Question about Fuji FinePix A360 Digital Camera
Camera shuts off
My camera just shuts off if i hit any button . i have put 3 new sets of battries in it. i can leave it on for a couple of minutes the green light comes on and the lens comes out and the display lightsd up and i can see all movement on it. but if i touch any button it just shuts off not saying anything about a low battery or any other problem.
  • 8 Answers
SOURCE: Camera says brand new batteries are dead, then shuts down
It is possible that the batteries are dead (they might be faulty or too old) even when they are out of the package, though unlikely. Try another set of batteries, and if these don't work, you'll probably have to send it for a checkup.
Posted on Nov 01, 2005
  • 188 Answers
SOURCE: Fuji FinePix S500
try using it with fresh pair of fully charged batteries.
Posted on Jul 25, 2008
SOURCE: I turn camera on and it shuts off immediately
I had the exact same problem, it would shut off after trying to turn it on. The door to the memory card has very small tabs on it that push in some kind of sensor inside the camera when you shut the lid. It starts up when I push in the sensor.
Posted on Sep 07, 2008
  • 1223 Answers
SOURCE: My FINEPIX s1000fd fujifilm camera
pls update firmware issue will be resolved most likely and pls rate me fixya for help
Posted on Apr 13, 2009
SOURCE: fuji s1 pro problems
I cannot solve the problem, but will say that in searching for a solution to my problem, I read in the manual that if you are not going to use the camera for a while, to take the batteries out. This is probably why you now have a malfunction. I sympathise - only now do I know this myself, having not referred to the manual very much in the past eight busy years. Sorry for your loss.
Posted on Sep 16, 2009
  • 11967 Answers
SOURCE: camera has a glitch?????
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 26, 2010
0 characters
1 Points
My camera discharging battries after few minutes ?
Time to have it checked by camera tech, no user fix.
Nov 22, 2012 | Kodak EASYSHARE Z1285 Digital Camera
Out of the box camera yesterday. Random LCD & power problems
Send the camera back, it's obviously faulty by what you have explained.
It should be under the manufacturers warranty so there will be no repair costs.
Jul 27, 2010 | Kodak EasyShare Z950 Digital Camera
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
Date Settings
Hi there and thanks for coming to FixYa.
To put the date and time stamp on the images do this:
1) Set the Mode dial to Setup.
2) Hit the Up arrow on the control button to Camera and hit the right arrow on the control button.
3) Select Date and Time with by hitting up or down arrow on the control button then press right on the control button.
4) Hit the conrol button up or down to select Date and Time, then press the center of the control button.
5) Return the Mode dial to the camera postion to start taking pictures.
Feb 28, 2009 | Sony Digital Cameras
Does anyone know how to set the time on on vq 500 camera?
put ur camera on camera mode not play mode and hit the mode/delete button 3 times and hit ok(by the on/off button) and set it
Dec 25, 2008 | VistaQuest VQ-5115 Digital Camera
Setting time and date on Samsung BL 103 digital camera
1. Turn It On (lol)
2. Hit the menu button. ( the Middle One)
3. Go over to the display option ( Third One Over)
4. Go Down To date and time
5.hit the right button
6.hit the right button again
7. when you get to the date and time just hit the up and down button to change it
8. and finally hit the ok button ( same as the menu button)
Dec 06, 2008 | Digital Cameras
Polaroid pdc 4055
Take batteries out- leave for an hours or more re insert batteries and follow set up procedure in the manual
May 12, 2007 | Polaroid PhotoMax PDC 4055 Digital Camera
Camera wont turn on even with new batteries
In order to narrow down the issue, I suggest you the following steps. 1) First of all we have to power drain the Camera. Take out the battries and unplug adaptor, now hold the power on putton ( Click Button) for a minute this will clear the static power on Camera. If this doesn't fix the issue, Than.... 2) As cam is working fine with Ac adaport and batterys are not working you have to check the cam with the new battries. If you store battries for a long time with out using them, they may result in battery drain. If this doesn't work. 3) Then it need a Physical check, where we can track if Power suply from battries are reaching till its destination or not. This is the way to narrow down the issue. Thanks you.
Apr 08, 2007 | Konica Minolta DiMAGE Z1 Digital Camera
Fuji FinePix A360 Digital Camera Logo
37 people viewed this question
Top Fuji Digital Cameras Experts
Steven Wander
Steven Wander
Are you a Fuji Digital Camera Expert? Answer questions, earn points and help others
