Question about Dell Latitude D600 Notebook
Power supply issues or notebook problem?
This problem is a bit crazy because it involves 2 laptops and 2 adapters. I have a dell latitude 600 notebook (got it used) and a dell inspiron 6000(got it new). I have power cords for both. (They look identical and have the same input and output numbers) I have used them interchangebly. I keep one cord at work and one at home to use as I travel to and from with my laptops. While at home, the cord stopped working on my latitude. (Green light goes out as soon as it is plugged into the back of my laptop) I plug it in the wall then into the laptop. I have also tried plugging into the laptop first and then the wall- no green light at all then. I tried it with the inspiron and the same thing was happening. So I figured it was the cord.
I brought the other cord home from work and plugged it into the wall and then into the latitude. Green light on until it is plugged into the latitude and then it goes out. But this time the cord works with my inspiron. I then took the other cord (the one that I thought was the problem) and tried it with my inspiron again....and it worked! I am completely confused and have decided that the problem probably lies with the latitude 600 and not the cords.
Have you ever heard of this before? Does the battery have some kind of memory that could have been damamged? If so is there any way to reset it?
I will entertain all and any ideas on how to solve it. thanks
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 72 Answers
It's a pretty common problem (Power pin failure). The pins/sockets are poorly designed and poorly constructed. The day-in and day-out jerking and pulling on the cable causes the failure.
This video talks about using a cable retention device to stop the problem. I have tried the product and it works really well.
Posted on Mar 04, 2008
    Problem Solver:
  • 9 Answers
It sound like the power connetor to the motherboard inside your Dell latitude 600 is damaged. Either the solder joints conecting it to the PCB are damaged or the conecter it self is malfunctioning.
I would contact Dell directly and describe the problem you are having to them. Your laptop might need to be fixed by a technician. Here is the web site to chat with them online http://support.dell.com/support/topics/global.aspx/support/gen/chat?c=us&l=en&s=gen
Posted on Dec 27, 2007
Not powering up/power supply led goes out when plugging into into laptop
Step 1:
Try removing the battery of your laptop and try using the ac adapter/power supply alone.
Step 2:
Check your power supply's wiring if it's loose or have some signs of defects on it.
Dec 12, 2012 | Dell Latitude D 600/610
Universal power supply targus tip for Dell Latitude D620, won't charge battery, pop up says slow and no (charge), use only Dell. Is there a Targus tip that will go on Model APA10 Targus Universal power...
the problem is the BIOS of the Dell system is looking for an ID signal from the AC adapter so it knows what adapter is connected. If the BIOS cannot ID the power supply, then battery charger is disabled.
You will need to get a Dell AC adapter.
http://www.discountelectronics.com/index.php?l=product_detail&p=1459
Feb 15, 2010 | Dell Latitude D620 Notebook
Dell d 600 laptop is working perfectlly on dirct power supply but not charging the battery
If the battery is the original one than most likely the battery will need replacement.
If a new or known good battery will not change, while using a 90 watt standard ac adapter (An Auto Air adapter will run the system but not charge the battery) then next is motherboard replacement
Dec 27, 2009 | Dell Latitude D600: Pentium M 1.6GHz,...
I have a dell laptop latitude d600 and it will not turn on. the power supply light is on and when u plug it into the computer it turns off and the computer will not turn on and the power supply light goes...
There are 2 possible points of failure here. The AC adapter or the Motherboard. If possible, try a different D-Series AC adapter from a known good system and see if there is any change. Also test your adapter on a known good Dell if possible. If the adapter is the fault, then replace it. If a known good adapter has the same issue, then the motherboard is at fault and needs replacement. Motherboard are about $100 on EBay
Jun 04, 2009 | Dell Latitude D600 Notebook
My dell Inspiron 1318 laptop's battery is not charging.
check power supply see if its putting out voltage to laptop
Mar 29, 2009 | Dell Latitude C640 Notebook
Laptop won't power on Dell latitude 600
step 1. unplug everything (all usbs, extra screens, power supply...EVERYTHING!)
step 2. take your battery out, and leave it out
step 3. Hold down your power button (with the battery still out) and count to 15
step 4. put the battery back in (you can plug everything back in too)
step 5. turn it back on...if this still doesn't work. call Dell
Mar 06, 2009 | Dell Latitude D600 Notebook
Dell 610 - battery will not charge and adapter goes "blink"
http://support.dell.com/support/edocs/systems/ins6400/en/index.htm
aneesnv@msn.com
Dec 18, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
128 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
