Question about Palm Tungsten T Handheld
Re: Tungensten C
It won't turn on. However, sometimes if I hold it in the cradle just right it will boot up for about a minute and then turn dark.
  • 59 Answers
It sounds like the Palm isn't properly getting charged.
Maybe if you can put something to hold it down on the cradle and let it sit there to get a charge for 1-2 hours, then it may power on regularly.
Posted on Jan 04, 2008
My Samsung SMT217S will not stay on. It boots up fine then within seconds, sometimes minutes, goes dark and I have to boot it up again.
could be a battery fault. there is a chip in the battery that tell phone its charge. if this becomes faulty it will do this as phone thinks battery is flat.
Apr 24, 2018 | Samsung Computers & Internet
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
CK30 is cold booting when I remove the main battery. The supercap battery status is high and I am not depressing the cold boot button in the battery compartment.
Hello jcapsto. It could be that the backup or 'flash' battery isn't totally charged for one reason or another. This little internal battery keeps a minute current going to the units' flash memory that holds settings and other data and allows warm boots. I would recommend putting your CK30 in it's cradle with the main battery in overnight. Then trying removing the battery and it should spring right back to life. If not, then I would pin the issue on your backup battery and would implore you to contact Intermec or the vendor you purchased it from about replacement/repair. I hope this helps to at least isolate the problem. Good luck!
Jan 08, 2010 | Intermec CK30
Blank Screen
sounds like the backlight has gone. Possibly easier to have the screen replaced.
Have you checked that theres no dimmer or light/darker switch on the side et,c.
Also power the device on, in the cradle. if it lights in the cradle, adjust the systems display settings.
Mike @ Compurepair.
May 29, 2009 | Computers & Internet
My apple iPhone 8GB, screen locked and is only allowing me to make emergency calls. Thanks, Ada
You may need to put it back in its cradle to sync.....A quick turn the unit off, by sliding the touch screen slide.....then holding the top right-side tab.....It will give you a (Slide to power-off)....turn off for a minute...Once back on replace to cradle for sync...If problem still exsit...Contact Apple Genuis bar!
Sep 14, 2008 | Lands Phones
MC50 won't boot with battery attached
Be sure the Battery is in the "LOCKED" position, with the lever all the way to the right.
Jun 29, 2008 | Symbol MC50 Pocket PC
Fails to boot
You might try a Hirens Boot CD, un-zip the files, create a bootable cd from the .ISO file and boot your troubled system, select virus scan on boot.
Apr 16, 2008 | Gateway MT3705 Notebook
Palm Tungsten T Handheld Logo
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
