Question about Jensen MP5610 CD Player
How to remove
I cant seem to remove my jensen cd player from the dash of my 95 plymouth neon. i bought the universal removal tool for car stereos but neither types worked...
  • 53 Answers
Just take out the whole dash kit and then you will be able to take it out
Posted on Sep 02, 2008
How to remove the stereo on a 1996 mazda mpv
Mazda MPV Dash Trim Removal, Stereo Removal - Auto ...
? 3:38
https://www.youtube.com/watch?v=REoTeVM2S-o
Jul 1, 2013 - Uploaded by Robert DIY
Dash trim removal: 5 minutes. This video will show you how toremove the dash trim piece on the Mazda ...
[PDF]MAZDA 1996-UP MPV - Scosche
www.scosche.com/media/guides/ma381.pdf
164. 1996-UP MAZDA MPV. MINIVAN. RADIO REMOVAL USING SCOSCHE DT-1 TOOLS . FRONT DOOR PANEL. FRONT AND REAR DOOR 61/2" 3-HOLE.
DIY Mazda Car Radio and Speaker Removal, How to Remove
www.carstereoremoval.com/htm/stereoremovalMazda.htm
'96-99* Car Stereo Removal · Ford Stereo Removal Tools Stereo Removal Tools. How To Install and Remove Mazda MPV Van Car Radio and Speaker, '89-95*
Jan 31, 2016 | Mazda Cars & Trucks
How do you install in dashdvd player in 2002 jaguar s type
Here is a link: http://www.youtube.com/watch?v=G-7DhH2xQQE
The video shows a guy using a metal pry tool. NEVER USE A METAL TOOL TO REMOVE DASH PANELS! Purchase a plastic dash panel removal kit to prevnt damage and scratches to the dash finish.
Aug 23, 2012 | Jensen's VM9312 Car DVD Player
How do you remove radio, from my 2001 dodge neon, that just went dead, for no reason. I replaced the fuse on the side of dash board. Still nothing.
Safety Precautions
  • Before removing the stereo or any other electrical component, it is vital that you first disconnect the grounding cable from the Neon's battery. The grounding cable connects the battery to the frame or chassis of the vehicle.
    Use a Phillips-head screwdriver to loosen the grounding cable's camp from the negative battery lead. Make sure to rest the clamp away from the negative lead post until the removal is complete.
  • Remove the Dash Trim Panel
  • The dash trim panel that surrounds the Neon stereo needs to be removed to access the stereo. The panel contains, but is not connected to, the climate control knobs on the dashboard.
    Grab the panel at the bottom corners and pry it from the dash. You will likely be able to remove the panel without the assistance of a trim pry tool, but if you are having difficulty removing the panel by hand, wrap a thin cloth around a trim panel removal tool or flat head screwdriver to remove the panel.
    Once the lower edge of the panel is relieved from the panel, you can work your hands (or flat pry tool) around the perimeter to separate the remaining edges.
    Since the panel is not connected to the climate control knobs, you will not need to disconnect the wiring to the knobs. The panel, once free, can be set aside until you replace the stereo.
  • Remove the Stereo
  • The Neon stereo deck is held into the stereo mounting bracket by 10 millimeter bolts on either side of the radio. Remove the bolts and store them in the ashtray for safe-keeping.
    Pull the stereo from the dock. The unit will easily slide from the mounting bracket with an even pull from the left and right of the stereo. Pull the stereo far enough to reach the wiring on the rear of the radio.
    The wiring to the stereo includes the antenna, the power supply and the speaker wires. There may also be patch cables connected if an amplifier is connected to your stereo system. Pull the cables from the stereo. The antenna and power supply are single cables. The speaker wires (and patch cables) will be grouped by wire binders. The plastic wire binders should be pulled as a unit. Do not pull the wires themselves.
    Once the wiring has been disconnected from the stereo, the unit will be completely free from the Neon.
    If you plan to operate the vehicle before installing a new stereo or re-installing the factory deck; reconnect the grounding cable to the negative battery lead. Otherwise, leave the cable away from the negative lead until all of your work is completed.
  • Feb 26, 2011 | 2001 Dodge Neon
    Replacing Stereo in 99 Plymouth Neon
    What for? All you need to do is hook up the power wire, a ground and the speaker connections and you are good to go.
    Want some good stuff go to Crutchfield. Have everything and very helpful with installation Crutchfield Car Stereo Speakers Home Theater Pro Audio 4k TV
    Sep 04, 2017 | Sony Car Audio & Video
    Dash removal 95 plymouth voyager
    This is a fun one. I was going to attempt to explain, but pictures are worth a thousand words on this one! See www.carstereoremoval.com/htm/stereoremovalDodPlyVoyager94_95Str.HTM This is a temporary page, please print when accessed.
    Nov 14, 2008 | 1995 Plymouth Voyager
    DDX512 Video Playback Bypass
    I grounded my Jensen to a screw inside the dash. I had to put a switch on it though - Jensen requires an on-off-on sequence with the parking brake, which applies and removes the ground. I duplicate this by throwing the switch. Check the manual or online references to see if you have to do this. If you do, you'll need a switch. If not, you can just ground the wire.
    Aug 19, 2008 | Kenwood Excelon DDX-7015 Double Din Car...
    Jensen cd 615x
    order from jensen or go to a local audio store, ie sound creations,
    or a store that installs car stereos, I have had pretty good luck with circut city, best buy is a bit cheaper, but then again you get what you pay for.
    Mar 05, 2008 | Jensen CD-615X CD Player
    Cd player
    1998 new, well, okay, u will need to have an philips screw driver and remove part of ur AC Buttons panel from undearneath there should be some screws remove them all, from top and bottom, and the see if the panel is loose enough to remove it, and then u ll be able to see the screws that hold the Deck. and i believe what u need to do now, (remove the wiring and install the adapter and ur new CD Player)
    Dec 18, 2007 | Jensen CD4610 CD Player
    How do I get it out of the dash
    the radios come with 2 removal tools. you remove the trim plate then slade the tools in one per side... what kind of car? i may be able to tell you a different way of removing it..
    Sep 05, 2007 | Pioneer DEH-P44 CD Player
    Jensen MP5610 CD Player Logo
    161 people viewed this question
    Top Jensen Car Audio & Video Experts
    xxxxxx xxx
    Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
