This problem should be removed because:
Problem with Water Heaters
hi. my heatline vizo 24 boiler not working
hi. my heatline vizo 24 not working. When i turn heating/ hot water on, it works for 30sec and then it goes off. Then (the pear and line across it light on the main bar) start flushing. what is the problem?
Solutions (1)
Best Solution
overheat stat or fan best of luck
Very Hot water coming out of overflow pipe
6 year old Heatline boiler. water out of overflow and backing up to boiler.Pressure guage up and down.Hot water in house only lukewarm....
hot water
i hae a heatline combi boiler and for some reason i am only getting limited hot water (around 2 minutes at time) and then it turns to cold...
heating pressure gauge goes up
the pressure gauge on the heating system goes well up to its limit when the heating is on high and it is not heating up properly. the hot...
its takeing a long time for some of radiators to
its takeing a long time for some of radiators to get hot,and when they do they dont get that hot ,iv flushed the system out,could it be...
Add Your Solution
My 24i 28i boiler will not start,has 240v fuses ok...
Book keeps saying replace PCB.Have replaced but still same fault.Replaced gas valve as well but still same .
Flame Rolls Out Of Access Opening When Burner...
REPLACED BURNER ASSEMBLY BUT NOW THERE ARE FlameS RollING Out Of Access Opening When Burner Fires
air condition
heatpump/low voltage
thermostat not on
thermostat off
i need to drain my system, how do i do it
radiator came off wall and i need to no how to drain sytem and refill
Fix-O-Meter
1,921
1,921 people viewed this problem
- 4 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Water Heater Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
View More Comments
