GE WBVH6240F Front Load Washer
Problem for GE WBVH6240F Front Load Washer
Water in tub and nothing happen when we try to wash cloths
By cook7200 on Oct 13, 2009
No matter what I try to do the door locks, tub moves, door unlocks, door locks, then it sits there and until the timer works down to 0, then the door unlocks. I have a sears tech coming tomorrow, will post what he finds.
Solution #1
posted on Oct 13, 2009
Not Rated)
milten1
Rank: Guru  GE Washers & Dryers  Expert
Rating: 90%, 480 votes
usually this is indicitive of a bad pump or something stuck in it.these machines when first started they try to pump out first
the cycle will continue as long as it senses water
have them inspect the pump
good luck with sear service i hope it goes well
Was this helpful?
Yes
No
Popular Solutions for GE WBVH6240F Front Load Washer
Questions and Unsolved Problems for GE WBVH6240F Front Load Washer
Do you recommend GE WBVH6240F Front Load Washer?
Answer
Answer
washer wont start. says dl error then F. Is this the door problem or what/
Answer
it keeps pauseing have to keep restarting
Answer
Water pours out from under the machine at initial fill. I can see it coming from the little valve... (More)
Answer
Once the add garment light goes out it starts emptying the water. then goes to the rinse cycle.
Answer
Hi Do you have any info on model WBVH5200Joww ? control board problem Thanks Angelina...
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE WBVH6240F Front Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14816
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
