Question about Mitsubishi WS-55809 55" Rear Projection Television
Mitsubishi WS-55809 55 won't power up
Push the power button, the grn light stays lit for a few seconds and then turns off. If I unplug the set the power bbutton blinks several times and stops. ?Can I fix this myself
  • 4 more comments
  • Anonymous Jan 02, 2008
    i have a problem about reset button it always flashing green light we try to use press with an pointed pen but doesnt stop flashing its about one hour already can you help us to fix the problem
  • Anonymous Jan 04, 2008
    SAme thing
  • Retsailor Jan 05, 2008
    Got the same Problem nothing I find seems to work.
  • Anonymous Jan 09, 2008
    i have the same problem
  • Anonymous Jan 10, 2008
    tv has lost time and will not turn on with out code
  • edgeking Jan 12, 2008
    VS-70707 won't power up. Was working fine. Went on vacation came back and problem was there. Push power switch, green timer light comes on, the immediatly goes off.
Where is the reset button?
Posted on Jan 12, 2008
    Genius:
  • 1,153 Answers
Check error codes on here or ctechnicians.com
Posted on Dec 27, 2007
Turns itself off and then won't stay on
Do the self check.
If you unplugged the set, plug it back, turn it on and allow to fail.
Press both the Menu and Input (input may be labeled device) buttons on the front of the set and Hold both for at least 5 seconds and release both.
Power light will begin to blink a two digit error code like 2 blinks, 2 blinks, pause and repeat it for a total of 5 times.
Let me know what error you find and I tell you the meaning and a possible answer.
Dec 21, 2012 | Mitsubishi WS-65807 65" Rear Projection...
I have a WS-65907 tv, it wont turn on
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Oct 30, 2012 | Mitsubishi WS-65907 65" Rear Projection...
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
REGARDS, SD TECH
Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Push power button and timer button lights for a few seconds and then tv turns off model is Ws 55859
When it shuts down go to the set and press the menu and the Device/Input button both in together and hold for 6 seconds then count the two digit blink code from the power indicator. it will blink a two digit code which repeats several times.
Jul 23, 2011 | Mitsubishi WS-55859 55" Rear Projection...
TV won"t stay on turns off in 3 seconds WS 55807
Do the self check when power light goes off.
On front of set press and hold both the menu and input buttons for 5 seconds or longer and release both buttons.
Power light will blink a error code like: 2 blinks, 2 blinks, a pause and repeat about 4 more times.
Let me know what error code you find and I will tell you what it means.
If this information told you something rate this solution as very helpful as I do this here for free.
SD TECH
Aug 28, 2010 | Mitsubishi WS-55807 TV
Have a ws-42413 mitsubishi TV
This behavior could be an indicator of power supply problems or abnormal current drain from elsewhere in the set.
Modern supplies are, by design, able to shut down if voltage or currents aren't within the design limits of the circuits they are servicing.
Without some hands-on it is not possible to isolate the problem unless one of the forums deals with a series fault.
If the set had a reset button, it would be located on the outside of it where the user could reset it.
The reset buttons one finds on some sets is nothing other than a very cheap kind of thermal circuit breaker that trips when current is above its limit.
These are kind of prone to failure themselves.
Jul 13, 2008 | Mitsubishi WS-65905 65" Rear Projection...
TV wont stay on
you may have a convergence problum if your convergence ic,s are shorted, you will need to check the convergence fuses in the power supply.
May 06, 2007 | Mitsubishi WS-55413 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
371 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
