Question about E-Machines etower 633id PC Desktop
How can I fix this?
I cannot get into my system configureation because I do not know what the password is. When I continue to get to the screen after the Windows Millennium screen the scandisk screen pops up by itself automatically. Then there sound in my computer when I put it on that sounds like a crackling noise. I think it my be my disk drive. How can I fix that.
  • Barrera1978 Dec 27, 2007
    Do you know how I can bypass the password so that I can get into the configuration settings. Because my computer say's that there is a error in drive A://
  • ladiesolja Jun 02, 2008
    my computer goes wont turn into my regular screen it goes to the manual area and ask for a password
  • 417 Answers
theres a set of removable pin jumpers inside the machine towards the bottom of the motherboard, one of them is the password jumper, remove it and start it up to reset or remove your password. they are super small so maybe use a pair of tweezers and a magnifying glass and a flashlight.
good luck
J
Posted on Aug 28, 2008
    Sergeant:
  • 263 Answers
When you push the power bottom and the screen start up push the funtional key F8 that will give you the chance to use it on save mode or you can go to the last know good configuration mode the hight lighting mode with the arrows from your key board and than press enter if you can make that works if not your hard drive it has a big internal mark in the internal disk and you can not be able to fix that the only way to fix this is bay sacaning the surface of the har disk or replece it
Posted on Dec 27, 2007
  • Jose Ramirez Dec 27, 2007
    what kind of password the one is on bios or the log in ,,,,,any way if the password is from bios you have to open the computercase and next to the conectors from the mainpanel there is a jumper or a switch the one you'll see next to it the inscription clear and password so what you have to do is just change the jumper to the side where is the word clear power on and off quickly.that will erease the pasword and return it to the original location------ if is the one from log in turn on the computer and before to boot up press the key F8 than hight on save mode by moving it with the arrow bottoms from the keyboard than press enter when logo cames out you have to use it as guess that option let you go into the system, now you have to go to control panel,and user acounts,you'll see administrator and guess so click on administrator or in any other user the one is on that computer ones you click in you'll see a list on top the one it seds create ,change, delete, passord or user so what you have to do now is delete de password by folowing the instructions.............easy ha.....i know you can do it
  • Jose Ramirez Dec 29, 2007
    the a:// means your flopy drive is not working or has someting inside you can disable it no bios or just by disconect it maybe thats the problem why the compurer does not work so you have to set you boot order firs HD ,CD, FD
When I Start My Acer Aspire 5336 Laptop, And Continue To My Password Screen, My Keyboard Will Not Work, Even The Mouse Pad. How Do I Fix It?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 24, 2013 | Computers & Internet
How to enter bios on thinkcentre 8811-6cu
Try hitting F2 when boot starts will normally take you to the bios.
Jun 14, 2011 | Lenovo ThinkCentre® M55-8811 PC Desktop
The screen reads "unit immobilized
To Get to the manager and check for disabled items.
To enter the Systems Options Menu:
1. Press SELECT WORKOUT.
2. Touch the Life Fitness logo in the upper right hand corner of the screen three consecutive times
go to configuration
Configuration
Allows authorized personnel to access all configurable settings of the unit. Configurations which should only be changed by qualified technicians are password protected.
Manager Vivo/Network
Manufacturer , Create Your Own
Media Center , Clock
Custom Workouts
Touch Screen Configuration
Export / Import Settings
The console manual will show you all the default values .
https://www.lftechsupport.com/c/document_library/get_file?p_l_id=27605&folderId=483177&name=DLFE-28306.pdf
Feb 01, 2011 | Life Fitness 95Te Treadmill
I have a Powerware 9330 100kVA UPS. The configured password is unknown by me. I want to reset the password and want to know the default password so I can configure the system. Can anyone help me with this...
Powerware was purchased by Eaton and they continue to provide support for all Powerware products. In the U.S. call Toll Free: 1 800 843 9433 (International: +1 919 871 1800) or
e-mail: LargeUPSTS@Eaton.com. They can help you out with the password. The 9330 manuals and documentation are located here: http://powerquality.eaton.com/Products-services/legacy/9330-info.asp
Oct 06, 2010 | Powerware 9330 40 (A40401110031112) UPS...
Reset cisco airnet 1130ag
There are 2 ways to reset the access point.
Using the MODE Button
Follow these steps to delete the current configuration and return all access point settings to the factory defaults by using the MODE button:
1. blank.gifOpen the access point cover
2. blank.gifDisconnect power from the access point (the power jack for external power or the Ethernet cable for in-line power).
3. blank.gifPress and hold the MODE button while you reconnect power to the access point.
4. blank.gifContinue pressing the MODE button until the Ethernet LED turns amber. (approximately 2 to 3 seconds). Then release the button.
5. blank.gifAfter the access point reboots, you must reconfigure it using the web browser interface, the Telnet interface, or the access point console port.
Using the Web Browser Interface
Follow these steps to delete the current configuration and return all access point settings to factory defaults using the web browser interface:
1. blank.gifOpen your Internet browser. You must use Microsoft Explorer (version 5.x or later) or Netscape Navigator (version 4.x or later).
2. blank.gifEnter the access point IP address in the browser address line, and press Enter. An Enter Network Password screen appears.
3. blank.gifEnter the username Cisco in the User Name field.
4. blank.gifEnter the password Cisco in the Password field and press Enter. The Summary Status page appears.
5. blank.gifClick System Software. The System Software screen appears.
6. blank.gifClick System Configuration. The System Configuration screen appears.
7. blank.gifClick the Reset to Defaults button.
Note blank.gifIf the access point is configured with a static IP address, the IP address does not change.
8. blank.gifAfter the access point reboots, you must reconfigure it.
Aug 13, 2010 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
New laptop , now router unsecure; want to use admin and 1234 cannot find the screen to try that fix - do not know password created many yrs ago - do not have expertise to reset router;Netgear CE0560
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Nov 06, 2009 | Computers & Internet
Laptop HDD is now locked
The hard drive password is setup from the BIOS configuration.
To remove the password you need to go into the BIOS configuration and you need to get the password from your brother.
There are no backdoor passwords, if you cannot get the password or guess the password then you need a new hard disk. If he has also set a BIOS password (you need this to get into the BIOS configuration), otherwise he owes you a new computer.
Apr 27, 2009 | Computers & Internet
Password help
Entering the System Setup Program
1 Turn on (or restart) your computer.
2 When the DELL™ logo appears, press <F2> immediately.
3 If you wait too long and the operating system logo appears, continue to
wait until you see the Microsoft® Windows® desktop. Then, shut down
your computer and try again
On each screen, the system setup options are listed at the left. To the right of
each option is the setting or value for that option.
You can change settings that appear as white type on the screen. Options or
values that you cannot change (because they are determined by the
computer) appear less bright.
The upper-right corner of the screen displays help information for the
currently highlighted option. The lower-right corner displays information
about the computer. System setup key functions are listed across the bottom
of the screen.
The system setup screens display the current setup information and settings
for your computer, such as:
• System configuration
• Boot order
• Boot (start-up) configuration
• Basic device configuration settings
• System security and hard drive password settings
the password is under System security
Mar 06, 2009 | Dell Inspiron 8500 Notebook
E-Machines etower 633id PC Desktop Logo
46 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
