Question about Aiwa Z-L500 Shelf System
HOW TO INSTALL AIWA PX-E860 TURNTABLE BELT
HOW DO I REATTACH AIWA PX-E860 TURNTABLE BELT. DOES IT GO AROUND THE WHITE ROUND PART TO PULLE?
  • Anonymous Aug 24, 2008
    Belt come off howe do you replace
  • 104 Answers
Http://www.archive.org/details/Turntable_Belt_Installation
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things. the website shown in the video lists your belt under the "find my player" button on the left side of that site.
Posted on Feb 12, 2009
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
THE PLASTIC COVER OR LID IS BROKEN FROM MY AIWA PX-E860 TURNTABLE WHERE CAN I BUY IT. SILVIA DE ALBA
I don't think you can find this part easily and new and honestly it doesn't worth it.
I would suggest to go for this or something similar
Aiwa Stereo Full Automatic PX E860 Turntable System
Feb 12, 2014 | Aiwa PX-E860 Turntable
PX-E860 Turntable: I need to replace the cartridge of my aiwa turntab...
my aiwa PX -E800 TURNATBLE has stopped working ,, is there anywhere i can get a replacement turntable .
Regards
Trevor
May 17, 2010 | Aiwa PX-E860 Turntable
The drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on
Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
Dec 14, 2009 | Aiwa PX-E860 Turntable
Ive got a technics sl j90 how do you reattach the belt any ideas or pictures?
I HAVE THE SAME PROBLEM WITH REATTACH THE BELT OF THE TURNTABLE PLEASE IF U HAVE THE SOLUTION CAN U TELL ME HOW TO DO? baygiuseppe@tiscali.it MANY TANX
Dec 05, 2009 | Aiwa PX-E860 Turntable
How do I attach the turntable belt to the Aiwa px e850
Lift the platter off the turntable. You can identify the motor spindle by using your fingers to turn the round shaft which rotates freely. Remove the rubber mat off the platter. Place the belt around the outside of the drum on the bottom of the platter. From the top of the platter, place your finger in one of the platter holes and tension the belt so it will not fall off or twist. Griping the platter trough the holes while keeping tension on the belt place the platter on the turntable aligning your finger with the belt to the motor spindle. Place the section of the belt on your finger over the motor spindle. Replace the rubber mat on the platter.
Nov 05, 2009 | Aiwa PX-E860 Turntable
TURNTABLE SPEED TOO SLOW. IS THERE ANY WAY TO ADJUST IT.
The liely cause of the slow speed problem is the belt. Your turntable is belt driven, like components in your car's engine compartment. As the belt ages, it can begin to slip. Replacement of the belt will probably restore the speed once again. The PX-E860 turntable has been discontinued. There are parts, such as the belt, that are still available. How much longer these parts will be available for remains unknown. If you like the the turntable, you should consider purchasing several belts as the next time you need one, they may not be available or may cost much more.
One source for replacement belts (there may be many others, ie: eBay):
http://www.elexatelier.com/aiwa.htm
You might also need a manual to direct you as to how to go about changing the belt. The manual is a free (after registering) download below:
http://www.retrevo.com/support/Aiwa-PX-E860-Turntables-manual/id/1077bh126/t/2/
Oct 05, 2009 | Aiwa PX-E860 Turntable
Dont know how to put on the belt for my emerson turntable m-266oa
Merely take off the horseshoe clip from spindle(under rubber) and remove turntable. Put the belt around the circular raised area in the middle of the platter and reinstall platter over spindle. align one of the holes in the platter with the brass spindle and just pull belt around spindle. Good luck...
Jul 10, 2009 | Aiwa PX-E860 Turntable
Aiwa PX-E860 turntable
Don't understand. If it doesn't turn on, how do you know the electronics are ok? More than likely your transformer shorted, and will need to be replaced.
Sep 23, 2007 | Aiwa PX-E860 Turntable
Aiwa Z-L500 Shelf System Logo
422 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
