Question about Linksys (WMP54GS) 802.11g/b Wireless Adapter
I am no longer able to connect my wireless router...why?
I've simply turned on my computer and can no longer connect with my router.  I've restarted both the router, modem, and computer.  Checked the wireless cards status in the device manager, disabled and re-enabled it's use.  I believe the problem is the mode, it seems to be searching for an adhoc network...can you help?
  • clearcree524 Apr 09, 2009
    Bought a new Netgear rangemax. The router and my modem are working fine. I confirmed it with a friends laptop. My remote desktop computer has a linksys G wireless card. But, that computer won't give me a list of the available wirless signals to even connect to.
    Novelist:
  • 59 Answers
Hi canuck07,
Here's how to remove the ad-hoc setting (I'm assuming you're running Windows XP):
1) Right-click on the wireless icon on your system tray (right end of taskbar) and choose "Open Network Connections,"
OR go to Start Menu > Control Panel > Network and Internet Connections > Network Connections.
2) Right-click the wireless connection and choose Properties.
3) Select the Wireless Networks tab.
4) Under "preferred networks," select your network and click "Properties."
5) On the Association Tab, the bottom check-box corresponds to ad-hoc networks - uncheck it.
Hopefully this will make your adapter able to find your network. Please let me know if this doesn't work, or if I can be of any further assistance.
H2H
Posted on Dec 14, 2008
Ghostery turned off wireless signal
Hi There,
It's certainly purely coincidence that your network cut out after installing ghostery. The program has literally nothing to do with your network connection, it's simply a browser add-on.
The problem more than likely lies within your computer OS, either you've hit the wireless switch on your laptop (turn it back on) or (Fn+F8) or you've mangled your internet connection settings in your firefox options.
If all else fails, try removing the power plug from your router for 30 seconds, plug it back in and allow it to boot fully.
Jul 18, 2012 | Computers & Internet
Wireless connection
-Try restarting your pc.
-If the problem persists then unplug your router for about 15 seconds.
-If that doesnt work, then remove the code key that you assigned and see if the pc connects then you've simply entered the wrong code key that you assigned.
-If that doesn't then go into your network settings, right click on the network you are trying to connect to and click repair, it will try to diagnose the problem.
- It may be that you changed a setting in the router, try setting it to factory default.
I hope this helped!
Dec 08, 2011 | D-Link Wireless N 150 Home Router 4Port...
Im using a smcwbr14t-g router how can i create a secure wifi connection.a wifi with password so others cant connect thru my network.pls help ty
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Aug 16, 2011 | SMC Barricade g SMCWBR14T-G Wireless...
My belkin wont keep connection
1. Powercycle your equipment (unplug the power to your router and your modem)
2. Wait 15 seconds then plug equipment back in.
3.If your Modem runs off signal from a tower try and get more signal simply by moving modem closer to a window.
4.Check your connections to the modem and to the router, ensure the wires are plugged all the way in.
5.Using your wireless signal from your computer pc or laptop ensure you have sufficient signal you may have to move closer to the router, once in a while you will be to far from your router to have a good connection.
6. Make sure the ventilation slots on modem and router are not blocked.
7.Check to see how far your modem is away from any electrical equipment your modem should be away at least 3 feet away.
8. If you are able to keep connection directly plugged into your modem from your computer most likely there is an issue with the router, In this case you can always reset your router there may be a configuration error in your router, To reset simply press and hold reset button on the back of the router for approximately 15 seconds or until router restarts, Caution by resetting your router will reset back to factory default and your router will be unsecure once again.
9. When your are disconnected from the internet make sure that the Connection itself isnt still connected if your connection itself is connected and you are unable to get online you may need to renew your ip address. usually your ip address automatically renew's once the router and modem have been powercycled (unplugged and plugged back in) however you may need to manually renew your ip.
10.Windows Xp: Start/Run/CMD and press ok
A.Type ipconfig /release
B.Type ipconfig /renew
Windows Vista/7 Start/All Programs/Accessories/Right click on command prompt and hit run as administrator.
B.Type ipconfig /renew then restart your computer
If you are a Mac user:Here is a link to show you how to renew http://support.apple.com/kb/TS1920 If your continue to get disconnected contact your ISP (Internet Service Provider) Check and ensure that it is not an issue on there end
Nov 15, 2010 | Belkin (F5D5231-4) Router
My computer no longer recognizes my belkin router as a wifi access point. It's as if it stopped working. Any ideas?
Belkin products are all built from Refurbished materials. It is entirely possible that your wireless access point has simply stopped working. Try going in and restarting the wireless function on your router, you'll need to be plugged directly into the router via an Ethernet cable to do this though, if the wireless is not working.
May 17, 2010 | Belkin (F5D7230-4) Router (587009)
I have an Asus G60 laptop which was connected wirelessly to the internet. After a disconnection (router went off for a minute), the laptop no longer recognizes the wireless connection. The light on the...
Do you have PCMCIA adaptor or buil-in adaptor? If is pcmcia then unplug from computer, restart computer, after this shut down, plug your pcmcia and start again.
Mar 03, 2010 | Zonet (zew1600z) 802.11g/b Wireless...
Every time I do a restart, I lose the internet connection from any browser. Specs: ? Vista ? Toshiba Satellite L355 ? Apple ''Airport'' router (it looks like a flying saucer)
I think you are using any third party wireless device to connect your computer wirelessly so you simply need to connect your computer with the software of that third party device that you are using that will only resolve your concern
and if not then i suggest you to reinstall the wireless card on your computer and tried to reconnect and check teh connection after restarting the computer.
I hope that will resolve your concern
Thanks
Harmeet :)
Oct 28, 2009 | Apple Computers & Internet
Connection Not Consistent
You shouldn't have to run the setup wizard to reconnect. It sounds like you just haven't configured it to auto-connect to that wireless connection. Right click on My Network Places and select Properties. Right click on your Wireless LAN connection, and tell it to connect. You should be able to go through those settings and tell it to auto-connect to your router as well.
Sep 09, 2007 | Linksys Wireless-N WRT150N Router
Router works except for the wireless FEATURE!
If you disconnect it from the internet (i.e. unplug the internet cable) the router will not be able to communicate with the internet - therefor it will not work. Leave the router connected until you no longer require internet use, then simply turn it off.
Aug 09, 2007 | Linksys WRT55AG Router
Open Questions:
See all Linksys (WMP54GS) 802.11g/b Wireless Adapter Questions
Linksys (WMP54GS) 802.11g/b Wireless Adapter Logo
116 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
