Question about Maxtor Hard Drive
My hard drive shows only 1.5 GB instead of 100
Hi, I replaced a hard disk in my toshiba satellite laptop (new disk is 100GB, old was 40GB). After I installed XP and then wanted to install more software (and I didn't have enough space) I realized that my hard drive is only 1.5GB. When I go to DOS, it shows 100GB... There are no partitions...
I first installed win 98 and then xp, but I can't use boot disk win 98 because this computer will only install the floppy disk drive if I have XP (the drives are on the factory disk compatible only with xp)...
Any suggestions?
  • 4 more comments
  • i-vegy Dec 27, 2007
    yes, I installed it from the upgrade disk and didn't convert it to NTFS (how?)... I also uninstalled xp, but the problem was the same on win 98.
    thanks but I can't format the drive,
    it gives me a wired message:
    Windows cannot format this drive. Quit any disk utilities or other programs that are using the drive and make sure that no windows is displaying the contents of the drive. Then try formatting again.
    Also this model of toshiba satellite doesn't have an access to BIOS settings.
    yes, cd second edition.
    system is FAT
    473 MB used space
    1.55 GB free
    thanks for the explanation, now I understand what happened. I know only how to convert it to FAT 32, but I have no idea how to repartition it to non dos partition.
  • i-vegy Dec 29, 2007
    I will try later, my other computer has problems, I will have to wait till next week to fix it.
    Thanks a lot for your help and I will let you know how it went.
    Problem Solver:
  • 4 Answers
Is it correct that you installed XP from an "upgrade" pack?
when you installed XP did you convert the file system to NTFS?
Posted on Dec 27, 2007
  • 4 more comments
  • olrob Dec 27, 2007
    most win98 installs use a "32bit FAT" file system. this has limitations on the maximum size of partitions and file sharing/locking etc etc. as does the earlier "16bit FAT" (or just FAT). To get the full features of XP you need to run the NTFS.
    (note that there is "early" and "late" NTFS).
    You CAN run XP with FAT-FS, but should only do this if you need to continue accessing the partition with an earlier operating system.
    The best option is to FORMAT the partition as a NTFS partition. If this is not possible (ie because your XP upgrade requires an existing older system and your upgrade pack does not give you the option to reformat into NTFS) do the "conversion" at the earliest stage possible. Note: the conversion is a "one-way" street, there is no going back.
    Check your BIOS carefully to see if the detected cyls/hds/secs are correct and BIOS is showing the correct capacity. It maybe that the older bios does not contain the correct translation table for the drive. If in doubt select "user defined drive" and enter the "physical" cylinder/heads/sectors as specified by the DRIVES manufacturer.
    Reinstall win98 using the custom install option, carefully think and select options. Install the minimum, choose the highest level of File System available (ie not FAT16) (NTFS is higher than FAT32).
    If things look OK after this proceed to install XP upgrade remembering to selecting to use NTFS. If not looking OK it is time to run Maxtor drive diagnose/install program like MaxBlast available for down load from Maxtor/Seagate web site.
    ah yes the good ol Tosh Sat dilema.. never mind.
    Best to avoid using Windows format anyway.!!
    is your win98 install disk SE (second edition)?
    i am assuming it is a CD?
    in win98: double click "my computer", right click c: drive, click "properties"
    whats the file system? how do the numbers look?
    try Programs >Accesories>system tools>Drive Converter and try to convert the FS to FAT32
    what brand of drive is the 100gb pure Toshiba or Seagate Maxtor Western Dig etc?
    the problem you have is that FAT(16) can only address a volume size of 2.1Gb (1.55gb + 473Mb), and somehow your 100gb drive has been initialized/formated with that. Older op systems like DOS and Disk Manager programs of that era only know about FAT16 so they just call it FAT. even after you convert the fat to 32 bit, you are still stuck with the existing partition size.
    Suggest that you scrap the current content of drive by repartitioning it as one NON-dos partition if possible and definitly not formated.
    Then when you boot from the win98 setup CD, the 2nd or 3rd screen you see should give you the option of "Configure unallocated disk space" or "Exit setup".
    obviously select the former.
    the system should reboot (onto the CD again) and proceed to FORMAT the drive. You should be ok from there.
  • olrob Dec 28, 2007
    OK lets try it this way! If the toshiba blocks you, let me know exactly where.
    Boot from the win98 CD but DO NOT launch setup. Select instead "Start computer with CD-ROM support" it should give you the A:\> prompt.
    type in "fdisk" press enter key. Say Y to large disk support. DELETE all existing partitions. Create 1 primary Dos partition.
    after exiting fdisk Reboot and launch win setup. it should automatically start formating.
    (the maximum volume size for FAT32 -therefore win98- is 137gb).
I want to install max capacity HHD on my Satellite A30 series,. The existing HHd is 40 GB ( too small) with IDE connection. Can you recommend a suitable hard drive of 100GB or higher capacity
Sure, you can go to a market that it close to you and buy two things, a new hard disk at any size you want and a connecror between sata and IDE then go to prof man with these laptops
Dec 27, 2010 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
What is the drive type used in the Toshiba 2415 S205 laptop?
Specifications of TOSHIBA Satellite? 2415 Series
P4 2000MHz/15.0”XGA/256MB/40GB/DVD-CDRW/Mdm/LAN/WinXP Home
Satellite 2415-S206
P4 2000MHz/15.0”XGA/256MB/40GB/DVD-CDRW/Mdm/LAN/WinXP Pro
Mobile Intel® Pentium® 4 processor-M at 2.00GHz
Memmory 256MB expandable to 1024MB
All-in-one design
40GB* hard disk drive
DVD-ROM/CDRW multi-function drive
Mar 15, 2010 | Toshiba Satellite 2415-S205 Notebook
Toshiba (MK1031GAS) 100 GB Hard Drive - Cant be viewed in My comp
The first thing you need to do is go into the Control Panel, then double click on Administrative Tools. After that, open up Computer Management, then go to Storage, then Disk Management. This is where you will see all of your drives listed. Be extremely careful in this section because you don’t want to screw up your main hard drive.
What you are looking for in the Disk Management area is your new hard drive. If you only have one hard drive, it should show up as Disk 0. Therefore, your new drive should most likely be Disk 1. Underneath the name Disk 1 it should say Unknown, the size of the disk, and Not Initialized. Right click in this area and you should get a pop-up window. Click Initialize Disk and it should only take a couple of seconds.
Once your new hard drive is initialized, you will still have to format the drive before you can use it. To format, right-click in the column to the right of the Disk 1 label and then click New Simple Volume in the menu that pops up. From here, you can allocate how much of the drive you want for a new volume, what drive letter you want to call it, give it a name, and finally format the hard disk.
Formatting the hard drive may take a while, depending on the size. My 500 gigabyte drive took nearly an hour to format, so don’t be alarmed if your's takes a while. Once the format completes, your new hard drive will now show up in My Computer and you can start putting files on it.
Dec 24, 2009 | Toshiba (MK1031GAS) 100 GB Hard Drive
Internal Hard Disk Upgrade
Yes, there is. Match the type of drive (Serial ATA or Parallel ATA) you get with what you have. Make sure your Satellite sees the drive in the BIOS. For drives larger than 120 GB, recommend operating systems Windows XP (Service Pack 2 or higher) or Vista. Older OS's have a 137 GB limitation (they only see the first 137 GB of the hard drive despite its size).
Mar 01, 2009 | Toshiba Satellite M45-S359: M45-S359...
Hard disk capacity increase
yeah you need to replace the old hard disk to new IDE 120GB hard disk.
Jan 20, 2009 | Toshiba 100GB Laptop for Satellite 2400,...
Hard drive
These instructions should help.
Toshiba® Satellite 100, 105, 110, 115, 200, 205, 210, 400, 405, 410, 420, 430 Series
Hard Drive Installation Instructions
  1. Turn notebook upside-down.
  2. Remove the battery compartment cover.
  3. Remove the battery pack.
  4. Remove the 2 Phillips screws that mount the hard drive down.
  5. Slide the hard drive away from its connector and gently lift it out of the notebook.
  6. Remove the tray from the old hard drive and assemble it onto the new hard drive.
  7. Slide the new hard drive into its connector inside the notebook.
  8. Replace the 2 Phillips screws used to mount the hard drive into place.
  9. Replace the battery pack.
  10. Replace the battery compartment cover.
Jul 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
Hard drive
I think as bigger drive as ya can afford say up to 80GB.. would be OK.. just make sure that the new drive is same type as old and ya be all good.
Jul 28, 2008 | Toshiba Satellite A105 Notebook
It is possible by opening up the case and removing the old hard drive and replacing it with a new one. You will have to reinstall Windows.
Aug 23, 2007 | Toshiba Satellite A45-S250 Notebook
Maxtor Hard Drive Logo
292 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
