Question about Panasonic PT-AE700U Multimedia Projector
Mustang projector mount required mounting projector upside down...
How do you flip the image 180 degrees?
You may have figured it out by now... From the remote, you go into the menu and find the setting "Display Image" and the option is "Ceiling".
Posted on Jan 15, 2008
I have a Panasonic PT-LM2U; when it is turned on, everything powers up fine but the image projected is upside down. I've looked through the menu but didn't see an option for flipping or rotating...
Every modern projector that I have seen has a setting that will allow you to flip the image for this.If you purchased it used it was probably configured as a ceiling mount in an upside down orientation or rear projection onto a translucent screen. (The projection method can be set from the "OPTION2" menu. in a Model LM1 so it should be similar. http://service.us.panasonic.com/OPERMANPDF/PTLM1U.PDF
If yours doesn't have this option, then you'll have to use mounts that require the projector to be upside down.
Jul 18, 2011 | Panasonic PT-LM2U Multimedia Projector
I mounted the projector on the ceiling and need to flip the image
ok go in the main menu u see 4 windows under on eof the options flip throw the windows to get it to go right side up ok in menu settings on the sony ok
Feb 02, 2008 | Sony VPL-VW100 (Ruby) Multimedia Projector
I want to attach a Vivitek 650HD projector to a ceiling mount, but am not sure if I mount it upside down. There doesn't seem to be a "flip" function to flip the picture.
I am 99% sure most projectors are mounted upside down. There should be a way to simply flip the image electronically via the option menu.
In most projector OCD menu (keep in mind you may want to do this before mounting), under the "Installation" or "Initial Installation" section should be an option about Projection mode/method. The options should allow you to pick front, rear, ceiling, or ceiling+rear. This sets the project to know when it will be in front of the screen, behind it, and/or attached to the ceiling (which it knows will be upside down). Then you simply set it to ceiling, mount the projector, and finish your other adjustments as needed.
Apr 27, 2011 | Televison & Video
Hello, please tell me how to flip the image upside down. I ceiling mount my M410HD and I can not turn the image 180 degrees. Thank you, Mircea
Go into projectors menu, and you'll find sub menu "display" and it will give you options front, rear, etc and choice front, ceiling
Mar 15, 2011 | Dell M410HD Projector Projector
Upside down images
the projector will project 4 image configurations: front, rear, ceiling front, and ceiling rear. go into the menu, under settings, and change it from ceiling to front.
Jan 07, 2010 | InFocus In2102 Projector
Words are backwords
There ia likely a menu item as some projectors can be mounted upside down OR more likely, used for rear projection requiring reverse reading.
Look for a menu setup item to change this.
Dec 31, 2009 | ViewSonic PJ513DB Projector
Upside down image
These projectors are designed to be mounted upside down. Think of a projector that is ceiling mounted in a classroom. Change this setting in Menu - Advanced Menu - Setup - Mirror.
Jun 09, 2009 | Hitachi CP-X445 LCD Projector
Angle of projected image
Hi there
No this can not be changed , the PB6100 was actually designed to mounted upside down in your ceiling and therefore the lens is 28-30 degrees upwards when projected on a flat surface.
Flip it upside down and you'll see what I'm getting at.
Oct 07, 2007 | BenQ PB6100 Multimedia Projector
Rotating the image.
Hi, I am not familiar with that model, But usually if you go into the settings menu you will see settings for the display which may be under "Display" "Rotate" "Keystone" "Flip" That model is made to be mounted upside down so somewhere in the menu there will be a setting similar to those I mentioned that will flip the image.
Hope that helps, Sorry I couldn't be more specific.
Sep 20, 2007 | Hitachi PJTX100 Multimedia Projector
Panasonic PT-AE700U Multimedia Projector Logo
543 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
