Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Does not fill all the way
Our washer was purchased from a surplus warehouse. Works great but doesn't fill all the way. Is there a way to adjust the fill level?
Two suggestions:
1. The most likely problem is a pressure sensor a device integrated into the level swith on your control panel. The end of the tube goes is exposed to the water level and increases the air pressure as the water level rises. As the water level rises, the pressure in the tube rises and the working sensor responds accordingly. Replace the swich, an easy inexpensive job. 4 screws, 2 in front, 2 in back and the control panel will roll up and forward exposing the switch.
2. There is a small chance that the water inlet valve ($35) is clogged or malfunctioning.
Posted on Dec 30, 2007
  • 1,314 Answers
Change the fill swtch
Beko dishwasher doesn always fill with water but makes sounds as if it does. Other times it works great any ideas?
depending on chosen wash cycle washers are not always supposed to 'fill' just use enough for that cycle .
If you mean sometimes no water at all and sometimes water with same settings check hoses and valves .
make sure valves are fully open hoses securely attached and hoses from valves to washer are not pinched twisted or damaged.
Hopefully the water not getting in the washer isn't leaking all over your floor below the washer.
Jul 18, 2016 | Beko Dishwashers
Washer will not spin at all no code . will drain and tumble back and forth,when it comes time to spin it turns off.
A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring things up-- either an agitator in the middle of a top-load machine or a rolling drum in the case of a front-loader.
The four cycles that every washer performs are fill, wash, drain, and spin. Though these functions are pretty basic, a number of things can go wrong with them.
There are a number of problems that you can fix quite simply; some issues, however, are better left in the hands of an appliance repairperson.Problems that commonly occur with a clothes washer are discussed in depth below.If your washer doesn't run, be sure it's plugged in and that the receptacle works (the circuit hasn't overloaded). Before working on the washing machine, be sure to unplug it.
To prevent problems, follow good maintenance procedures. Use the right amount of detergent for your washer and your water hardness, make sure the machine is level, and don't overload it for the cycle chosen.
Washing Machine Does Not Fill
If the washer doesn't fill, the water inlet screens may be blocked. Clean or replace them. (Check your owner's manual for the location of the screens; they're often located at one end of the supply hoses, or you may have to remove a panel to access them.) Other reasons for not filling may be that either the timer or temperature selector is broken--both of these are repairs for an appliance repairperson.
Washer Does Not Spin
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a w
asher to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
Clothes Are Wet After Spin Cycle
If your clothes remain wet after your washer's spin cycle, perform the following diagnostics:
1) Lift the lid during the spin cycle. If the tub is not spinning, you may have a damaged motor coupler. Call a repairperson to replace this part.
2) If the tub is spinning, recheck the load to make sure it is balanced. If you are certain the load is balanced but your clothes are still wet, you may need to call a repairperson to replace a damaged motor pulley, tub bearing, belt, or clutch.
3) You can also follow the troubleshooting steps outlined in "Washing Machine Doesn't Drain." You may have a problem with your drain hose or pump.
Oct 27, 2011 | Washing Machines
My maytage washer went off balance. just discovered it and it doesn't drain, spin, wash the timer works and it also fills. It just clicks. How do I fixi t?
If the inlet valve works to bring in water to the drum and still the washer does not start then the water level sensor can be defective.
You need to check on the voltage on the timer controller unit to confirm if there is a output even after the water fills up. also check the door switch , if open the washer will not start.
Sep 09, 2011 | Refrigerators
Will not fill with water but works on spin cycle
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Jun 08, 2011 | Maytag Washing Machines
We have a eduscience telescope (bought several years ago) Our grandson found it our attic and states that it is missing a diagonal mirror. Where can I find one.
Measure the hole in the focuser-- diagonals come in 3 sizes:
.965, 1.25, and 2 inch sizes.
Your scope is probably a .965 contact Surplus Shed and see if they have one:
or Telescope Warehouse:
Nov 07, 2010 | Edu-Science (10166) Telescope
Ihave an Amana washer model DLWRAW. Ithas a
not a good number go to whirlpool parts surplus dot com and ask for mark i can get you going on that with a great price shipping is only 4.95
Jun 25, 2009 | Amana DLW330RA Top Load Washer
I'm trying to purchase a new Model 29732 kenmore washer
It is no longer available.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 07, 2009 | Kenmore Washing Machines
Maytag washer fills but doesn't agitate
I took the control panel off and played with the lid switch a little and found the agitater would work intermittently. I bypassed one of the switchs (it appeared to have two switches mounted on a plate) and the washer would work properly. I used information I found on to help understand my problem and see a picture of the switch for my washer, so I contacted them to purchase the part. I installed the lid switch assembly and it now works great.
Mar 06, 2009 | Maytag LAT2300 Top Load Washer
My Washer machine fill up dosenl' spin
I think the problem is a faulty inlet valve that needs replacing. Hope this helps.
Jan 20, 2009 | Kenmore 24932 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
88 people viewed this question
Dan Webster
Dan Webster
Sal De
