Bosch 24 in. SHU43 Built-in Dishwasher
Problem for Bosch 24 in. SHU43 Built-in Dishwasher
Doesn't get hot and steamy especially during rinse
By uad52 on Oct 13, 2009
doesn't get hot and steamy especially during rinse cycle
Best Solution
posted on Oct 28, 2009
Very Helpful)
sbk101
Rank: Master
Rating: 88%, 4 votes
I dont belive this dishwasher has a heating element. If it works like most bosch dshwshrs, then it is supposed to get the water really hot with a run through water heating element and this hot water (156 degrees) cleans and dries the dishes. There may be a problem there- I am also experiencing issues since last week with mine running a long time and not sanitizing.
Comments:
Oct 30, 2009
- the previous poster is correct. I found the same soution (solder joint) in other forums. I will take mine apart this weekend and hopefully verify. What concerns me is why did it burn out in the first place? Bosch has 5 year warranty on circuit board, but you will have to get service call. Board costs about 160 dollars.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 21, 2009
Very Helpful)
sfronek
Rank: Apprentice
Rating: 100%, 3 votes
Chances are there is a bad solder connection on the circuit board. I had this exact problem last year. I added a bit of solder to the burnt out portion on the circuit board, and now it works great. I learned this from other chat rooms.
Was this helpful?
Yes
No
Solution #3
posted on Oct 13, 2009
Very Helpful)
TheMazz
Rank: Guru
Rating: 92%, 45 votes
Try whispering sweet-nothings into its ear and kissing it. This always gets me "hot and steamy". ha, ha
But seriously, the steam you see in your dishwasher is created when the heating element inside the dishwasher heats the water up even higher than your water heater. This provides extra cleaning power. The heating element is also turned on during the drying cycle to help dry the dishes quickly. That is why you get a blast of steam when you open the door at the end of its cycle.
So no steam means either the element is bad (likely) or the controller/timer is bad (hopefully not, $$). If you know how to use an ohmmeter then you can "ohm out" the element and see if it is open (unplug the power first!!). If not, you can remove the element and take it to your parts store and ask them to do it (again, turn off the power first!!!).
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Bosch 24 in. SHU43 Built-in
Questions and Unsolved Problems for Bosch 24 in. SHU43 Built-in
Do you recommend Bosch 24 in. SHU43 Built-in Dishwasher?
Answer
Answer
The power switch on my Bosch shu43 is flaky. It has to be pushed several times to get it to start.... (More)
Answer
dishwasher does not turn on. it is plugged in but when the on off button is pushed nothing happens.
Answer
model number SHU43C05UC-17 I have had several problems with this machine have had the pump... (More)
Answer
pump will not stop when you put power on . pump starts as soon as you put the power on ... (More)
Answer
Bosch SHE58C won't drain. Not only does the "dry" cycle not really get things dry, but... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
