Question about IBM ThinkPad T43 Notebook
MY IBM T43 fails to boot
When i power on my laptop it stops booting and gives the message Operating System not found. (sometimes - 1 out of 20 attempts it powers on and consequently shuts down after 5 - 10 mins but most times gives this message and wont start at all). What do you think is wrong?
  • Anonymous Dec 05, 2008
    I have the same problem mine wont boot to a CD or USB divice.
  • xniknakx Jan 01, 2009
    I have the same problem..
    I got my ibm laptop for christmas, and it only turned on once and worked.
    Then when I turned it on the next day, it says check media cable.. and then underneath it says operating system not found.
    :S
    Problem Solver:
  • 9 Answers
Take out the hard drive and see if the laptop still shuts down. If it doesn't then your hard drive might be the issue. You can also try reseating your memory.
Posted on Dec 27, 2007
Ibm t43 thinkpad cant change bios setup up utility to modify in user consult system supervisor
Boot the computer, when the first sign of life appears, tap f12. Go to boot order, then select cd drive as primary boot device.
Apr 10, 2014 | IBM ThinkPad T43 Notebook
How to boot ibm thinkpad t43
Press the power button and it will start booting.
Mar 28, 2012 | IBM ThinkPad T43 Notebook
Won't boot in safe mode
Starting an IBM Thinkpad T43 in safe mode allows you to troubleshoot technical issues that you otherwise couldn't. Often when a system has a virus or other type of malicious program, safe mode is the only way to locate and delete the problem. In safe mode, only the computer's essential programs are enabled, and only the files necessary to running the system are in use. Learn how to start an IBM Thinkpad T43 in safe mode using a few fairly easy steps.
1.Close all programs and restart the IBM Thinkpad T43.
2.Press "F8" repeatedly after the IBM logo appears, but before the operating system logo appears. If the "F8" key doesn't work, restart the computer and try pressing the "F11" key repeatedly.
3.Press the "down arrow" key to select "Safe Mode."
4.Press the "Enter" key. The computer will boot up in safe mode.
Sep 16, 2011 | IBM ThinkPad T43 Notebook
I have an IBM T43. When I try to start it up, it says error loading operating system. What can I do to fix this? Thank You!!
First, you need to check your BIOS to make sure the Hard drive is set as your primary boot drive.
Second, You need to do a complete diagnostic on the hard drive. Many times computers come with a chkdsk option but if not you should be able to make one on a different computer by downloading a disk diagnostic from IBM and putting it onto a bootable CD.
You need to determine if the hard drive is still good before doing anything with the software.
If the hard drive is good try booting into safe mode.
If it still does not load you may need to reinstall the operating system. Depending on the version you can do that without erasing all your files.
Apr 11, 2011 | IBM ThinkPad T43 Notebook
My thinkpad t43 have a crack sound when start on. then it come out a message state that cannot find any system on the set.
You might like to check for virus first by booting with a bootable virus software CD or USB flash drive. If that's it then a lot of headache saved. If no virus then maybe something wrong with your hard drive. You might like to boot with CD or USB flash drive by modifying the boot sequence in BIOS. If you can see the hard drive after booting, then you can backup the data and try a physical media scan on the hard disk. That may fix it if you are given some options. Otherwise you can reinstall the operating system by using the Operating System installation CD or the recovery CD. If Operating System CD is not given, there might be an hidden volume from where you can restore the laptop to factory default. The instruction of doing so should be there on the manual of the laptop. If those are not working, I guess you may need to call the support person of ThinkPad.
Jul 11, 2010 | IBM ThinkPad T43 Notebook
T 43 says "operating system not found"
Sounds like you have a bad hard drive. Boot up with a Windows CD and select repair at the setup menu. It should dump you to a command line. Type "chkdsk /f" without the quotes and it will check the hard drive for errors. When it's done, reboot normally and it should get you into windows. If it doesn't, replace the hard drive and install windows on the new HDD.
Oct 26, 2009 | IBM ThinkPad T43 Notebook
IBM t43 laptop wont power up
did you try to check if the power supply is working properly coz if no lights at all it means no power is coming.
Sep 16, 2009 | IBM ThinkPad T42p Notebook
BIOS self-set Password after upgrade/HD Install
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
try this if you can do  but i am not sure.  i am good on electronic things but its hard to do that. its only way.
May 28, 2009 | IBM ThinkPad T43 Notebook
Operating system not found, hard disk not found message showing in IBMT20
On my ThinkPad Notebook Windows 7, I have got "operating system not found" error, to fix problem, Windows Boot Genius helped me finally!
Dec 26, 2007 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T43 Notebook Logo
399 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
