bit a ice
Oct 09, 2009 | Refrigerators
Subzero model 532 fridge not cooling well, freezer ok
Did u check condenser on the top behind the grill? If it's clean, check unit for evaporator freon leaking. Light....Possibly bad bulbs behind that plastic light cover or light switch - one of them located on upper portion of door frame.
Aug 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
Subzero 532 refridge cooling but freezer won't freeze
Unit has separate compressors and thermostat's. Clean the condenser, if it doesn't improve call for service, as there is a decent chance you will need sealed system work or defrost issue. If you need instructions on cleaning the condenser check subzero.com.also try advanceing the defrost timer as they mostly die in the defrost cycle. Behind the grille there will be a panel with a small hole in it with a screw above and below. Use a flat blde screw driver to turn the gray piece in th small hole clockwise a few clicks. If the freezer comes back on you will need to replace the defrost timer.
Jul 26, 2009 | Sub-Zero 690 Side by Side Refrigerator
SubZero Model 532 (1994) Refigerator/Freezer:
My SubZero 550 Regrigerator/freezer is not making icecubes. Any ideas
May 12, 2009 | Refrigerators
SubZero 532 frig lights out
There are two door switches one for fan and the other for the lights. With the compressor running, there are two so yu need to make sure it is the refrigerator and not the freezer, open the door and press the right switch and listen for a fan. The left should be your light switch and the problem is generally in the switch, on rare occasions there is a failure of bi-metal safety switch part number 4200850. One very rare occasions you may have a wiring proble.If you go to www.subzero.com there is a showroom locator tab on the top right corner, click it and you will go to a locator page which will get you to your local parts didtributor.
Nov 30, 2008 | Sub-Zero 561 / F
Sub zero 532: noise increasing.
We have the same SubZero unit and the water leak is the ice maker line or the pan that catches condensation. If you unscrew the panel at the bottom, you will be able to take the pan out and see if the water is from there. If it is from the ice maker line (which was plastic on ours), you should fix this right away as we didn't and we ended up having a $10,000 flood that ruined our hardwood floors. Also, the increased motor noise happened to us as well, but when we had the motor replaced, it is not much quieter.
Nov 15, 2008 | Sub-Zero 632 / S
Subzero 532 ice buildup in frig
Not enough refrigerant in sealed system or/and restriction in capillary tube.
HTML clipboard http://www.SubZeroLosAngeles.com
________________________________________
Sub-Zero Service Experts in LA Metro
Jul 30, 2008 | Sub-Zero 632 / S
Subzero 611 Refrigerator not cooling, freezer fine
It sounds like a defective ref section evaporator. This is common, due to poor quality metal used in fabrication. If you call subzero, they will more than likely fix it as they are aware of this issue. It probably wont cost you anything if you get them involved.
Mar 12, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 632 / S Logo
257 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
