KitchenAid 525 Watts KP2671 Professional 6 Series Stand Mixer
Problem for KitchenAid 525 Watts KP2671 Professional 6 Series Stand...
Kitchenaid mixer motor makes loud grinding,
By lgardash on Oct 13, 2009
Kitchenaid mixer motor makes loud grinding, squeaking noise.
Solution #1
posted on Nov 03, 2009
Not Rated)
hslincoln
Rank: Wiz
Rating: 99%, 13 votes
lgardash, Are you sure it's the motor or could it be the transmission?
It 'sounds' like you've got some transmission gear issues, and a situation similar to my wife's mixer, which we got new in Dec 2006. (Within a week of her first using it, she contacted KA Customer Care and the only 'care' they offered was an explanation that the new KA Pro Mixer gears are all metal and to expect it to be louder than previous models that used a plastic gear (to fail). Well, there's an acceptable level of noise, and an unacceptable level (you don't need to be a mechanical engineer to know when something doesn't sound right) and it seems that my wife's new mixer's operating noise level was always unacceptable. It finally 'died' this past October.) OK I've vented enough on KA... now what might be your problem(s)?
It could be as simple as thorough normal use the gears have shifted slightly in the transmission and the gear teeth are making different contact, hence the grinding/squeaky noise. The higher the speed, the louder, higher pitched sound you'll get. Alas, the noise may also be indicative of a potential gear failure (after our mixers increasing noisiness, the bevel gear broke and the mixer 'froze').
If your mixer is under warranty, contact Kitchenaid. If it's out of warranty, then take it apart and do a diagnostic exam of the gearing. Whatever you find you should be able to fix yourself. Be sure to have the Kitchenaid Part Manual (Part No. 8212278 Rev D) on hand if you attempt to disassemble yourself. It also lists all the parts so that you can determine, which parts, if any have failed. You'd think that the Kitchenaid name would warranty their mixers for a lifetime... So much for quality in America today!
I hope this helps, and good luck! - Howard, Burke, VA
Was this helpful?
Yes
No
Popular Solutions for KitchenAid 525 Watts KP2671
Questions and Unsolved Problems for KitchenAid 525 Watts KP2671
Do you recommend KitchenAid 525 Watts KP2671 Professional 6 Series Stand Mixer?
Answer
Answer
my mixer runs great except it doesn't seem to get quite as fast as it used to.... almost like 'top... (More)
Answer
when the pro 600 is mixing it starts to make a clicking noise and sometimes takes a while to start?... (More)
Answer
kitchenaid 6 qt mixer will not run...........overheated and shut down...will not restart
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For KitchenAid 525 Watts KP2671...:
Top Mixer Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Mixer Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
