Question about Sony CDP-C505 5-Disc CD Changer
Player does not recognize any discs
Any help on this would be appreciated. This Sony CD player had been on a shelf for a year or so as it was working sporadically then and I finally replaced it with a DVD/DVR/VHS unit. But, I missed the 5-disc feature so I thought I'd take another look at it. I took the lid off the player, loaded it with CDs and closed the carousel. It recognized the discs and I started forwarding through the discs and tracks and no problem. I then took it over to my receiver and hooked it up. The player would not recognize the CDs. Should you be able to see the light from the laser with the lid off? I turned off the lights in the house and could not see any light coming from the sensor. So, seemed to work for a few minutes, but then nothing. Any advice? Thanks.
  • classicxman Dec 27, 2007
    Otacon, Given the price of new units these days, is it worth it to replace the lens unit? Is that something I can do myself or is it a job for a technician? Thanks.
    Guru:
  • 1,894 Answers
May be its not compatiable with the reciever or so.
but i have seen that the laser will not be seen for all the time once the player starts.
just soon it starts it will be visible for us. but then after we cant see the laser. its not a problem. its its normal working only
Posted on Dec 27, 2007
    President:
  • 1,944 Answers
If you don't see any signs of the laser then it's most likely that the lens unit has malfunctioned or simply "died" (but in your case the laser still shows some signs of life since you said it recognized your discs). You need to get that replaced to have your unit up and running again. Sorry...
  • Damen Wong
    Damen Wong Dec 27, 2007
    It could be dust, so try using a lens cleaner (but it's highly unlikely). Try it just to be sure.
  • Damen Wong
    The problem with replacing the lens is the fact that the part might not be available anymore (your unit is relatively old.). Suppose you do find the part, it might not be cheap since it is rare. Suppose u get the part, if you don't have experience it could be hard. I would recommend getting a new one.
  • 490 Answers
Please do simple process by simply cleaning the lens area with cotton swabs. please don't try to play any disk in try open stage, you may damage your player thanks gizmo
  • J Jain Dec 31, 2007
    dear sir
    further found that voltage trasfered from mother board circute to lens unit may not be proper,
    i request kindly also get the voltage checked
    thanks
    Gizmo
I have had the CMT-NE5 system for four years now. Great little stereo. Recently anytime I try to play a disc I get the message "No Disc". I am using compatible disks, and have tried several...
Hello
Replace the flat strip wire that connects laser pickup unit to main board. If it does not help you, replace laser pickup unit with same typa and number. OK.
Dec 21, 2010 | Sony CMT-NE5 CD Shelf System
The CD player is not recognizing my CD disc. It states the CD drive is empty even though all 3 have the disc in.
If you already tried it with a known good clean cd, try using lense cleaner. If that do not work you are out of luck because that means the laser assembly is defective already, and replacing that is very difiicult, whats more they are an expensive part, costing anywhere from 50 to over a hundred bucks. Lastly they are hard to find for a particualr model.
Nov 28, 2009 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Help - CD won't eject! I press 'Open' on my sony CMT-EX1 system and the CD moves backwards as though it's going to eject but then it stays there, unreachable. Then the display begins to switch between...
I have the same problem and it's due to dirt!
I'm going to try using compressed air, but -
this definitely works:
:) Seriously:
tilt the cd player to a 45 degree angle (flat, basically - as if they tray were horizontal.)
I had my player for 10 or 12 years, and this problem is only coming up now. My house gets very dusty.
Also - vertical load disc players are hard to clean. X_X (inside the disc tray)
I love this stereo too!
I don't want to have to go out and buy another stereo!
Oct 16, 2009 | Sony CMT-EX1 CD Shelf System
RCA RP-9515 stereo, CD player won't play
RD probably stands for "Reading Disc" and ND probably stands for "No Disc". If the CD player doesn't recognize any discs, then either the laser is dead or the motor has died. MOst likely you will have to replace the unit.
Mar 22, 2009 | RCA 100-Watt Stereo System With 5-CD...
CD PLayer no longer recognising CD RW discs
Try cleaning the discs with straight swipes, with a dry cloth, like your shirt, starting from the center and swiping outward.
Mar 01, 2009 | Sharp CD-XP5500 CD Shelf System
CD Player does not recognize CD
If using computer generated dics , disc usally bad burn progam , bad disk, burn speed to fast. Check out NERO burn. OR dirty eye, clean, laser eye with disc clean disc
Oct 05, 2008 | Teac DC-D2831 CD Shelf System
CD Player will not play, just moved the tray in, then out and stops.
Take off the metal cabinet cover, then find the lens on the exchanger and blow it off with some compressed air. If it still won't work, then try a different disc (commercially made, like from Wal-Mart) because the disc might be unreadable
Nov 25, 2007 | Sony MHC-RXD3 CD Shelf System
CD Player not working
Since the unit was in storage for a while dust may have settled on the lens.Try cleaning the lens.
Dec 17, 2006 | Sharp CD-XP120 CD Shelf System
Sony CDP-C505 5-Disc CD Changer Logo
305 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
