Question about Citizen Eco-Drive BL006056H Wrist Watch
CITIZEN TITANIUM SOLAR TECH WR200
How do you open this watch. I been looking for the right anwer all over the place and without luck. The stem is broken and I may have parts, but I need to open it first. Any suggestion will be greatly appreciated.
  • shulton Jan 08, 2008
    I would like to get inside and take a look at the movement. I have 3 watches on my bench and each one with a different problem. I guess one of them must be trash to save the other two
If you can't see a buckle on the outside, you may have a invisible double lock clasp. Look in the inside of the watch, if there is bar, find the center of the bar and place one thumb on either side of the two links in the center of the bar. Press outward, away from the watch the two links will open an expand to reveal a "butterfly" expansion.
Hope this helps.
Posted on Dec 27, 2007
Citizen eco drive stopped working
Bad capacitor (Titanium Ion Battery)... probably a $30 or so repair on a fine watch.
Feb 17, 2014 | Citizen Watches Citizen Atomic Perpetual...
Why won't my "solar" powered watch charge/work any more?
Some of these eco-drive watches use a swinging weight self winding mechanism (albeit through a generator) or a solar cell under the dial, some use both. Either way the capacitor is the thing that holds the charge and once that fails it will need replacing. Sometimes not as straight forward as replacing a battery as you nay have to remove the auto weight and sometimes usually on the solar ones its just a case of popping it out and a new one in. They are quite difficult to identify and get hold of but they do differ from normal batteries as they come with 1 of the contacts attached to them to prevent fitting an ordinary battery by mistake
Feb 02, 2013 | Citizen Watches
I have a new Citizen WR200 and the manual that came with the watch is very basic. Please can you tell me where can I get a more comprehensive set of instructions for my watch. Many thanks, David.
You can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical
support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on
"get setting instructions"
I cannot promise that the instructions will be any better than the ones you already have. Some makers only give the most rudementary instructions and expect you to know the rest. I hope this helps!
Feb 09, 2011 | Citizen BL5314 52E WR200 Eco-Drive scyba...
Eco-drive watch stop working, after it was in jewelry box for over a year.
First, be sure that the stem is fully pressed in. Pulling out the stem to set the watch stops the action.
The Eco-Drive is still a battery watch. It just has a solar/light powered recharge system built in. The battery will run down after a year of no light. Place the Eco-Drive in bright sunlight for a couple of days in order to recharge the built-in battery. You may recharge the watch in fluorescent light as well, it just takes longer.
Dec 05, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
My Citizen WR200 keeps resetting to the year 2016.
If you haven't got instructions you can get them from you can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on "get setting instructions"
If this does not help I suggest that you contact them and discuss your problem. The web site indicates that there a 5 year warranty on their watches. If this applies to your watch, then they should repair it free of charge.
Jul 15, 2010 | Citizen BL5314 52E WR200 Eco-Drive scyba...
Daylight saving time
Apr 13, 2010 | Citizen BL5314 52E WR200 Eco-Drive scyba...
How do I manually set my Eco-drive wr200
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CITIZEN watch manuals. Rate me, please
Apr 01, 2010 | Citizen BL5314 52E WR200 Eco-Drive scyba...
Corrosion
sounds like the acid level in your sweat is high a lot of watches onlly have a light plated skin over base metal. if you look at whats scraping you you will see the edge of the surface metal and the base metal . if this helps please rate.joe
Nov 19, 2008 | Citizen Eco-Drive BL006056H Wrist Watch
Citizen Eco-Drive BL006056H Wrist Watch Logo
1,678 people viewed this question
Top Citizen Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
