Question about RCA RCR311B Remote Control
Re: tv unable to program channels
We purchased a tv and we can't get any channels. The tv is not hooked up to a box its going to the wall it is basic cable. How can I get channels? Do I need a box?
NO!!! you need to auto program the T.V go through the menu and find auto progeam its easy
Posted on Feb 21, 2008
Westinghouse VR-2188 will not find channels when hooked up to comcast basic cable box but will if connected straight into wall, whats wrong? Cable box works on all other TV's in the house also so it is...
Make sure you have selected "cable" as the source input to the tuner. If there is a selection for both digital and analog channels when doing a channel scan then select it.
Jan 04, 2014 | Westinghouse Televison & Video
So you want to connect your receiver thing to your tv ?
or your cable ?
Well if the antenna cable is hooked up, you should be able to simply run it up behind your tv and put it on the antenna plug.
The reveiver should attach to your tv with a cable provided.
Dec 27, 2007 | Televison & Video
I have a Samsung hdtv but its not playing in hd.I have it hooked up to cable straight from the wall bypassing the cablebox.Is it the tv or cable?
You do not indicate if you have auto programmed the television to get digital channels, If you are selecting a channel without a decimal point, for instance 82.3 is NBC hd in my cable system. If your cable provider does not produce these on direct cable then you can not get HD without a box.
Try to Auto Program your tv in the cable mode STD format, this can take up to 20 minutes to complete scan including deleting scrambled channels. After programming try the lowest or highest analog channel like 2 or 70, channel down or up from there to see if any digital channels appear.
Mar 01, 2013 | Samsung Televison & Video
Unable to view/record cable channels with Panasonic DMR EZ48V
Here is what you will need. This is assuming you do not have a HD cable box.
1) A two port cable splitter available at your local hardware or electronics store. VERY IMPORTANT- this splitter needs to pass up to 1000 mghz so you do not interfere with the functions of the cable box. Also, when purchasing this don't be fooled gold does not always equal good (a common mistake made by folks).
2) 1 small coax cable.
3) 3 Additional coax cables. (1 long enough to reach from the wall to the cable box. 1 long enough to reach from cable box to the TV. 1 long enough to reach from wall to the VCR. These cables should be RG6 coax cable (about the width of a standard wooden pencil)
4) 2 RCA cables (Yellow/Red/White)
Here is how you need to connect the cables....
1) Use the small coax cable and connect it from the WALL to the INPUT of the two way SPLITTER.
2) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the CABLE BOX.
3) Use one of the coax cables and connect it to the OUTPUT of the CABLE BOX to the INPUT of the TV.
4) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the VCR.
5) Use one of the RCA cables and connect to the DVD/VHS COMMON OUT on the VCR. Connect the other end of this cable to the VIDEO IN on the back of the TV.
6) Use the other RCA cable and connect it to the VIDEO OUT on the back of the CABLE BOX. Connect the other end to the IN 1 on the back of the VCR.
Here is how to set up the VCR-
1) Tune the TV to the video input that you connected the VCR to.
2) Go to the auto program in the menus for the VCR and select "CABLE" as the source and you should now be able to get all the channels you would normally get without the cable box.
3) This will give you the option to record shows from basic cable on the VCR. While copying these channels you will still be able to tune the TV to CH 3 for the cable box and watch TV normally through the cable box.
4) If you want to copy one of the channels that is only available with the cable box you will still be limited to only being able to watch that channel while it is recording but here is how you will do it.
  • Tune the CABLE BOX to the channel you want to record.
  • Tune the TV to the VIDEO INPUT you have the VCR connected to.
  • Select either VCR or DVR on the VCR.
  • Select recording mode.
  • Press the INPUT SELECT button.
  • Select IN 1.
  • Press RECORD.
Hope this has been helpful....
Good Luck....
Jan 19, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
To hook cable to tv
tke the coax cable coming out of your cable box and connect into the coax connector on
your tv.put the tv on channel 3 and change channels with the cable box.if you do not have a cable box run thcable from the wall into your
tv and auto-program the tv.
Jul 28, 2009 | Televison & Video
Hooking up DVC/VCR to HD cable box/TV
Hi Seve.
Not sure what is meant by 'HD cable box'.
If you mean a DSD (Digital Satellite Decoder), then the built-in firmware prevents recording (of composite video signal).
In our country the SP requires that you buy a dedicated 'Explora' decoder which allows recording.
HD cable technology may have introduced similar anti-piracy measures.
{reminder to me: Google "HD cable TV" :)
Oct 06, 2017 | Televison & Video
No channels?
Try going into the setup menu and make sure the ANT input is set to cable. Then look for Auto Program or Channel Setup and let it scan and find all the channels it can receive. After it's done you should be able to go up and down through the channels.
Feb 16, 2008 | Sharp 32R-S50 32" TV
Cannot program cable to tv
if your are using a cable box,all of your channels will be control only on the cable, what you are going to do is use the remote control of the cable box.
Nov 07, 2007 | Panasonic PV-C1320 13 in. TV/VCR Combo
Programming digital channels
The problem is not with your TV. You need a digital box to unscramble the channels.
Oct 28, 2007 | RCA HD52W56 52" Rear Projection HDTV
Not able to scan stations
I don't understand why you would bother to scan channel when you have directv or dishnetwork???
directv or Dishnetwork required their units in order to watch any channel,which means:
A. Depending on your TV setting,if you use RF connection from your basic directv to the tv,you would have to leave the TV on Ch.3 or view the rest of the channels,you have to change it from the directv or dishnetwork box. You are NOT able to scan the rest of the channels from the TV,bottom line!!
If you have comcast or your local cable provider,once you have activated,you could use the RF signal coming out from the wall plate straight to the tv and go to TV auto programming,it will auto scan the available channels for you.
Don't waste your time on directv.
If you are thinking about recording from your BASIC directv or dishnetwork box, you would connect SAT. signal from the wall plate to the directv box,then use composite video/audio output and connect straight to your VCR/DVD player under composite video/audio input. Now you could record the viewing channel to the VHS.
Aug 19, 2007 | RCA DRC8335
RCA RCR311B Remote Control Logo
223 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
