Panasonic ET-RM100 Remote Control Logo
Posted on Dec 26, 2007
Vcr remote Hi Will a Panasonic N2QAJB000086 remote work a NV-FJ630 panasonic VCR?
5 Related Answers
Anonymous
  • 275 Answers
  • Posted on Mar 21, 2007
SOURCE: panasonic pv-v4021 VCR
Actually George, You should read the supplied Operations manual. In that you will find a chapter for using the Remote as a Universal remote, and a list of codes will be give. Check out the code for Misubishi TVs and feed that.
Anonymous
  • Posted on Dec 30, 2008
SOURCE: panasonic vcr nv-sj200
To select AV, you need to use the remote and press the input select button.
Anonymous
  • Posted on Jan 12, 2009
SOURCE: Set the clock on my Panasonic NV-J11 HQ VCR
Hey there - I've got the exact same model VCR; although I've lost the manual as well, I've been using it for so long that I
can usually remember it all from heart:
To set the clock
1. Open the flip-down lid, push [CLOCK] button.
For each of the steps below, use the white-labeled [+] and [-] tracking buttons to increase/decrease each number.
2. Two digits should be blinking - this is the year (last two digits only) - adjust and push [NEXT] when done.
3. Two digits, with a "D" next to them should now be flashing - this is the month (1=January thru 12=December), adjust and push [NEXT] when done.
4. Two digits, with a "M" next to them should now be flashing - this is the day-of-month (1..31), adjust and push [NEXT] when done.
5. The time should now be displayed, with hours flashing - adjust and push [NEXT] when done.
6. The minutes of the time should now be flashing - adjust. When you push [NEXT], this will complete the date-setting and start the seconds-of-the-minute off at zero - handy for synchronising to an external time source (I recommend using the
Teletext broadcast clock if available - you'll usually find your recordings will start right-on time when you do this, depending on your TV station).
7. If you make an error at any step above, push [CLOCK] to exit clock-setting mode and start again.
Depending on your model of VCR - the clock may either persist through power failures (backup battery) or may have to be reset next time power is lost. Mine doesn't seem to have a backup battery.
To program the VCR for timer-recording: There are two modes, Timer Record (start and finish recording at arbitrary times in the future), and OTR ("One Touch Recording", start recording right now and finish at a set time in the future).
*** Timer recording ***
There are eight programme slots (numbered 1-8 on the display), each programme slot has an individual channel and start/finish time associated with it. Programmes can be scheduled up to 1 month in the future.
Push [PROG/CHECK] to cycle through each slot (after the eighth slot, it will return back to normal operating mode).
When you want to set a programme, push [PROG/CHECK] until you find an empty slot (date/time will be all dashes). Then do the following:
1. Channel should be flashing - set this using white-labeled [+]/[-] tracking buttons and push [NEXT] when done.
2. Date should be flashing (defaults to today), use [+]/[-] to adjust starting date and push [NEXT] when done.
3. Set the starting time ("ON" should be lit next to time) (defaults to now), use [+]/[-] to adjust starting time and push [NEXT] when done.
4. Set the finishing time ("OFF" should be lit next to time) (defaults to starting time), use [+]/[-] to adjust and push [NEXT] to complete the setting of this programme. After this, you'll be returned to the start of setting the next programme (the unit will also beep five times to confirm you have a valid programme set).
If you make an error (or you need to clear a programme slot that already has a programme set), hold down the [-] and [+] buttons for three seconds until the starting time/date becomes all dashes.
When you're done with setting your programme(s), keep pressing [PROG/CHECK] until you exit into normal operating mode, then push the [TIMER REC] button to activate the timer; this will put the VCR into timer standby mode, and the orange clock icon should be lit solidly on the display. There should also be a number (1..8) lit for each programme that has been set, but is still yet to run. Make sure you have the tape inserted and positioned in the right place when you do this.
After timer standby mode is activated, you can then push [PROG/CHECK] to review the individual programme slots; each push of [PROG/CHECK] will cycle through each slot (the display will time out in 10-15 secs).
To get out of timer standby mode (either when after the programmes have run or if you've made an error), push [TIMER REC] again - this will return you to normal operating mode (where you can fix errors if need be). Programmes that have run to completion should be automatically be cleared.
*** OTR (One Touch Recording) ***
This will start the tape recording immediately (good for when you have an unexpected distraction or sudden change of plans) and have it stop at a later preset time. The OTR mode only has one programme slot, unlike timer record.
1. Insert tape, have it positioned where you want to record from. Set the channel to the one you want to record from.
2. Open the flip-down lid, look at the bottom-right corner of the array of buttons inside.
3. Push the green-labeled [OTR +] button; this will start the tape recording instantly (the red "OTR" indicator should be lit on the display).
4. The stop time should also be displayed - use the [OTR -] and [OTR +] to adjust the stop time. When you're done, that's all you need to do (you can adjust it any time later).
To abort OTR mode (ie. if you start it by mistake, or want to stop the recording early), push the main [VTR] button to stop the recording. Yes, that's right - turn the whole thing off, it'll leave you in standby mode.
Hope this helps!
-- Bryan R.
Anonymous
  • 3 Answers
  • Posted on Feb 14, 2009
SOURCE: Panasonic PV-8400 Remote sensor not working?
This is indeed a faulty IR sensor. If it's just the sensor, swap with your good one to check. From memory they are plug in - a little device behing d the smoked translucent facia (display panel). I have come across this several times with Panasonic VCRs. Check whether the remote works at night time with all fluorescent lights in the room switched off. If so, the IR filter circuitry is faulty. Same solution - replace IR sensor on VCR.
Anonymous
  • Posted on Apr 28, 2009
SOURCE: My remote is stuck in VCR mode
RECODE THE REMOTE
HI I have just bought a Panasonic NV-FJ620 VCR and it doesn't have a remote - can I programme it without a remote? At the moment I can even get a picture. Thanks Nicola
You will have great diffculty. If you can't find the original remote get a good quality universal one. But have a look first for the original on somewhere like Curry's Parmaster website.
1helpful
I have acquired a Panasonic NV-FJ620B-S Video Cassette Recorder which has 2 x scart sockets on the back. 1 marked AV2 DECODER/DECODEUR(EX) the other AV1 (TV). The AV1 scart connector works fine on the TV...
Have just visited the Panasonic UK website and the User Manual for the Panasonic NV-FJ620B-S is available free. It lists on page 11 all the details. I'll e-mail it you Tom to see if it helps.
1helpful
The LP on my Panasonic NV FJ-630 VCR doesnt show a
I know of four places that deal in Panasonic parts and they are all on-line!
Number one is Grandata, 2 is Willow Vale, 3 is CPC.
The fourth one I have just checked on and they have the upper cylinder unit in stock at £47.99 plus P&P!
And they are Curry's Partmaster.
You might want to try the others just in case they do it cheaper, but I find that Panasonic heads tend to be all around that sort of price.
1helpful
I require a replacement remote control for a Panasonic NV-FJ620 VCR, recently bought from a car-boot, the VCR works fine but having a remote would be great. Please advise, thank you. Alex.
Try Curry's partmaster. They have 3 ranging in price from £14.99 to 18.99.
You could also get a universal one, these are cheaper, but often don't operate all functions. Remotes are sometimes a lot more expensive than the 3 on Curry's site, think yourself lucky that you didn't pick up one at the boot where the remote alone costs upwards of £60!
2helpful
VHS to DVD recording
OK connect the AV Out Yellow, Red, White, OR SVHS, OR SCART, from the VCR, connect these leads color to color to the DVD's AV whatever, IN.. Press Play on VCR, and "Record" on CVD that should do it.
Remote for VCR Panasonic NV-HD 630
I hope this helps. I found this replacement CLICK HERE
If that does not work for you, go to a Radio Shack or Best Buy and locate a universal remote. Ask the sales person to help you find the correct remote for your unit... Good Luck With That!
2helpful
2answers
Panasonic NV-SJ205 Changing Rf ?
ok. This is a really easy one.
All you have to do is hold down the menu button on the remote control for more than 5 seconds, If that doesnt work hold down the power button on the remote control for more than 5 seconds. If that doesnt work hold down the power button on the actual vcr unit for 15 seconds. The first method should work for Panasonic's fine.
This will then display your current rf output.
You can then change the output by using the up and down arrows or the channel up and down button on your remote or the vcr unit.
Press menu button to save or the same button you used to bring up the rf opposition eg power button on remote or the unit.
all the best. Top tech
3helpful
Nv fj630 can't power up
Had the same problem with my one. After a lot of time spent testing etc and finding no low volts of any value present and looking on the web, I found that Panasonic tend to use a similar design of power supply for a lot of models and there appears to be, after a number of years in use, a weak link in the design/use with the voltage regulator. For this model, the regulator generic part number is STRG 6352 and the Panasonic part no is C5HACZZ00002. In the UK it is available from:-
http:/www.chsinteractive.co.uk/electrical-components/misc/nvfj620b-c5haczz00002-ic-pana.htm
If you need a service manual for this model, which is helpful for checking things/disasembly/assembly, you can obtain a free one from:-
http://www.reptips.dk/Reptips/NV-FJ620.pdf
As a note the panasonic replacement from chs came with the pins bent correctly, so it fitted directly after I had cut the old one out.
Best of luck!
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
